Two way communication is failed between Blynk App. and Arduino
Hi? I’m very novice user for Blynk.
Now I’m trying to receive data from Arduino and to control Arduino using Blynk via Ethernet.
Currently, receiving data from Arduino is a OK. (The value from the sensor(CDS) is displayed on Value Display well). Unfortunately, adding a button to the Blynk App and turning on/off the LED via pushing button doesn’t work. LED is connected on Digital Pin and Button is also mapped on Digital Pin. I couldn’t understand that why two-way communicate is failed, what can I check first? Any clues are very helpful for me.
    Social networks:            http://www.fb.com/blynkapp
                                http://twitter.com/blynk_app
  This example shows how to configure static IP with Ethernet.
  Be sure to check ordinary Ethernet example first!!!
  NOTE: Pins 10, 11, 12 and 13 are reserved for Ethernet module.
        DON'T use them in your sketch directly!
  WARNING: If you have an SD card, you may need to disable it
        by setting pin 4 to HIGH. Read more here:
        https://www.arduino.cc/en/Main/ArduinoEthernetShield
#include <Ethernet.h>
char auth[] = "////";
IPAddress server_ip (10, 0, 0, 10);
// Mac address should be different for each device in your LAN
byte arduino_mac[] = { ////////// };
IPAddress arduino_ip ( /// );
IPAddress dns_ip     ( /// );
IPAddress gateway_ip ( /// );
IPAddress subnet_mask(255, 255, 255,   0);
#define W5100_CS  10
#define SDCARD_CS 4
int CDS=0;
  pinMode(SDCARD_CS, OUTPUT);
  digitalWrite(SDCARD_CS, HIGH); // Deselect the SD card
  //Blynk.begin(auth, server_ip, 8080, arduino_ip, dns_ip, gateway_ip, subnet_mask, arduino_mac);
  // Or like this:
  Blynk.begin(auth, "blynk-cloud.com", 80, arduino_ip, dns_ip, gateway_ip, subnet_mask, arduino_mac);
  CDS = analogRead(A1);
  //Serial.println(CDS);
  Blynk.virtualWrite(V1, CDS);
You shouldn’t have virtual write commands in the void loop() trying to run running thousands of times a second.
Recommended reading…
And basically all the other documentation made available
Thank you very much for your help.
First, I try to clean the code in the loop by using the Timer.
and I added BLYNK_WRITE code as below, but BLYNK_WRITE does not seem to be tiggered.
It is very difficult for me to find out what is the problem.
char auth[] = "///";
byte arduino_mac[] = { /// };
IPAddress arduino_ip ( ///);
IPAddress dns_ip     ( ///);
IPAddress gateway_ip ( ///);
#define W5100_CS  10
#define SDCARD_CS 4
int CDS=0;
BlynkTimer timer; // Announcing the timer
BLYNK_CONNECTED() {
  Blynk.syncVirtual(V9);
  Serial.println("CONNEDTED");
BLYNK_WRITE(V9) {
Serial.println("BLYNK_WRITE"); // never go into here (except firt connection)
  int buttonState = param.asInt();
  digitalWrite(8, buttonState);
  Serial.println(buttonState);
  // Or like this:
  pinMode(8, OUTPUT);
  timer.setInterval(1000L, sensorDataSend); //timer will run every sec
void sensorDataSend()
Are you at least getting the expected value on the serial print? If not look in the analog read direction, if so what are you seeing on whatever widget you have on V1… and is it set to PUSH?
I deleted the device information that was tested at the beginning, except only one Arduino(Ethernet) , and tested it with the same code, and everything works well.
  • Continuously display data received from the sensor on Blynk App
  • Turn on / off the LED of Arduino via pushing button on Blynk App
But it still is not clear what the cause was.
Anyway, it was very helpful to share your insight and information.
