Hello fellow Blynkers
I’m working on a project with two small solenoids that is packed in a wodden box and hitting the sides, making a metronome like sound.
I want to have two sliders and an on/off button in my control panel on my phone. I want one of the sliders to control the delay between the triggers(100-1000 ms) , and the other slider to control the HIGH of them (1-5 ms)
I want the solenoids to shift between them, so it’s going to go like this:
- Solenoid 1 HIGH for X ms
- Solenoid 1 LOW for Y ms
- Solenoid 2 HIGH for X ms
- Solenoid 2 LOW for Y ms
I’ve managed to do so in a similar project using delay, but I’ve figured out that’s a nogo with Blynk, so I’ve tried out this strobe example using SimpleTimer, but the problem is that it’s only one slider, and the on/off time is the same.
Any advice and solutions would be greatly appricated! Also note right now I’m just using LEDs for testing purposes, since i dont want to burn solenoids
Heres my code so far:
SimpleTimer timerSlag;
char auth[] = "****";
#define LED_PIN D1
int t1;
WiFi.persistent(false);
Blynk.begin(auth, "XXXX", "XXXX");
Serial.println("setup done! Script is running...");
BLYNK_WRITE(1)
if (param[0].asInt()) {
timer.enable(t1);
timer.disable(t1);
digitalWrite(LED_PIN, LOW);
// Toggle LED
void ledBlynk()
digitalWrite(LED_PIN, !digitalRead(LED_PIN));
// Change blink interval using virtual pin 2
BLYNK_WRITE(2)
int interval = param[0].asInt();
boolean wasEnabled = timer.isEnabled(t1);
timer.deleteTimer(t1);
t1 = timer.setInterval(interval, ledBlynk);
if (!wasEnabled) {
timer.disable(t1);
Thanks in advance!
