Two issues
I used an arduino mkr nb 1500 and worked on platform.io.
Currently I found 2 problems
Firstly, in version 1.3.0 of the blynk library, when I write a double type variable to blynk.virtualwrite, I get an error code during compilation.
The second is that LTE communication is disconnected after about 2 hours.
I used serial.println to find where it stops and it seems to be blynk.run().
{ serial.println
  GPIO_init();
  digitalWrite(17, HIGH);
  Wire.begin(); // Start I2C communication
  Wire.setClock(3400000UL);
  setupMPU(); // Set up MPU6050
  getMeasurement();
  Blynk.begin(BLYNK_AUTH_TOKEN, nbAccess, gprs, client, pin, "sgp1.blynk.cloud");
  timer.setInterval(60000L, Timer1);
  timer.setInterval(500L, Timer2);
{ timer.getMeasurement(); }
  getMeasurement();
  if (Blynk.connected())
    Serial.println("Lost connection");
    MODEM.hardReset();
    NVIC_SystemReset();
  Serial.println(F("blynk.run"));
Your full sketch would be more useful than a snippet, and an example of the first issue and compiler error message would also help.
@PeteKnight
Iโ€™ll give you a full sketch first.
The most important issue is getting stuck in the infinite loop of the blynk.run function.
#include <Arduino.h>
#include <Wire.h>  // I2C ํ†ต์‹ ๊ณผ ๊ด€๋ จ๋œ ๋ผ์ด๋ธŒ๋Ÿฌ๋ฆฌ
#include <MKRNB.h> // MKR NB ๋ณด๋“œ์™€ ๊ด€๋ จ๋œ ๋ผ์ด๋ธŒ๋Ÿฌ๋ฆฌ
// Blynk ์žฅ์น˜ ID
#define DEVICE_ID 2
// Blynk ์„ค์ •
#define BLYNK_TEMPLATE_ID "TMPL6lM3nJxMN"
#define BLYNK_TEMPLATE_NAME "Expansion Joint"
const char *BLYNK_AUTH_TOKENS[] = {
    "DlcXosJtli9mCLRVaUpZmC86vM_9Z4Qk",
    "F0X8EnEl6ZDZ9jGttffSPj9kOGFYkGVU"};
#define BLYNK_AUTH_TOKEN (BLYNK_AUTH_TOKENS[DEVICE_ID])
#include <BlynkSimpleMKRNB.h> // MKR NB ๋ณด๋“œ์šฉ Blynk ๋ผ์ด๋ธŒ๋Ÿฌ๋ฆฌ
// MKR NB ์ดˆ๊ธฐํ™”
NBClient client;
GPRS gprs;
NB nbAccess;
char pin[] = "0000";
/*  GPIO
ํฌํŠธ ํ•€ ๊ตฌ์„ฑ
์•„๋‘์ด๋…ธ ํฌํŠธ ํ•€ ๊ธฐ๋Šฅ: pinMode(), digitalRead() ๋ฐ digitalWrite()๋Š” ๊ธฐ๋ณธ์ ์œผ๋กœ ์–ด์จŒ๋“  ์ด ์ž‘์—…์„ ์ˆ˜ํ–‰ํ•ฉ๋‹ˆ๋‹ค.
digitalRead() ๋ฐ digitalWrite()์— ๋น„ํ•ด ์ง์ ‘ ๋ ˆ์ง€์Šคํ„ฐ ์กฐ์ž‘์„ ์‚ฌ์šฉํ•˜๋ฉด ์•ฝ๊ฐ„์˜ ์„ฑ๋Šฅ ์ด์ ๋งŒ ์žˆ์Šต๋‹ˆ๋‹ค.
ํฌํŠธ ํ•€ ์ž…๋ ฅ
ํŠน์ • ํฌํŠธ ํ•€์„ ์ž…๋ ฅ์œผ๋กœ ์„ค์ •ํ•˜๋ ค๋ฉด:
PORT->Group[PORTA].PINCFG[19].bit.INEN = 1;  // Enable PA19 input
PORT->Group[PORTA].PINCFG[19].bit.PULLEN = 0;
PORT->Group[PORTA].DIRCLR.reg = PORT_PA19;
ํ’€์—… ์ €ํ•ญ์œผ๋กœ ์ž…๋ ฅ์„ ํ™œ์„ฑํ™”ํ•˜๋ ค๋ฉด:
PORT->Group[PORTA].PINCFG[19].bit.INEN = 1;  // Enable PA19 input with a pull-up resistor
PORT->Group[PORTA].PINCFG[19].bit.PULLEN = 1;
PORT->Group[PORTA].OUTSET.reg = PORT_PA19;
ํ’€๋‹ค์šด ์ €ํ•ญ์œผ๋กœ ์ž…๋ ฅ์„ ํ™œ์„ฑํ™”ํ•˜๋ ค๋ฉด:
PORT->Group[PORTA].PINCFG[19].bit.INEN = 1;  // Enable PA19 input with a pull-down resistor
PORT->Group[PORTA].OUTCLR.reg = PORT_PA19;
์ž…๋ ฅ์„ ์ฝ์œผ๋ ค๋ฉด:
if (PORT->Group[PORTA].IN.reg & PORT_PA19)  // Read the input pin on PA19
ํฌํŠธ ํ•€ ์ถœ๋ ฅ
ํŠน์ • ํฌํŠธ ํ•€์„ ์ถœ๋ ฅ์œผ๋กœ ์„ค์ •ํ•˜๋ ค๋ฉด:
PORT->Group[PORTA].DIRSET.reg = PORT_PA19;  // Set PA19 to an output
PORT->Group[PORTA].PINCFG[19].bit.INEN = 1;  // Support output read back
์ถœ๋ ฅ์„ ๋†’๊ฒŒ ์„ค์ •ํ•˜๋ ค๋ฉด:
PORT->Group[PORTA].OUTSET.reg = PORT_PA19;  // Set PA19 output HIGH
์ถœ๋ ฅ์„ ๋‚ฎ๊ฒŒ ์„ค์ •ํ•˜๋ ค๋ฉด:
PORT->Group[PORTA].OUTCLR.reg = PORT_PA19;  // Set PA19 output LOW
Arduino-ํฌํŠธ ํ•€ ๋งคํ•‘
์˜ˆ๋ฅผ ๋“ค์–ด ๋””์ง€ํ„ธ ํ•€ D12์˜ ๊ฒฝ์šฐ Arduino "g_APinDescription" ๊ตฌ์กฐ๋ฅผ ์‚ฌ์šฉํ•˜์—ฌ Arduino ํ•€ ๋ฒˆํ˜ธ์—์„œ ํฌํŠธ ํ•€์œผ๋กœ ๋งคํ•‘ํ•˜๋Š” ๊ฒƒ๋„ ๊ฐ€๋Šฅํ•ฉ๋‹ˆ๋‹ค.
PORT->Group[g_APinDescription[12].ulPort].PINCFG[g_APinDescription[12].ulPin].bit.INEN = 1;
void GPIO_init()
  pinMode(17, OUTPUT);
  analogReadResolution(12);
  // analogReference(AR_DEFAULT) = Set the analogue input threshold to 3.3V
  ADC->INPUTCTRL.bit.GAIN = ADC_INPUTCTRL_GAIN_DIV2_Val;
  ADC->REFCTRL.bit.REFSEL = ADC_REFCTRL_REFSEL_INTVCC1_Val;
  // pinMode(A2, OUTPUT);
  PORT->Group[PORTB].DIRSET.reg = PORT_PB03;
  PORT->Group[PORTB].PINCFG[3].bit.INEN = 1;
  // pinMode(D0, INPUT);
  PORT->Group[PORTA].PINCFG[22].bit.INEN = 1;
  PORT->Group[PORTA].PINCFG[22].bit.PULLEN = 0;
  PORT->Group[PORTA].DIRCLR.reg = PORT_PA22;
  // pinMode(D1, OUTPUT);
  PORT->Group[PORTA].DIRSET.reg = PORT_PA23;
  PORT->Group[PORTA].PINCFG[23].bit.INEN = 1;
  // pinMode(D2, INPUT);
  PORT->Group[PORTA].PINCFG[10].bit.INEN = 1;
  PORT->Group[PORTA].PINCFG[10].bit.PULLEN = 0;
  PORT->Group[PORTA].DIRCLR.reg = PORT_PA10;
  // pinMode(D3, OUTPUT);
  PORT->Group[PORTA].DIRSET.reg = PORT_PA11;
  PORT->Group[PORTA].PINCFG[11].bit.INEN = 1;
  // pinMode(D4, INPUT);
  PORT->Group[PORTB].PINCFG[10].bit.INEN = 1;
  PORT->Group[PORTB].PINCFG[10].bit.PULLEN = 0;
  PORT->Group[PORTB].DIRCLR.reg = PORT_PB10;
  // pinMode(D5, OUTPUT);
  PORT->Group[PORTB].DIRSET.reg = PORT_PB11;
  PORT->Group[PORTB].PINCFG[11].bit.INEN = 1;
  // pinMode(D6, INPUT);
  PORT->Group[PORTA].PINCFG[20].bit.INEN = 1;
  PORT->Group[PORTA].PINCFG[20].bit.PULLEN = 0;
  PORT->Group[PORTA].DIRCLR.reg = PORT_PA20;
  // pinMode(D7, OUTPUT);
  PORT->Group[PORTA].DIRSET.reg = PORT_PA21;
  PORT->Group[PORTA].PINCFG[21].bit.INEN = 1;
// MPU6050 ๋ณ€์ˆ˜
float Acc_scaleFactor, Gyro_scaleFactor;
const int8_t MPU_ADDR = 0x69;
// mpuData ์ธ๋ฑ์Šค ์—ด๊ฑฐํ˜•
enum SensorIndex
  AcX,
  AcY,
  AcZ,
  Tmp,
  GyX,
  GyY,
  GyZ
// MPU6050 ๋ ˆ์ง€์Šคํ„ฐ๋ฅผ ์„ค์ •ํ•˜๋Š” ํ•จ์ˆ˜
inline void configureMPURegister(int8_t registerAddr, int8_t value)
  Wire.beginTransmission(MPU_ADDR);
  Wire.write(registerAddr);
  Wire.write(value);
  Wire.endTransmission(true);
void setupMPU()
  // MPU6050 ์ „์ฒด(4๊ฐœ) ํ™œ์„ฑํ™”
  PORT->Group[PORTA].OUTSET.reg = PORT_PA23;
  PORT->Group[PORTA].OUTSET.reg = PORT_PA11;
  PORT->Group[PORTB].OUTSET.reg = PORT_PB11;
  PORT->Group[PORTA].OUTSET.reg = PORT_PA21;
  // MPU6050 ์ดˆ๊ธฐํ™” ๋ฐ ๋ฆฌ์…‹
  configureMPURegister(0x6B, 0);    // MPU-6050 ํ™œ์„ฑํ™”
  configureMPURegister(0x6B, 0x03); // ํด๋Ÿญ ์†Œ์Šค ์„ค์ •
  /*  ๊ฐ€์†๋„๊ณ„ ์„ค์ •
    AFS_SEL=0, Full Scale Range = +/- 2 [g]
    AFS_SEL=1, Full Scale Range = +/- 4 [g]
    AFS_SEL=2, Full Scale Range = +/- 8 [g]
    AFS_SEL=3, Full Scale Range = +/- 10 [g]
  switch (0)
  case 0:
    configureMPURegister(0x1C, 0x00);
    Acc_scaleFactor = 16384;
    break;
  case 1:
    configureMPURegister(0x1C, 0x08);
    Acc_scaleFactor = 8192;
    break;
  case 2:
    configureMPURegister(0x1C, 0x10);
    Acc_scaleFactor = 4096;
    break;
  default:
    configureMPURegister(0x1C, 0x18);
    Acc_scaleFactor = 3276.8;
    break;
  // ์Šค์ผ€์ผ ํŒฉํ„ฐ๋ฅผ ์—ญ์ˆ˜๋กœ ์ทจํ•จ
  Acc_scaleFactor = 1.0 / Acc_scaleFactor;
  /*  ์ž์ด๋กœ์Šค์ฝ”ํ”„ ์„ค์ •
    FS_SEL=0, Full Scale Range = +/- 250 [degree/sec]
    FS_SEL=1, Full Scale Range = +/- 500 [degree/sec]
    FS_SEL=2, Full Scale Range = +/- 1000 [degree/sec]
    FS_SEL=3, Full Scale Range = +/- 2000 [degree/sec]
  switch (0)
  case 0:
    configureMPURegister(0x1B, 0x00);
    Gyro_scaleFactor = 1.0 / 131.0;
    break;
  case 1:
    configureMPURegister(0x1B, 0x08);
    Gyro_scaleFactor = 65.5;
    break;
  case 2:
    configureMPURegister(0x1B, 0x10);
    Gyro_scaleFactor = 32.8;
    break;
  default:
    configureMPURegister(0x1B, 0x18);
    Gyro_scaleFactor = 16.4;
    break;
  Gyro_scaleFactor = 1.0 / Gyro_scaleFactor;
  /*  DLPF ์„ค์ •
    Accel BW 260Hz, Delay    0ms / Gyro BW 256Hz, Delay 0.98ms, Fs 8KHz
    Accel BW 184Hz, Delay    2ms / Gyro BW 188Hz, Delay  1.9ms, Fs 1KHz
    Accel BW  94Hz, Delay    3ms / Gyro BW  98Hz, Delay  2.8ms, Fs 1KHz
    Accel BW  44Hz, Delay  4.9ms / Gyro BW  42Hz, Delay  4.8ms, Fs 1KHz
    Accel BW  21Hz, Delay  8.5ms / Gyro BW  20Hz, Delay  8.3ms, Fs 1KHz
    Accel BW  10Hz, Delay 13.8ms / Gyro BW  10Hz, Delay 13.4ms, Fs 1KHz
    Accel BW   5Hz, Delay   19ms / Gyro BW   5Hz, Delay 18.6ms, Fs 1KHz
  configureMPURegister(0x1A, 6);
  // MPU6050 ์ „์ฒด(4๊ฐœ) ๋น„ํ™œ์„ฑํ™”
  PORT->Group[PORTA].OUTCLR.reg = PORT_PA23;
  PORT->Group[PORTA].OUTCLR.reg = PORT_PA11;
  PORT->Group[PORTB].OUTCLR.reg = PORT_PB11;
  PORT->Group[PORTA].OUTCLR.reg = PORT_PA21;
// ๋ฐฐ์—ด ํฌ๊ธฐ ์ˆ˜์ •์š”ํ•จ (ํƒ€์ž…, ํฌ๊ธฐ)
int16_t mpuData[4][7];      // [0,1,2,3][AcX, AcY, AcZ, Tmp, GyX, GyY, GyZ] ์ˆœ์œผ๋กœ ์ €์žฅ
int32_t mpuData_prev[4][3]; // [num][data]
const uint8_t MPU_portGroup[4] = {0, 0, 1, 0};
const uint32_t MPU_writePin[4] = {1ul << 23, 1ul << 11, 1ul << 11, 1ul << 21};
const uint32_t MPU_readPin[4] = {1ul << 22, 1ul << 10, 1ul << 10, 1ul << 20};
// MPU6050์—์„œ ๋ฐ์ดํ„ฐ ์ฝ๊ธฐ
inline void readMPU(uint8_t MPU_num)
  // Data Backup
  mpuData_prev[MPU_num][AcX] = mpuData[MPU_num][AcX];
  mpuData_prev[MPU_num][AcY] = mpuData[MPU_num][AcY];
  mpuData_prev[MPU_num][AcZ] = mpuData[MPU_num][AcZ];
  // ํ•ด๋‹น ํ•€์ด ํ™œ์„ฑํ™”๋˜์–ด ์žˆ์œผ๋ฉด, ๋ฌด์‹œ
  if (PORT->Group[MPU_portGroup[MPU_num]].IN.reg & MPU_readPin[MPU_num])
    return;
  // ํ•ด๋‹น ํ•€์ด ๋น„ํ™œ์„ฑํ™”๋˜์–ด ์žˆ์œผ๋ฉด, MPU ํ™œ์„ฑํ™”
    PORT->Group[MPU_portGroup[MPU_num]].OUTSET.reg = MPU_writePin[MPU_num];
  // ๋ฐ์ดํ„ฐ ์ฝ๊ธฐ
  Wire.write(0x3B);
  Wire.endTransmission(false);
  // ๊ฐ€์†๋„ ๋ฐ์ดํ„ฐ๋งŒ ํ˜ธ์ถœ
  Wire.requestFrom(MPU_ADDR, 6, true); // 2byte * 3
  mpuData[MPU_num][AcX] = (Wire.read() << 8 | Wire.read());
  mpuData[MPU_num][AcY] = (Wire.read() << 8 | Wire.read());
  mpuData[MPU_num][AcZ] = (Wire.read() << 8 | Wire.read());
  // MPU ๋น„ํ™œ์„ฑํ™”
  PORT->Group[MPU_portGroup[MPU_num]].OUTCLR.reg = MPU_writePin[MPU_num];
double accData[4] = {0.0, 0.0, 0.0, 0.0};
uint32_t soundData = 0;
inline void getMeasurement()
  // ์†Œ์Œ ์ธก์ •
  uint32_t soundValue = analogRead(A0);
  if (soundData < soundValue)
    soundData = soundValue;
  // ์ง„๋™ ์ธก์ •
  uint32_t axisValue;
  double axisValue_double;
  for (int i = 0; i < 4; i++)
    readMPU(i);
    axisValue = abs(mpuData[i][AcX] - mpuData_prev[i][AcX]);
    axisValue += abs(mpuData[i][AcY] - mpuData_prev[i][AcY]);
    axisValue += abs(mpuData[i][AcZ] - mpuData_prev[i][AcZ]);
    axisValue_double = (axisValue)*Acc_scaleFactor;
    if (accData[i] < axisValue_double)
      accData[i] = axisValue_double;
  Blynk data type
  Type     MIN             MAX
  Integer  -2,147,483,648  2,147,483,647
  Double   -1.8 x 10^300   4.9 x 10^-324
  String   any value is accepted
uint32_t updateCount = 0;
void Timer1()
  Blynk.virtualWrite(0, accData[0]);
  Blynk.virtualWrite(1, accData[1]);
  Blynk.virtualWrite(2, accData[2]);
  Blynk.virtualWrite(3, accData[3]);
  Blynk.virtualWrite(4, soundData);
  memset(accData, 0, sizeof(accData)), soundData = 0;
  Serial.print(F("Updating data - ")), Serial.println(++updateCount);
bool led_state = false;
void Timer2()
  digitalWrite(17, led_state);
  if (led_state)
    led_state = false;
    led_state = true;
  GPIO_init();
  Wire.begin(); // I2C ํ†ต์‹  ์‹œ์ž‘
  setupMPU(); // MPU6050 ์„ค์ •
  getMeasurement();
  getMeasurement();
    MODEM.hardReset();
    NVIC_SystemReset();
Well, first of all this code wonโ€™t compile under Blynk 1/3.0 because these two lines arent at the very top of your sketchโ€ฆ
You should be calling getMeasurement(); from your void loop and personally I wouldnโ€™t do an if (Blynk.connected()) test in your void loop if youโ€™re using Blynk.begin().
Youโ€™re also doing some other strange stuff, like calling Blynk.run in void setup.
[Screenshot removed by moderator]
Thatโ€™s right. It wonโ€™t compile in version 1.3.0, but I did get a compile error code back that said it was a problem with a double-type variable, not a positional problem in the code you mentioned.
And did you happen to try running it on version 1.2.0?
So, how do I make sure this system is connected to the network properly?
This is because the getMeasurement function needs to perform as many iterations as possible in as little time as possible on the MCU.
Iโ€™m not sure what your screenshot is meant to show, but Iโ€™d suggest that you copy/paste the relevant text and post it with triple backticks at the beginning and end.
The error message relating to the positioning of the Template Name and ID will be:
#error "Please specify your BLYNK_TEMPLATE_ID and BLYNK_TEMPLATE_NAME
Youโ€™ve mentioned this twice, but havenโ€™t shared the code that creates the compiler error message, or the details of the message itself.
That sounds like itโ€™s not compatible with Blynk then.
Will this illustration help you solve it?
In the code I sent you, the location of the #define is the original, unaltered code.
Can you suggest another way to do this?
No, but if you edit your post, delete the screenshot and post the relevant piece of code and the text of the compiler error message (both with triple backticks) then Iโ€™ll take a look at it.
Remove getMeasurement(); from your void loop and call it with a BlynkTimer.
If you want something other than whatโ€™s below, youโ€™ll need to tell us how to make it appearโ€ฆ
Processing mkrnb1500 (platform: atmelsam; board: mkrnb1500; framework: arduino)
Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/atmelsam/mkrnb1500.html
PLATFORM: Atmel SAM (8.1.0) > Arduino MKR NB 1500
HARDWARE: SAMD21G18A 48MHz, 32KB RAM, 256KB Flash
DEBUG: Current (atmel-ice) External (atmel-ice, blackmagic, jlink)
PACKAGES:
 - framework-arduino-samd @ 1.8.13
 - framework-cmsis @ 1.40500.0 (4.5.0)
 - framework-cmsis-atmel @ 1.2.2
 - toolchain-gccarmnoneeabi @ 1.70201.0 (7.2.1)
LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
LDF Modes: Finder ~ chain, Compatibility ~ soft
Found 17 compatible libraries
Scanning dependencies...
Dependency Graph
|-- Blynk @ 1.3.0
|-- MKRNB @ 1.5.1
|-- Wire @ 1.0
Building in release mode
Compiling .pio\build\mkrnb1500\src\main.cpp.o
Compiling .pio\build\mkrnb1500\lib74b\BlynkNcpDriver\BlynkRpcCRC8.c.o
Compiling .pio\build\mkrnb1500\lib74b\BlynkNcpDriver\BlynkRpcClientWeakImpl.c.o
Compiling .pio\build\mkrnb1500\lib74b\BlynkNcpDriver\BlynkRpcInfra.c.o
Compiling .pio\build\mkrnb1500\lib74b\BlynkNcpDriver\BlynkRpcInfraUart.c.o
Compiling .pio\build\mkrnb1500\lib74b\BlynkNcpDriver\BlynkRpcUartFraming.c.o
Compiling .pio\build\mkrnb1500\lib74b\BlynkNcpDriver\MessageBuffer.c.o
Compiling .pio\build\mkrnb1500\lib74b\BlynkNcpDriver\MessageWriter.c.o
Compiling .pio\build\mkrnb1500\libc78\MKRNB-1.5.1\GPRS.cpp.o
Compiling .pio\build\mkrnb1500\libc78\MKRNB-1.5.1\Modem.cpp.o
Compiling .pio\build\mkrnb1500\libc78\MKRNB-1.5.1\NB.cpp.o
Compiling .pio\build\mkrnb1500\libc78\MKRNB-1.5.1\NBClient.cpp.o
Compiling .pio\build\mkrnb1500\libc78\MKRNB-1.5.1\NBFileUtils.cpp.o
Compiling .pio\build\mkrnb1500\libc78\MKRNB-1.5.1\NBModem.cpp.o
Archiving .pio\build\mkrnb1500\lib74b\libBlynkNcpDriver.a
Compiling .pio\build\mkrnb1500\libc78\MKRNB-1.5.1\NBPIN.cpp.o
lib\MKRNB-1.5.1\src\NBFileUtils.cpp: In member function 'uint32_t NBFileUtils::downloadFile(arduino::String, const char*, uint32_t, bool)':
lib\MKRNB-1.5.1\src\NBFileUtils.cpp:117:28: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
         for (auto i = 0; i < size; i++) {
lib\MKRNB-1.5.1\src\NBFileUtils.cpp: In member function 'uint32_t NBFileUtils::readFile(arduino::String, arduino::String*)':
lib\MKRNB-1.5.1\src\NBFileUtils.cpp:179:24: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
lib\MKRNB-1.5.1\src\NBFileUtils.cpp: In member function 'uint32_t NBFileUtils::readFile(arduino::String, uint8_t*)':
lib\MKRNB-1.5.1\src\NBFileUtils.cpp:226:24: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
lib\MKRNB-1.5.1\src\NBFileUtils.cpp: In member function 'uint32_t NBFileUtils::readBlock(arduino::String, uint32_t, uint32_t, uint8_t*)':
lib\MKRNB-1.5.1\src\NBFileUtils.cpp:273:24: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
lib\MKRNB-1.5.1\src\NBFileUtils.cpp: In member function 'int NBFileUtils::deleteFiles()':
lib\MKRNB-1.5.1\src\NBFileUtils.cpp:316:9: warning: unused variable 'num' [-Wunused-variable]
     int num = listFiles(files);
Compiling .pio\build\mkrnb1500\libc78\MKRNB-1.5.1\NBSSLClient.cpp.o
Compiling .pio\build\mkrnb1500\libc78\MKRNB-1.5.1\NBScanner.cpp.o
Compiling .pio\build\mkrnb1500\libc78\MKRNB-1.5.1\NBUdp.cpp.o
Compiling .pio\build\mkrnb1500\libc78\MKRNB-1.5.1\NB_SMS.cpp.o
Compiling .pio\build\mkrnb1500\libc78\MKRNB-1.5.1\utility\NBSocketBuffer.cpp.o
Compiling .pio\build\mkrnb1500\lib25a\Blynk\utility\BlynkDebug.cpp.o
Compiling .pio\build\mkrnb1500\lib25a\Blynk\utility\BlynkHandlers.cpp.o
Compiling .pio\build\mkrnb1500\lib25a\Blynk\utility\BlynkHelpers.cpp.o
Compiling .pio\build\mkrnb1500\lib25a\Blynk\utility\BlynkTimeUtils.cpp.o
Compiling .pio\build\mkrnb1500\lib25a\Blynk\utility\BlynkTimer.cpp.o
Compiling .pio\build\mkrnb1500\lib25a\Blynk\utility\utility.cpp.o
Compiling .pio\build\mkrnb1500\libe79\Wire\Wire.cpp.o
Archiving .pio\build\mkrnb1500\libc78\libMKRNB-1.5.1.a
Compiling .pio\build\mkrnb1500\FrameworkArduinoVariant\variant.cpp.o
Compiling .pio\build\mkrnb1500\FrameworkArduino\Reset.cpp.o
Compiling .pio\build\mkrnb1500\FrameworkArduino\SERCOM.cpp.o
Compiling .pio\build\mkrnb1500\FrameworkArduino\Tone.cpp.o
Compiling .pio\build\mkrnb1500\FrameworkArduino\USB\CDC.cpp.o
Archiving .pio\build\mkrnb1500\libe79\libWire.a
Compiling .pio\build\mkrnb1500\FrameworkArduino\USB\USBCore.cpp.o
Archiving .pio\build\mkrnb1500\lib25a\libBlynk.a
Compiling .pio\build\mkrnb1500\FrameworkArduino\USB\samd21_host.c.o
Archiving .pio\build\mkrnb1500\libFrameworkArduinoVariant.a
Compiling .pio\build\mkrnb1500\FrameworkArduino\Uart.cpp.o
Compiling .pio\build\mkrnb1500\FrameworkArduino\WInterrupts.c.o
Compiling .pio\build\mkrnb1500\FrameworkArduino\WMath.cpp.o
Compiling .pio\build\mkrnb1500\FrameworkArduino\abi.cpp.o
Compiling .pio\build\mkrnb1500\FrameworkArduino\api\Common.cpp.o
Compiling .pio\build\mkrnb1500\FrameworkArduino\api\IPAddress.cpp.o
Compiling .pio\build\mkrnb1500\FrameworkArduino\api\PluggableUSB.cpp.o
Compiling .pio\build\mkrnb1500\FrameworkArduino\api\Print.cpp.o
Compiling .pio\build\mkrnb1500\FrameworkArduino\api\Stream.cpp.o
Compiling .pio\build\mkrnb1500\FrameworkArduino\api\String.cpp.o
Compiling .pio\build\mkrnb1500\FrameworkArduino\compact\dtostrf.c.o
Compiling .pio\build\mkrnb1500\FrameworkArduino\cortex_handlers.c.o
Compiling .pio\build\mkrnb1500\FrameworkArduino\delay.c.o
Compiling .pio\build\mkrnb1500\FrameworkArduino\hooks.c.o
Compiling .pio\build\mkrnb1500\FrameworkArduino\itoa.c.o
Compiling .pio\build\mkrnb1500\FrameworkArduino\main.cpp.o
Compiling .pio\build\mkrnb1500\FrameworkArduino\new.cpp.o
Compiling .pio\build\mkrnb1500\FrameworkArduino\pulse.c.o
Compiling .pio\build\mkrnb1500\FrameworkArduino\pulse_asm.S.o
Compiling .pio\build\mkrnb1500\FrameworkArduino\startup.c.o
Compiling .pio\build\mkrnb1500\FrameworkArduino\wiring.c.o
Compiling .pio\build\mkrnb1500\FrameworkArduino\wiring_analog.c.o
Compiling .pio\build\mkrnb1500\FrameworkArduino\wiring_digital.c.o
Compiling .pio\build\mkrnb1500\FrameworkArduino\wiring_private.c.o
Compiling .pio\build\mkrnb1500\FrameworkArduino\wiring_shift.c.o
Archiving .pio\build\mkrnb1500\libFrameworkArduino.a
Linking .pio\build\mkrnb1500\firmware.elf
.pio\build\mkrnb1500\src\main.cpp.o: In function `void BlynkApi<BlynkProtocol<BlynkArduinoClientGen<arduino::Client> > >::virtualWrite<double>(int, double)':
main.cpp:(.text._ZN8BlynkApiI13BlynkProtocolI21BlynkArduinoClientGenIN7arduino6ClientEEEE12virtualWriteIJdEEEviDpT_[_ZN8BlynkApiI13BlynkProtocolI21BlynkArduinoClientGenIN7arduino6ClientEEEE12virtualWriteIJdEEEviDpT_]+0x38): undefined reference to `dtostrf_internal(double, signed char, unsigned char, char*)'
collect2.exe: error: ld returned 1 exit status
*** [.pio\build\mkrnb1500\firmware.elf] Error 1
================================= [FAILED] Took 4.86 seconds =================================
 *  ํ„ฐ๋ฏธ๋„ ํ”„๋กœ์„ธ์Šค "C:\Users\k3492\.platformio\penv\Scripts\platformio.exe 'run', '--environment', 'mkrnb1500'"์ด(๊ฐ€) ์ข…๋ฃŒ๋˜์—ˆ์Šต๋‹ˆ๋‹ค(์ข…๋ฃŒ ์ฝ”๋“œ: 1).
 *  ํ„ฐ๋ฏธ๋„์ด ์ž‘์—…์—์„œ ๋‹ค์‹œ ์‚ฌ์šฉ๋ฉ๋‹ˆ๋‹ค. ๋‹ซ์œผ๋ ค๋ฉด ์•„๋ฌด ํ‚ค๋‚˜ ๋ˆ„๋ฅด์„ธ์š”.
Oh, and why does the blynk.run() function keep getting stuck in an infinite loop?
I still have no idea which line of code in your sketch is making this error message appear, despite asking for it multiple times.
I also have no idea if youโ€™ve moved #define BLYNK_TEMPLATE_ID "TMPL6lM3nJxMN" and #define BLYNK_TEMPLATE_NAME "Expansion Joint" to the top of your sketch, as is required with all versions of the Blynk library except 1.2.0.
When you use Blynk.begin() itโ€™s a blocking function, which may be the cause of your issue, but youโ€™ve not really explained what the symptoms of your โ€œinfinite loopโ€ are, and what you see in your serial monitor when this happens.
And, if youโ€™re asked to EDIT an existing post, then please do that, rather than leaving the post unedited and re-posting the requested data in a new post.
We are very sorry for the hassle.
This syntax only causes problems when the variable type you are writing to is a double.
If you remove that syntax and try to write a variable of type int, there is no problem.
Yes, since you mentioned it, it has been moved to the top line of the code.
After about two hours of running in the code I sent you, the
Serial.println(F(โ€œblynk.runโ€)) the syntax doesnโ€™t print and the Arduino freezes.
The LEDs stop flashing, and the cloud connection is lost.
What is executed above that statement is blynk.begin.
What happens if you try a simple test like thisโ€ฆ
double test =  123.456;
Blynk.virtualWrite(V0, test);
Did you try what I suggested and remove this:
and replace it with Blynk.run(); ?
Have you tried moving this out of your void loopโ€ฆ
and calling it with a BlynkTimer instead?
This didnโ€™t work in 1.3.0 eitherโ€ฆ
Iโ€™m going to go with 1.2.0 for now.
Based on everything youโ€™ve said, Iโ€™ve modified the code.
The getMeasurement() function was taking about 4-5ms, so I modified the code by adding 10ms to the timer.
// Blynk ์žฅ์น˜ ID
#define DEVICE_ID 2
// Blynk ์„ค์ •
// MKR NB ์ดˆ๊ธฐํ™”
NBClient client;
GPRS gprs;
NB nbAccess;
/*  GPIO
ํฌํŠธ ํ•€ ๊ตฌ์„ฑ
ํฌํŠธ ํ•€ ์ž…๋ ฅ
ํฌํŠธ ํ•€ ์ถœ๋ ฅ
void GPIO_init()
// MPU6050 ๋ณ€์ˆ˜
enum SensorIndex
  AcX,
  AcY,
  AcZ,
  Tmp,
  GyX,
  GyY,
  GyZ
  Wire.write(value);
void setupMPU()
  switch (0)
  case 0:
break;
  case 1:
break;
  case 2:
break;
  default:
break;
  switch (0)
  case 0:
break;
  case 1:
break;
  case 2:
break;
  default:
break;
  /*  DLPF ์„ค์ •
  // Data Backup
return;
  // ๋ฐ์ดํ„ฐ ์ฝ๊ธฐ
  Wire.write(0x3B);
  // MPU ๋น„ํ™œ์„ฑํ™”
int accData_lengh = sizeof(accData);
inline void Get_measurement()
  // ์†Œ์Œ ์ธก์ •
  // ์ง„๋™ ์ธก์ •
  uint32_t axisValue;
readMPU(i);
  Blynk data type
  Type     MIN             MAX
void Cloud_update()
  memset(accData, 0, accData_lengh), soundData = 0;
void LED_blink()
  if (led_state)
led_state = false;
led_state = true;
  GPIO_init();
  Get_measurement();
  timer.setInterval(60000L, Cloud_update);
  timer.setInterval(500L, LED_blink);
  timer.setInterval(10L, Get_measurement);
MODEM.hardReset();
NVIC_SystemReset();
Iโ€™m going to leave it on for the day to see if it freezes like it did before.
hello.
Iโ€™m working on an arduino mkr nb 1500 to monitor sensor data on platform.io.
I modified the code as per your help yesterday and have been testing it for a day or so, but the arduino freezes after about 10-30 minutes.
The code is shown below.
Weโ€™ve temporarily removed the blynk-specific #define.
// Blynk ์žฅ์น˜ ID
#define DEVICE_ID 2
// Blynk ์„ค์ •
#define BLYNK_TEMPLATE_ID "="
#define BLYNK_TEMPLATE_NAME "="
// MKR NB ์ดˆ๊ธฐํ™”
NBClient client;
GPRS gprs;
NB nbAccess;
/*  GPIO
ํฌํŠธ ํ•€ ๊ตฌ์„ฑ
ํฌํŠธ ํ•€ ์ž…๋ ฅ
ํฌํŠธ ํ•€ ์ถœ๋ ฅ
void GPIO_init()
// MPU6050 ๋ณ€์ˆ˜
enum SensorIndex
  AcX,
  AcY,
  AcZ,
  Tmp,
  GyX,
  GyY,
  GyZ
  Wire.write(value);
void setupMPU()
  switch (0)
  case 0:
    break;
  case 1:
    break;
  case 2:
    break;
  default:
    break;
  switch (0)
  case 0:
    break;
  case 1:
    break;
  case 2:
    break;
  default:
    break;
  /*  DLPF ์„ค์ •
  // Data Backup
    return;
  // ๋ฐ์ดํ„ฐ ์ฝ๊ธฐ
  Wire.write(0x3B);
  // MPU ๋น„ํ™œ์„ฑํ™”
uint32_t axisValue;
  // ์†Œ์Œ ์ธก์ •
  // ์ง„๋™ ์ธก์ •
    readMPU(i);
    axisValue = abs(mpuData[i][AcX] - mpuData_prev[i][AcX]) + abs(mpuData[i][AcY] - mpuData_prev[i][AcY]) + abs(mpuData[i][AcZ] - mpuData_prev[i][AcZ]);
  Blynk data type
  Type     MIN             MAX
void Cloud_update()
void LED_blink()
  if (led_state)
    led_state = false;
    led_state = true;
  GPIO_init();
  readMPU(0), readMPU(1), readMPU(2), readMPU(3);
The monitor output looks like this
---- Opened the serial port COM3 ----
Updating data - 2
Updating data - 3
Updating data - 4
Updating data - 5
Updating data - 6
Updating data - 7
Updating data - 8
Updating data - 9
Updating data - 10
Updating data - 11
Updating data - 12
Updating data - 13
Updating data - 14
Updating data - 15
Updating data - 16
Updating data - 17
Updating data - 18
Updating data - 19
Updating data - 20
Updating data - 21
Updating data - 22
Updating data - 23
Updating data - 24
Updating data - 25
Updating data - 26
Updating data - 27
Updating data - 28
Updating data - 29
---- Closed serial port COM3 due to disconnection from the machine ----
---- Reopened serial port COM3 ----
Updating data - 1
Updating data - 2
Updating data - 3
Updating data - 4
Updating data - 5
Updating data - 6
Updating data - 7
Updating data - 1
Updating data - 2
Updating data - 3
Updating data - 4
Updating data - 5
Updating data - 6
Updating data - 7
Updating data - 8
Updating data - 9
Updating data - 10
Updating data - 11
Updating data - 12
Updating data - 13
Updating data - 14
Updating data - 15
Updating data - 16
Updating data - 17
Updating data - 18
Updating data - 19
Updating data - 20
Updating data - 21
Updating data - 22
Updating data - 23
Updating data - 24
Updating data - 25
Updating data - 26
Updating data - 27
Updating data - 28
Updating data - 29
    Updating data - 1
    Updating data - 2
    Updating data - 3
    Updating data - 4
    Updating data - 5
    Updating data - 6
    Updating data - 7
    Updating data - 8
    Updating data - 9
    Updating data - 10
    Updating data - 11
    Updating data - 12
    Updating data - 13
    Updating data - 14
    Updating data - 15
    Updating data - 16
    Updating data - 17
    Updating data - 18
    Updating data - 19
    Updating data - 20
    Updating data - 21
Iโ€™ve done some testing and it seems that the blynk.run function gets stuck in an infinite loop.
Iโ€™m using lte cat.m1, what could be the problem?
@junsang Iโ€™ve moved your latest post into this topic, as itโ€™s about the same subject.
Please donโ€™t create new topics about the same thing, it makes it much harder for community members to follow the conversation thread.
What exactly does this mean?
Why have you moved your Template ID and Template Name so that they are no longer at the top of your sketch?
Have you tried testing using a far simpler sketch, to see if that helps with your connectivity issues?
Suddenly, it occurred to me that someone might use my token, so I did.
It is only temporarily hidden before uploading the post
I tried very simply using blynk.begin and blynk.run and uploading random numbers to the cloud with a timer, but the connection was lost.
I tried to install the sensor, but my Arduino frequently got stuck in an infinite loop and lost connection to the cloud, so I added an MCU to reboot the RST pin.
However, I think this is very inefficient in many ways.
So youโ€™ve redacted some of your sensitive data.
Personally, I tend to do thisโ€ฆ
#define BLYNK_TEMPLATE_ID "REDACTED"
#define BLYNK_TEMPLATE_NAME "REDACTED"
#define BLYNK_AUTH_TOKEN "REDACTED"
It would make sense to post that sketch, and use it for the basis of future tests.
The code below.
With this code, it worked for a bit longer and then broke.
About an hour or two?
// Blynk ์žฅ์น˜ ID
#define DEVICE_ID 2
// Blynk ์„ค์ •
// MKR NB ์ดˆ๊ธฐํ™”
NBClient client;
GPRS gprs;
NB nbAccess;
void Cloud_update()
    long randNumber = random(300);
    Blynk.virtualWrite(0, randNumber);
    MODEM.hardReset();
I suspect that the answer to your issue is going to be to stop using the blocking Blynk.begin command, and instead to do the following:
  1. establish a GSM connection
  2. use the Blynk.config(GSM_object, auth_token, Blynk_server, port) command
  3. use Blynk.connect(optional_timeout_in_ms) to establish your Blynk connection
  4. only execute Blynk.run() if Blynk.connected == true
  5. use a times function to check both your GSM and Blynk connections, and re-establish them if they have been dropped
Unfortunately, Iโ€™m not familiar with your hardware, so I canโ€™t help with code examp[le on how to do this.
You might also want to check that your board firmware is up to date, the library youโ€™re using for the board is up to date and that you get the same issue if you use a different network provider.
Can you provide a resource on what this means?
