I use an Wemos D1 Mini and i want to turn on/off 12v led that flickers with the Blynk app for iOS. (See my code under)
My wiring is correct because the led flicker if i just sett it in code, but i do not know how to make it flicker when i turned it on/off from the app. I can make the led turn on/off, but it does not flicker.
I’m not specially good with coding, and need som help to make this work.
int powerled = 14;
char auth[] = "***";
char ssid[] = "***";
char pass[] = "***";
pinMode(powerled, OUTPUT);
void candlelight(){
if(powerled == HIGH){
analogWrite(powerled, random(120) + 135);
delay(random(300));
if(powerled == LOW){
analogWrite(powerled, LOW);
candlelight();
