Error I get trying to run a default tutorial sketch on Seeed Wio Terminal.
What could be wrong?
Here is an error I get:
libraries/Blynk/utility/BlynkDebug.cpp.o: In function `BlynkFreeRam()':
/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkDebug.cpp:104: multiple definition of `BlynkFreeRam()'
libraries/Blynk/utility/BlynkDebug 2.cpp.o:/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkDebug 2.cpp:104: first defined here
libraries/Blynk/utility/BlynkDebug.cpp.o: In function `BlynkReset()':
/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkDebug.cpp:110: multiple definition of `BlynkReset()'
libraries/Blynk/utility/BlynkDebug 2.cpp.o:/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkDebug 2.cpp:110: first defined here
libraries/Blynk/utility/BlynkDebug.cpp.o: In function `BlynkDelay(unsigned long)':
/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkDebug.cpp:300: multiple definition of `BlynkDelay(unsigned long)'
libraries/Blynk/utility/BlynkDebug 2.cpp.o:/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkDebug 2.cpp:300: first defined here
libraries/Blynk/utility/BlynkDebug.cpp.o: In function `BlynkMillis()':
/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkDebug.cpp:307: multiple definition of `BlynkMillis()'
libraries/Blynk/utility/BlynkDebug 2.cpp.o:/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkDebug 2.cpp:307: first defined here
libraries/Blynk/utility/BlynkDebug.cpp.o: In function `BlynkResetImplemented()':
/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkDebug.cpp:328: multiple definition of `BlynkResetImplemented()'
libraries/Blynk/utility/BlynkDebug 2.cpp.o:/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkDebug 2.cpp:328: first defined here
libraries/Blynk/utility/BlynkDebug.cpp.o: In function `BlynkFatal()':
/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkDebug.cpp:332: multiple definition of `BlynkFatal()'
libraries/Blynk/utility/BlynkDebug 2.cpp.o:/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkDebug 2.cpp:332: first defined here
libraries/Blynk/utility/BlynkHandlers.cpp.o: In function `BlynkWidgetRead':
/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkHandlers.cpp:20: multiple definition of `BlynkWidgetRead'
libraries/Blynk/utility/BlynkHandlers 2.cpp.o:/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkHandlers 2.cpp:20: first defined here
libraries/Blynk/utility/BlynkHandlers.cpp.o: In function `BlynkWidgetWrite':
/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkHandlers.cpp:25: multiple definition of `BlynkWidgetWrite'
libraries/Blynk/utility/BlynkHandlers 2.cpp.o:/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkHandlers 2.cpp:25: first defined here
libraries/Blynk/utility/BlynkHandlers.cpp.o: In function `BlynkNoOpCbk':
/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkHandlers.cpp:15: multiple definition of `BlynkNoOpCbk'
libraries/Blynk/utility/BlynkHandlers 2.cpp.o:/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkHandlers 2.cpp:15: first defined here
libraries/Blynk/utility/BlynkHandlers.cpp.o: In function `GetReadHandler':
/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkHandlers.cpp:388: multiple definition of `GetReadHandler'
libraries/Blynk/utility/BlynkHandlers 2.cpp.o:/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkHandlers 2.cpp:388: first defined here
libraries/Blynk/utility/BlynkHandlers.cpp.o: In function `GetWriteHandler':
/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkHandlers.cpp:399: multiple definition of `GetWriteHandler'
libraries/Blynk/utility/BlynkHandlers 2.cpp.o:/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkHandlers 2.cpp:399: first defined here
libraries/Blynk/utility/BlynkHelpers.cpp.o: In function `dtostrf_internal(double, signed char, unsigned char, char*)':
/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkHelpers.cpp:11: multiple definition of `dtostrf_internal(double, signed char, unsigned char, char*)'
libraries/Blynk/utility/BlynkHelpers 3.cpp.o:/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkHelpers 3.cpp:11: first defined here
libraries/Blynk/utility/BlynkHelpers.cpp.o: In function `lltoa_internal(long long, char*, unsigned int, int)':
/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkHelpers.cpp:84: multiple definition of `lltoa_internal(long long, char*, unsigned int, int)'
libraries/Blynk/utility/BlynkHelpers 3.cpp.o:/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkHelpers 3.cpp:84: first defined here
libraries/Blynk/utility/BlynkHelpers.cpp.o: In function `ulltoa_internal(unsigned long long, char*, unsigned int, int)':
/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkHelpers.cpp:106: multiple definition of `ulltoa_internal(unsigned long long, char*, unsigned int, int)'
libraries/Blynk/utility/BlynkHelpers 3.cpp.o:/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkHelpers 3.cpp:106: first defined here
libraries/Blynk/utility/BlynkTimeUtils.cpp.o: In function `blynk_gmtime_r(long long const*, blynk_tm*)':
/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkTimeUtils.cpp:25: multiple definition of `blynk_gmtime_r(long long const*, blynk_tm*)'
libraries/Blynk/utility/BlynkTimeUtils 3.cpp.o:/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkTimeUtils 3.cpp:25: first defined here
libraries/Blynk/utility/BlynkTimeUtils.cpp.o: In function `blynk_mk_gmtime(blynk_tm*)':
/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkTimeUtils.cpp:48: multiple definition of `blynk_mk_gmtime(blynk_tm*)'
libraries/Blynk/utility/BlynkTimeUtils 3.cpp.o:/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkTimeUtils 3.cpp:48: first defined here
libraries/Blynk/utility/BlynkTimeUtils.cpp.o: In function `blynk_compute_sun(signed char, signed char, double, double, bool)':
/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkTimeUtils.cpp:143: multiple definition of `blynk_compute_sun(signed char, signed char, double, double, bool)'
libraries/Blynk/utility/BlynkTimeUtils 3.cpp.o:/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkTimeUtils 3.cpp:143: first defined here
libraries/Blynk/utility/BlynkTimer.cpp.o: In function `BlynkTimer::BlynkTimer()':
/Users/scott/Library/Arduino15/packages/Seeeduino/tools/arm-none-eabi-gcc/7-2017q4/arm-none-eabi/include/c++/7.2.1/bits/std_function.h:565: multiple definition of `BlynkTimer::BlynkTimer()'
libraries/Blynk/utility/BlynkTimer 2.cpp.o:/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkTimer 2.cpp:38: first defined here
libraries/Blynk/utility/BlynkTimer.cpp.o: In function `std::function<void ()>::operator=(std::function<void ()>&&)':
/Users/scott/Library/Arduino15/packages/Seeeduino/tools/arm-none-eabi-gcc/7-2017q4/arm-none-eabi/include/c++/7.2.1/bits/move.h:200: multiple definition of `BlynkTimer::findFirstFreeSlot()'
libraries/Blynk/utility/BlynkTimer 2.cpp.o:/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkTimer 2.cpp:121: first defined here
libraries/Blynk/utility/BlynkTimer.cpp.o: In function `BlynkTimer::changeInterval(unsigned int, unsigned long)':
/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkTimer.cpp:197: multiple definition of `BlynkTimer::changeInterval(unsigned int, unsigned long)'
libraries/Blynk/utility/BlynkTimer 2.cpp.o:/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkTimer 2.cpp:197: first defined here
libraries/Blynk/utility/BlynkTimer.cpp.o: In function `BlynkTimer::restartTimer(unsigned int)':
/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkTimer.cpp:235: multiple definition of `BlynkTimer::restartTimer(unsigned int)'
libraries/Blynk/utility/BlynkTimer 2.cpp.o:/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkTimer 2.cpp:235: first defined here
libraries/Blynk/utility/BlynkTimer.cpp.o: In function `BlynkTimer::executeNow(unsigned int)':
/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkTimer.cpp:243: multiple definition of `BlynkTimer::executeNow(unsigned int)'
libraries/Blynk/utility/BlynkTimer 2.cpp.o:/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkTimer 2.cpp:243: first defined here
libraries/Blynk/utility/BlynkTimer.cpp.o: In function `BlynkTimer::isEnabled(unsigned int)':
/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkTimer.cpp:251: multiple definition of `BlynkTimer::isEnabled(unsigned int)'
libraries/Blynk/utility/BlynkTimer 2.cpp.o:/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkTimer 2.cpp:251: first defined here
libraries/Blynk/utility/BlynkTimer.cpp.o: In function `BlynkTimer::enable(unsigned int)':
/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkTimer.cpp:260: multiple definition of `BlynkTimer::enable(unsigned int)'
libraries/Blynk/utility/BlynkTimer 2.cpp.o:/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkTimer 2.cpp:260: first defined here
libraries/Blynk/utility/BlynkTimer.cpp.o: In function `BlynkTimer::disable(unsigned int)':
/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkTimer.cpp:269: multiple definition of `BlynkTimer::disable(unsigned int)'
libraries/Blynk/utility/BlynkTimer 2.cpp.o:/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkTimer 2.cpp:269: first defined here
libraries/Blynk/utility/BlynkTimer.cpp.o: In function `BlynkTimer::enableAll()':
/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkTimer.cpp:276: multiple definition of `BlynkTimer::enableAll()'
libraries/Blynk/utility/BlynkTimer 2.cpp.o:/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkTimer 2.cpp:276: first defined here
libraries/Blynk/utility/BlynkTimer.cpp.o: In function `BlynkTimer::disableAll()':
/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkTimer.cpp:285: multiple definition of `BlynkTimer::disableAll()'
libraries/Blynk/utility/BlynkTimer 2.cpp.o:/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkTimer 2.cpp:285: first defined here
libraries/Blynk/utility/BlynkTimer.cpp.o: In function `BlynkTimer::toggle(unsigned int)':
/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkTimer.cpp:295: multiple definition of `BlynkTimer::toggle(unsigned int)'
libraries/Blynk/utility/BlynkTimer 2.cpp.o:/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkTimer 2.cpp:295: first defined here
libraries/Blynk/utility/BlynkTimer.cpp.o: In function `BlynkTimer::getNumTimers()':
/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkTimer.cpp:305: multiple definition of `BlynkTimer::getNumTimers()'
libraries/Blynk/utility/BlynkTimer 2.cpp.o:/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkTimer 2.cpp:305: first defined here
libraries/Blynk/utility/BlynkTimer.cpp.o: In function `BlynkTimer::deleteTimer(unsigned int)':
/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkTimer.cpp:211: multiple definition of `BlynkTimer::deleteTimer(unsigned int)'
libraries/Blynk/utility/BlynkTimer 2.cpp.o:/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkTimer 2.cpp:211: first defined here
libraries/Blynk/utility/BlynkTimer.cpp.o: In function `BlynkTimer::run()':
/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkTimer.cpp:55: multiple definition of `BlynkTimer::run()'
libraries/Blynk/utility/BlynkTimer 2.cpp.o:/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkTimer 2.cpp:55: first defined here
libraries/Blynk/utility/BlynkTimer.cpp.o: In function `BlynkTimer::init()':
/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkTimer.cpp:43: multiple definition of `BlynkTimer::init()'
libraries/Blynk/utility/BlynkTimer 2.cpp.o:/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkTimer 2.cpp:43: first defined here
libraries/Blynk/utility/BlynkTimer.cpp.o: In function `BlynkTimer::setupTimer(unsigned long, void (*)(void*), void*, unsigned int)':
/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkTimer.cpp:167: multiple definition of `BlynkTimer::setupTimer(unsigned long, void (*)(void*), void*, unsigned int)'
libraries/Blynk/utility/BlynkTimer 2.cpp.o:/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkTimer 2.cpp:167: first defined here
libraries/Blynk/utility/BlynkTimer.cpp.o: In function `BlynkTimer::setupTimer(unsigned long, std::function<void ()> const&, unsigned int)':
/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkTimer.cpp:139: multiple definition of `BlynkTimer::setupTimer(unsigned long, std::function<void ()> const&, unsigned int)'
libraries/Blynk/utility/BlynkTimer 2.cpp.o:/Users/scott/Documents/Arduino/libraries/Blynk/src/utility/BlynkTimer 2.cpp:139: first defined here
collect2: error: ld returned 1 exit status
exit status 1
Compilation error: exit status 1
