Hi I am new to using blynk
I am setting up a project to use the ttgotcall board to remotely open and close relays by gprs
My code is this
For this example, you need to install Blynk library:
TinyGSM Getting Started guide:
https://tiny.cc/tinygsm-readme
Blynk supports many development boards with WiFi, Ethernet,
GSM, Bluetooth, BLE, USB/Serial connection methods.
See more in Blynk library examples and community forum.
http://www.blynk.io/
Change GPRS apm, user, pass, and Blynk auth token to run :)
// Default heartbeat interval for GSM is 60
// If you want override this value, uncomment and set this option:
// #define BLYNK_HEARTBEAT 30
// Please select the corresponding model
#define SIM800L_IP5306_VERSION_20190610
// #define SIM800L_AXP192_VERSION_20200327
// #define SIM800C_AXP192_VERSION_20200609
// #define SIM800L_IP5306_VERSION_20200811
#include "utilities.h"
// Select your modem:
#define TINY_GSM_MODEM_SIM800
// Set serial for debug console (to the Serial Monitor, default speed 115200)
#define SerialMon Serial
// Set serial for AT commands (to the module)
// Use Hardware Serial on Mega, Leonardo, Micro
#define SerialAT Serial1
// See all AT commands, if wanted
//#define DUMP_AT_COMMANDS
// Define the serial console for debug prints, if needed
#define TINY_GSM_DEBUG SerialMon
// set GSM PIN, if any
#define GSM_PIN " ";
// Your GPRS credentials, if any
const char apn[] = ""; // search for apn of your network provider on Google
const char gprsUser[] = "";
const char gprsPass[] = "";
#include <TinyGsmClient.h>
#ifdef DUMP_AT_COMMANDS
#include <StreamDebugger.h>
StreamDebugger debugger(SerialAT, SerialMon);
TinyGsm modem(debugger);
#else
TinyGsm modem(SerialAT);
#endif
TinyGsmClient client(modem);
const char auth[] = "";
// Set console baud rate
SerialMon.begin(115200);
setupModem();
SerialMon.println("Wait...");
// Set GSM module baud rate and UART pins
SerialAT.begin(115200, SERIAL_8N1, MODEM_RX, MODEM_TX);
delay(6000);
SerialMon.println("Initializing modem...");
modem.restart();
// modem.init();
String modemInfo = modem.getModemInfo();
SerialMon.print("Modem Info: ");
SerialMon.println(modemInfo);
// Unlock your SIM card with a PIN
modem.simUnlock("1234");
Blynk.begin(auth, modem, apn, gprsUser, gprsPass);
but I can't connect to blynk-cloud,
what could be happening so that it doesn't connect? I have changed from port 80 to 8080 but I can't connect either
can you please help me
Thanks in advance
Greetings
@canyon please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
