Just want to share this, maybe this can help other blynkers…
#include <UIPEthernet.h>
#include <BlynkSimpleUIPEthernet.h>
Arduino Boards = ENC28J60 Network Card
RESET = RESET
3.3V = VCC ====== ( take note / take note / take note / take note 3.3v only.)
GRND = GND
PIN10 = CS
PIN11 = SI
PIN12 = SO
PIN13 = SCK
Warning:
Using this UIPEthernet Memory utilization is too high. it consume around 70% of your memory program storage.
char auth[] = "xxxxxxxxxxxxxxxxxxxxxxxxxxxxx";
// Mac address should be different for each device in your LAN
//byte arduino_mac[] = { 0xDE, 0xED, 0xBA, 0xFE, 0xFE, 0xED }; //Original mac address
byte mac[] = { 0xDE, 0xED, 0xBA, 0xFE, 0xAA, 0xA1 }; // modify the last 2 colomn hexa dicimal only ex.. (0xAA, 0xA1 };)
IPAddress localip ( 192, 168, 254, 150); // your arduino i.p address, through ENC28J60
IPAddress mydns ( 192, 168, 254, 1);
IPAddress gateway ( 192, 168, 254, 1);
IPAddress subnet (255, 255, 255, 0);
IPAddress serverip (192, 168, 254, 50); // your local server i.p address
//Blynk.begin(auth);
// You can also specify server.
// For more options, see BoardsAndShields/Arduino_Ethernet_Manual example
Blynk.begin(auth, serverip, 8442, localip, mydns, gateway, subnet, mac);
