I’m using the above TTGO board which has build in LoRa and ESP32
It works all fine when using LoRa radio alone and even WiFi together its all fine BUT when I compile with Blynk it continually crashes…logs below might provide a clue to experts; any help would be great
Rebooting...
ets Jun 8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 188777542, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:928
ho 0 tail 12 room 4
load:0x40078000,len:8424
ho 0 tail 12 room 4
load:0x40080400,len:5868
entry 0x4008069c
....Waiting to connect to Wifi:
..WL_CONNECTED = 3
WiFi status = 3
WiFi connected
IP address:
192.168.0.51
[1183]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ \/ '_/
/____/_/\_, /_//_/_/\_\
/___/ v0.6.1 on ESP32
[1192] Connecting to blynk.-----.com:80
[1235] <[1D|00|01|00] xxxxxxxxx
[1264] >[00|00|01|00|C8]
[1264] Ready (ping: 28ms).
[1331] <[11|00|02|00]Fver[00]0.6.1[00]h-beat[00]10[00]buff-in[00]1024[00]dev[00]ESP32[00]build[00]Aug 2 2019 15:02:58[00]
Blynk connected !
LoRa init succeeded.
LoRa Simple Gateway
Only receive messages from nodes
Tx: invertIQ enable
Rx: invertIQ disable
0 : RECEIVED FROM: relay1 => Guru Meditation Error: Core 1 panic'ed (Interrupt wdt timeout on CPU1)
Core 1 register dump:
PC : 0x4008bc92 PS : 0x00060334 A0 : 0x8008addb A1 : 0x3ffbdf50
A2 : 0x3ffc81f0 A3 : 0x3ffb8074 A4 : 0x00000001 A5 : 0x00000001
A6 : 0x00060323 A7 : 0x00000000 A8 : 0x3ffb8074 A9 : 0x3ffb8074
A10 : 0x00000018 A11 : 0x00000018 A12 : 0x00000001 A13 : 0x00000001
A14 : 0x00060321 A15 : 0x00000000 SAR : 0x00000019 EXCCAUSE: 0x00000006
EXCVADDR: 0x00000000 LBEG : 0x4000c2e0 LEND : 0x4000c2f6 LCOUNT : 0xffffffff
Core 1 was running in ISR context:
EPC1 : 0x401030d8 EPC2 : 0x00000000 EPC3 : 0x00000000 EPC4 : 0x4008bc92
Backtrace: 0x4008bc92:0x3ffbdf50 0x4008add8:0x3ffbdf70 0x40089863:0x3ffbdf90 0x40103055:0x3ffbdfd0 0x400f1e8f:0x3ffbdff0 0x4010358d:0x3ffbe020 0x401039ed:0x3ffbe040 0x400f0cd6:0x3ffbe080 0x400f1791:0x3ffbe100 0x400f180e:0x3ffbe130 0x400d3586:0x3ffbe150 0x400d35f1:0x3ffbe170 0x400d36b5:0x3ffbe190 0x4013fd5a:0x3ffbe1b0 0x400d49e9:0x3ffbe1e0 0x400d4a15:0x3ffbe200 0x400d1f63:0x3ffbe220 0x400d25d7:0x3ffbe280 0x400d2818:0x3ffbe2b0 0x400d29d1:0x3ffbe2f0 0x400d2b7b:0x3ffbe730 0x400d312f:0x3ffbe760 0x400d313a:0x3ffbe780 0x40081355:0x3ffbe7a0 0x40081b59:0x3ffbe7c0 0x40083870:0x3ffb1ef0 0x400835df:0x3ffb1f10 0x4008162f:0x3ffb1f30 0x400d1b2f:0x3ffb1f50 0x400d1b55:0x3ffb1f70 0x400d613d:0x3ffb1fb0 0x40088b49:0x3ffb1fd0
Core 0 register dump:
PC : 0x4008a25a PS : 0x00060634 A0 : 0x8008b439 A1 : 0x3ffb3d20
A2 : 0x3ffbeca0 A3 : 0x0000cdcd A4 : 0xb33fffff A5 : 0x00000001
A6 : 0x00060623 A7 : 0x0000abab A8 : 0x0000abab A9 : 0x3ffbe140
A10 : 0x00000003 A11 : 0x00060023 A12 : 0x00060021 A13 : 0x00000000
A14 : 0x00000000 A15 : 0x00000000 SAR : 0x00000019 EXCCAUSE: 0x00000006
Backtrace: 0x4008a25a:0x3ffb3d20 0x4008b436:0x3ffb3d50 0x400897c3:0x3ffb3d70 0x40102f7e:0x3ffb3db0 0x4010325a:0x3ffb3dd0 0x40104ea7:0x3ffb3df0 0x400f1ce9:0x3ffb3e10 0x40088b49:0x3ffb3e40
Rebooting...
