Hi everybody, this is my first post and I need a help to solve a problem that I don’t understand.
I made a sketch that work fine with arduino UNO and an ethernet shield BUT…
if I put the string: Udp.begin(localPort) the program stuck in row 157.
I show the code until the problematic row.
Thanks and I apologize for my english
Alessandro.
1. include <SunLight.h>
2. include <SPI.h>
3. include <Ethernet.h>
4. include <EthernetUdp.h>
5. include <BlynkSimpleEthernet.h>
6. include <TimeLib.h>
7. include <WidgetRTC.h>
8. define BLYNK_GREEN "#23C48E"
9. define BLYNK_BLUE "#04C0F8"
10. #define BLYNK_YELLOW "#ED9D00"
11. #define BLYNK_RED "#D3435C"
12. #define BLYNK_DARK_BLUE "#5F7CD8"
13. SunLight mySun; // Declaration of the object
14. float myLatitude = 45.9;
15. float myLongitude = 12.6;
16. //----------------- Comunicazione UDP (User Datagram Protocol) ---------------------
17. byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //DE:AD:BE:EF:FE:ED
18. IPAddress ip(192,168,1,40);// arduino luci
19. unsigned int localPort = 7880; // arduino luci
20. char DatiRX[20];
21. EthernetUDP Udp;
22. IPAddress IP_Remote(192,168,1,41); //citofono
23. unsigned int Port_Remote = 7878; //citofono
24. EthernetClient client;
25. char server[] = { 64, 233, 187, 99 }; //"www.google.com";
26. //----------------- TIME ---------------------
27. WidgetRTC rtc;
28. BLYNK_CONNECTED() { rtc.begin(); }// Synchronize time on connection
29. int oraPrecedente = 0;
30. //--------------------------------------
31. #define BLYNK_PRINT Serial
32. char auth[] = "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx";
33. //passw: alebl //
34. int BttBlynkLuci = LOW;
35. int BttBlinkAntifurto = LOW;
36. int BttBlinkDisattivaSensore = LOW;
37. int BttBlinkflash = LOW;
38. int ValueUltimaVisita = 0;
39. bool SensorePresenzaDisattivato = false;
40. bool presenzaAttivata = false;
41. bool contaSecondiLuceAccesaTemporaneaTimer = false;
42. String tutto = "";
43. BlynkTimer timer;
44. void checkPhysicalButton();
45. void checkPhysicalButton(){}
46. BLYNK_WRITE(V0) {BttBlynkLuci = param.asInt();}
47. BLYNK_WRITE(V1) {BttBlinkAntifurto = param.asInt();}
48. BLYNK_WRITE(V2) {BttBlinkflash = param.asInt();}
49. BLYNK_WRITE(V3) {ValueUltimaVisita = param.asInt();}
50. BLYNK_WRITE(V4) {BttBlinkDisattivaSensore = param.asInt();}
51. //BLYNK_READ(V2) {Blynk.
52. bool luceRossaAttivata = false;
53. bool luceGiallaAttivata = false;
54. bool luceVerdeAttivata = false;
55. WidgetLED ledWrosso(V11);
56. WidgetLED ledWgiallo(V12);
57. WidgetLED ledWverde(V13);
58. //Uscite:
59. #define LedSemaforoRosso 7
60. #define LedSemaforoGiallo 6
61. #define LedSemaforoVerde 5
62. #define ComandoRele 4
63. //Ingressi:
64. #define ConsensoPLC 3
65. #define SensorePresenza 2
66. bool StatoLuceManualePLC = false;
67. bool StatoLuceManualeBlynk = false;
68. int Presenza = LOW; //SensorePresenza
69. int Consenso = LOW; //ConsensoPLC
70. int contaSecondiLuceAccesa = 10000;
71. int contaSecondiPresenzaRilevata = 15000;
72. int contaSecondiLuceAccesaMax = 10000;
73. int contaSecondiLuceAccesaTemporanea = 10000;
74. void AzzeraSemaforo()
75. {
76. digitalWrite(LedSemaforoRosso, LOW);
77. digitalWrite(LedSemaforoGiallo, LOW);
78. digitalWrite(LedSemaforoVerde, HIGH);
79. ledWrosso.off();
80. ledWgiallo.off();
81. ledWverde.on();
82. luceRossaAttivata = false;
83. luceGiallaAttivata = false;
84. luceVerdeAttivata = true;
85. }
86. void lampeggio(int numeroLampeggi)
87. {
88.
89. for (int i=0; i <= numeroLampeggi; i++)
90. {
91. digitalWrite(ComandoRele, LOW); //Low = ON
92. delay(200);
93. digitalWrite(ComandoRele, HIGH); //Low = OFF
94. delay(200);
95. }
96. }
97. void clockDisplay() //ogni 10 secondi
98. {
99. Serial.println("-- 10 sec. --------------------");
100. if (contaSecondiLuceAccesa <10000) {contaSecondiLuceAccesa += 10;}
101. if (contaSecondiPresenzaRilevata <15000) {contaSecondiPresenzaRilevata += 10;}
102. if (contaSecondiLuceAccesaMax <10000) {contaSecondiLuceAccesaMax += 10;}
103.
104. Blynk.virtualWrite(V3, contaSecondiPresenzaRilevata/60);
105. }
106. void setup()
107. {
108. Blynk.begin(auth);
109. Serial.begin(9600);
110. Serial.println( "Inizia SETUP");
111.
112. // ----------- ATTIVA ETHERNET E VERIFICA LA CONNESSIONE ---------------
113. if (Ethernet.begin(mac) == 0)
114. {
115. Serial.println("Failed to configure Ethernet using DHCP");
116. Ethernet.begin(mac, ip);
117. }
118. // give the Ethernet shield a second to initialize:
119. delay(1000);
120. Serial.println("connecting...");
121.
122. // if you get a connection, report back via serial:
123. if (client.connect(server, 80))
124. {
125. Serial.println("connected");
126. client.println("GET /search?q=arduino HTTP/1.1");// Make a HTTP request:
127. client.println("Host: www.google.com");
128. client.println("Connection: close");
129. client.println();
130. }
131. else
132. {
133. Serial.println("connection failed"); // if you didn't get a connection to the server:
134. }
135. //------------- UDP ------------------
136. Udp.begin(localPort);
137. delay(1500);
138. Serial.println("UDP started");
139.
140. //-------------------- prendi l'ora -------------------
141. setSyncInterval(10 * 60); // Sync interval in seconds (10 minutes)
142. timer.setInterval(10000L, clockDisplay);
143. //timer.setInterval(5000L, TimerCinqueSecondi);
144.
145. pinMode(LedSemaforoRosso, OUTPUT);
146. pinMode(LedSemaforoGiallo, OUTPUT);
147. pinMode(LedSemaforoVerde, OUTPUT);
148. pinMode(ComandoRele, OUTPUT);
149. digitalWrite(ComandoRele, HIGH);
150. pinMode(ConsensoPLC, INPUT);
151. pinMode(SensorePresenza, INPUT);
152. Serial.println("Setup ended");
153. }
154.
155. void loop() {
156. Serial.println("Berfor Blynk ok");
157. Blynk.run();
158. Serial.println("After Blynk ok");
159. timer.run();
160. Presenza = digitalRead(SensorePresenza);
161. Consenso = digitalRead(ConsensoPLC);
162. if(BttBlinkflash == HIGH) { lampeggio(3); }
163. //----------------------------------- DISATTIVA SENSORE ---------------------------------
164. if(BttBlinkDisattivaSensore == HIGH && SensorePresenzaDisattivato == false)
165. {
166. Blynk.setProperty(V4, "color", BLYNK_RED);
167. BttBlinkDisattivaSensore = LOW;
168. SensorePresenzaDisattivato = true;
169. delay(3000);
170. }
171. if(BttBlinkDisattivaSensore == HIGH && SensorePresenzaDisattivato == true)
172. {
173. Blynk.setProperty(V4, "color", BLYNK_GREEN);
174. BttBlinkDisattivaSensore = LOW;
175. SensorePresenzaDisattivato = false;
176. delay(3000);
177. }
178. //----------------------------------- COMANDO MANUALE PLC ---------------------------------
179. if (Consenso == HIGH && StatoLuceManualePLC == false) //se la luce è spenta la accende
180. {
181. delay(1000);
182. digitalWrite(ComandoRele, LOW); //Low = ON
183. contaSecondiLuceAccesaMax=0;
184. Serial.println("Comando PLC manuale ON");
185. StatoLuceManualePLC = true;
186. Consenso = LOW;
187. }
188.
189. if (Consenso == HIGH && StatoLuceManualePLC == true) //se la luce è accesa la spegne
190. {
191. delay(1000);
192. digitalWrite(ComandoRele, HIGH); //High = OFF
193. contaSecondiLuceAccesaMax=10000;
194. Serial.println("Comando PLC manuale OFF");
195. StatoLuceManualePLC = false;
196. Consenso = HIGH;
197. }
198. //----------------------------------- COMANDO MANUALE BLYNK ---------------------------------
199. if (BttBlynkLuci == HIGH && StatoLuceManualeBlynk == false)
200. {
201. delay(1000);
202. digitalWrite(ComandoRele, LOW); //Low = ON
203. contaSecondiLuceAccesaMax=0;
204. Serial.println("Comando Blynk manuale ON");
205. Blynk.setProperty(V0, "color", BLYNK_YELLOW);
206. StatoLuceManualeBlynk = true;
207. }
208. if (BttBlynkLuci == LOW && StatoLuceManualeBlynk == true)
209. {
210. delay(1000);
211. digitalWrite(ComandoRele, HIGH); //High = OFF
212. contaSecondiLuceAccesaMax=10000;
213. Serial.println("Comando Blynk manuale OFF");
214. Blynk.setProperty(V0, "color", BLYNK_DARK_BLUE);
215. StatoLuceManualeBlynk = false;
216. }
217.
218. if(contaSecondiLuceAccesaMax > 1600 && contaSecondiLuceAccesaMax < 9999) //se la luce è accesa da più di 10 min(600) la spegne
219. {
220. digitalWrite(ComandoRele, HIGH);//High = OFF
221. contaSecondiLuceAccesaMax=10000;
222. Blynk.setProperty(V0, "color", BLYNK_DARK_BLUE);
223. Blynk.virtualWrite(V0, LOW);
224.
225. }
226. //------------------------------------- DA SENSORE --------------------------------------
227.
228. if (Presenza == HIGH && SensorePresenzaDisattivato == false)
229. {
230. //Serial.println(BttBlinkAntifurto);
231. contaSecondiPresenzaRilevata=0;
232. if(hour() < 7 || hour() > 16)
233. {
234. digitalWrite(ComandoRele, LOW);//Low = ON
235. contaSecondiLuceAccesa=0;
236. }
237.
238. if(BttBlinkAntifurto == 1 )
239. {
240. Blynk.notify("Rilevata presenza");
241. }
242. delay(10000);
243. }
244.
245. if (contaSecondiLuceAccesa > 120 && contaSecondiLuceAccesa < 300 && contaSecondiLuceAccesaMax > 600)
246. {
247. digitalWrite(ComandoRele, HIGH); //High = OFF
248. contaSecondiLuceAccesa = 10000;
249. }
250.
251. //------------------------------------- GESTIONE SEMAFORO --------------------------------------
252. if (contaSecondiPresenzaRilevata > 1 && contaSecondiPresenzaRilevata < 50 && luceRossaAttivata == false) //il semaforo parte con il rosso
253. {
254. luceRossaAttivata = true;
255. luceGiallaAttivata = false;
256. luceVerdeAttivata = false;
257. digitalWrite(LedSemaforoRosso, HIGH);
258. digitalWrite(LedSemaforoGiallo, LOW);
259. digitalWrite(LedSemaforoVerde, LOW);
260. ledWrosso.on();
261. ledWgiallo.off();
262. ledWverde.off();
263. }
264.
265. if(contaSecondiPresenzaRilevata > 1800 && contaSecondiPresenzaRilevata < 1900 && luceGiallaAttivata == false) // dopo 30 minuti diventa giallo
266. {
267.
268. luceRossaAttivata = false;
269. luceGiallaAttivata = true;
270. luceVerdeAttivata = false;
271. digitalWrite(LedSemaforoRosso, LOW);
272. digitalWrite(LedSemaforoGiallo, HIGH);
273. digitalWrite(LedSemaforoVerde, LOW);
274. ledWrosso.off();
275. ledWgiallo.on();
276. ledWverde.off();
277. }
278.
279. if(contaSecondiPresenzaRilevata > 14400 && luceVerdeAttivata == false) //dopo 4 ore diventa verde
280. {
281. contaSecondiPresenzaRilevata = 15000;
282. luceRossaAttivata = false;
283. luceGiallaAttivata = false;
284. luceVerdeAttivata = true;
285. AzzeraSemaforo();
286.
287. }
288. }
