As @PeteKnight said, it’s frustrating for any forum member to help as nobody can have patience and time to get the full picture of your project spreading across seemingly unrelated topics.
Anyway, we all can see you have lot of patience in getting help, by trying your best in researching and  modifying the code yourself.
So this is just a little bit of help. The most critical issues are
- The incorrect use of ISR (“ISR not in IRAM”)
- The use of delay() in wrong place to control the relay
- Many other problems as well
Here is the preliminary fix, based on your code. Hope you study it and improve.
#ifndef ESP8266
#error This code is intended to run on the ESP8266 platform! Please check your Tools->Board setting.
#endif
#define USE_BLYNK_WM      true
// Not use #define USE_SPIFFS  => using EEPROM for configuration data in WiFiManager
// #define USE_SPIFFS    false => using EEPROM for configuration data in WiFiManager
// #define USE_SPIFFS    true  => using SPIFFS for configuration data in WiFiManager
// Be sure to define USE_SPIFFS before #include <BlynkSimpleEsp8266_WM.h>
#define USE_SPIFFS                  false //true
#if (!USE_SPIFFS)
// EEPROM_SIZE must be <= 4096 and >= CONFIG_DATA_SIZE (currently 172 bytes)
#define EEPROM_SIZE    (4 * 1024)
// EEPROM_START + CONFIG_DATA_SIZE must be <= EEPROM_SIZE
#define EEPROM_START  0
#endif
// Force some params in Blynk, only valid for library version 1.0.1 and later
#define TIMEOUT_RECONNECT_WIFI                    10000L
#define RESET_IF_CONFIG_TIMEOUT                   true
#define CONFIG_TIMEOUT_RETRYTIMES_BEFORE_RESET    5
// Those above #define's must be placed before #include <BlynkSimpleEsp8266_WM.h>
#define USE_SSL   false
#if USE_BLYNK_WM
#if USE_SSL
#include <BlynkSimpleEsp8266_SSL_WM.h>        //https://github.com/khoih-prog/Blynk_WM
#else
#include <BlynkSimpleEsp8266_WM.h>            //https://github.com/khoih-prog/Blynk_WM
#endif
#else
#if USE_SSL
#include <BlynkSimpleEsp8266_SSL.h>
#else
#endif
char auth[] = "*";
char ssid[] = "*";
char pass[] = "*";
#endif
#include <MFRC522.h>
#define RST_PIN       5     // Configurable, see typical pin layout above
#define SS_PIN        4     // Configurable, see typical pin layout above
MFRC522 rfid(SS_PIN, RST_PIN); // Instance of the class
MFRC522::MIFARE_Key key;
byte nuidPICC[4];
//Project Code
bool pinValue5;
bool pinValue10;
bool pinValue20;
bool pinValue50;
bool pinValueConfirm;
bool flag;
//Flow Rate
int limitType, tap_limit_value, timer1, timer2, timer3, rowIndex = 0, month_old;
volatile uint32_t pulseCount = 0;
float flowRate = 0.00, waterCost, waterCost_month;
float flowLitres;
float totalLitres, totalLitres_month;
#define vPIN_VALUE_5              V0
#define vPIN_VALUE_10             V1
#define vPIN_VALUE_20             V2
#define vPIN_VALUE_50             V3
#define vPIN_CONFIRM              V4
#define vPIN_LVD                  V5
#define vPIN_TAP_LED              V7
#define vPIN_TAP_LIMIT            V14
#define vPIN_TAP_MANUAL           V18
#define vPIN_TAP_ACTIVATE         V19
#define vPIN_WATER_TOTAL          V25
#define vPIN_WATER_TOTAL_MONTH    V21
#define vPIN_WATER_FLOW           V26
#define vPIN_WATER_COST           V28
#define vPIN_WATER_COST_MONTH     V11
#define vPIN_WATER_TAP            V27
#define vPIN_TERMINAL             V31
#define vPIN_LIMITMENU            V9
#define vPIN_LAST_MONTH           V10
#define FLOW_SENSOR               D3  // D2
#define FLOW_CALIBRATION          4.5
#define WATER_PRICE               0.1444
bool relayActive      = false;
bool parkCarDisplayed = false;
WidgetLCD lcd(vPIN_LVD);
// Use true to bypass RFID validation
#define TESTING_WITHOUT_RFID      true
void displayLCD(uint8_t X1, uint8_t Y1, String msg1, uint8_t X2, uint8_t Y2, String msg2)
  lcd.clear(); //Use it to clear the LCD Widget
  lcd.print(X1, Y1, msg1); // use: (position X: 0-15, position Y: 0-1, "Message you want to print")
  lcd.print(X2, Y2, msg2);
BLYNK_CONNECTED()
  displayLCD(0, 0, "Welcome to", 0, 1, "Bakers got Gas");
BLYNK_WRITE(vPIN_VALUE_5)
  if ( param.asInt() )
    pinValue10 = pinValue20 = pinValue50 = pinValueConfirm = false;
    pinValue5 = true;
  if (pinValue5 && !param.asInt())
    Serial.println("Customer requests $5 gas");
    displayLCD(0, 0, "5? Please park", 0, 1, "at pump. Confirm");
BLYNK_WRITE(vPIN_VALUE_10)
    pinValue5 = pinValue20 = pinValue50 = pinValueConfirm = false;
    pinValue10 = true;
  if (pinValue10 && !param.asInt())
    Serial.println("Customer requests $10 gas");
    displayLCD(0, 0, "10? Please park", 0, 1, "at pump. Confirm");
BLYNK_WRITE(vPIN_VALUE_20)
    pinValue5 = pinValue10 = pinValue50 = pinValueConfirm = false;
    pinValue20 = true;
  if (pinValue20 && !param.asInt())
    Serial.println("Customer requests $20 gas");
    displayLCD(0, 0, "20? Please park", 0, 1, "at pump. Confirm");
BLYNK_WRITE(vPIN_VALUE_50)
    pinValue5 = pinValue10 = pinValue20 = pinValueConfirm = false;
    pinValue50 = true;
  if (pinValue50 && !param.asInt())
    Serial.println("Customer requests $50 gas");
    displayLCD(0, 0, "50? Please park", 0, 1, "at pump. Confirm");
BLYNK_WRITE(vPIN_CONFIRM)
  if ( param.asInt() && (pinValue5 || pinValue10 || pinValue20 || pinValue50) )
    pinValueConfirm = true;
  if (pinValueConfirm && !param.asInt())
    Serial.println("Purchase Confirmed");
void checkRFID()
  if ( ! rfid.PICC_IsNewCardPresent())
    return;
  Serial.println();
  flag = true;
  Serial.println("Flag OK");
  // Verify if the NUID has been readed
  if ( ! rfid.PICC_ReadCardSerial())
    return;
  Serial.print(F("PICC type: "));
  MFRC522::PICC_Type piccType = rfid.PICC_GetType(rfid.uid.sak);
  Serial.println(rfid.PICC_GetTypeName(piccType));
  // Check is the PICC of Classic MIFARE type
  if (piccType != MFRC522::PICC_TYPE_MIFARE_MINI &&
      piccType != MFRC522::PICC_TYPE_MIFARE_1K &&
      piccType != MFRC522::PICC_TYPE_MIFARE_4K)
    Serial.println(F("Your tag is not of type MIFARE Classic."));
    return;
  if (rfid.uid.uidByte[0] != nuidPICC[0] ||
      rfid.uid.uidByte[1] != nuidPICC[1] ||
      rfid.uid.uidByte[2] != nuidPICC[2] ||
      rfid.uid.uidByte[3] != nuidPICC[3] )
    Serial.println(F("A new card has been detected."));
    // Store NUID into nuidPICC array
    for (byte i = 0; i < 4; i++)
      nuidPICC[i] = rfid.uid.uidByte[i];
    Serial.println(F("The NUID tag is:"));
    Serial.print(F("In hex: "));
    printHex(rfid.uid.uidByte, rfid.uid.size);
    Serial.println();
    Serial.print(F("In dec: "));
    printDec(rfid.uid.uidByte, rfid.uid.size);
  else Serial.println(F("Card read previously."));
  // Halt PICC
  rfid.PICC_HaltA();
  // Stop encryption on PCD
  rfid.PCD_StopCrypto1();
void clickRelay(int relayPin, uint32_t timeout)
  static int pinRelay = relayPin;
  digitalWrite(pinRelay, HIGH);
  timer.setTimeout(timeout, []()
    digitalWrite(pinRelay, LOW);
    Serial.println("Stop pumping gas");
void pumpControl()
  if (!relayActive )
#if TESTING_WITHOUT_RFID
    flag = true;
#endif
    if (flag && pinValue5 && pinValueConfirm)
      pinValue5 = pinValueConfirm = false;
      relayActive = true;
      clickRelay(D0, 5000);
      flag = false;
      displayLCD(0, 0, "Dispense $5", 0, 1, "worth of gas");
      Serial.println("Dispense $5 worth of gas");
    else if (flag && pinValue10 && pinValueConfirm)
      pinValue10 = pinValueConfirm = false;
      relayActive = true;
      clickRelay(D0, 7500);
      flag = false;
      displayLCD(0, 0, "Dispense $10", 0, 1, "worth of gas");
      Serial.println("Dispense $10 worth of gas");
    else if (flag && pinValue20 && pinValueConfirm)
      relayActive = true;
      clickRelay(D0, 10000);
      flag = false;
      displayLCD(0, 0, "Dispense $20", 0, 1, "worth of gas");
      Serial.println("Dispense $20 worth of gas");
    else if (flag && pinValue50 && pinValueConfirm)
      relayActive = true;
      clickRelay(D0, 12000);
      flag = false;
      displayLCD(0, 0, "Dispense $50", 0, 1, "worth of gas");
      Serial.println("Dispense $50 worth of gas");
    else if ( !parkCarDisplayed && pinValueConfirm && (pinValue5 || pinValue10 || pinValue20 || pinValue50 ) )
      displayLCD(0, 0, "Park car on", 0, 1, "marked location");
      parkCarDisplayed = true;
void printHex(byte *buffer, byte bufferSize)
  for (byte i = 0; i < bufferSize; i++)
    Serial.print(buffer[i] < 0x10 ? " 0" : " ");
    Serial.print(buffer[i], HEX);
   Helper routine to dump a byte array as dec values to Serial.
void printDec(byte *buffer, byte bufferSize)
    Serial.print(buffer[i], DEC);
void ICACHE_RAM_ATTR pulseCounter()
  pulseCount++;
void flowSensor()
  noInterrupts();
  flowRate = pulseCount / FLOW_CALIBRATION;
  pulseCount = 0;
  interrupts();
  //calc totals
  flowLitres = (flowRate / 60);
  totalLitres += flowLitres;
  totalLitres_month += flowLitres;
  Blynk.virtualWrite(vPIN_WATER_TOTAL, (float) totalLitres);
  Blynk.virtualWrite(vPIN_WATER_FLOW,  String((float) flowLitres, 0));
  Blynk.virtualWrite(vPIN_WATER_TOTAL_MONTH, (float) totalLitres_month);
  waterCost = waterCost + ( ( ( (float) flowLitres ) * WATER_PRICE ) / 100);
  Blynk.virtualWrite(vPIN_WATER_COST, String(waterCost, 6));
  waterCost_month = waterCost_month + ( ( ( (float) flowLitres ) * WATER_PRICE ) / 100);
  Blynk.virtualWrite(vPIN_WATER_COST_MONTH, String(waterCost_month, 6));
  pinMode(D0, OUTPUT);
  //Flow Rate
  pulseCount   = 0;
  flowRate     = 0.0;
  flowLitres   = 0;
  totalLitres  = 0;
  //RFID
  SPI.begin(); // Init SPI bus
  rfid.PCD_Init(); // Init MFRC522
  for (byte i = 0; i < 6; i++)
    key.keyByte[i] = 0xFF;
  Serial.println(F("This code scan the MIFARE Classsic NUID."));
  Serial.print(F("Using the following key:"));
  printHex(key.keyByte, MFRC522::MF_KEY_SIZE);
#if USE_BLYNK_WM
  Blynk.begin("RFIC_System");
#else
#endif
  timer.setInterval(100L,  checkRFID);
  timer.setInterval(500L,  pumpControl);
  timer.setInterval(5000L, flowSensor);
  attachInterrupt(FLOW_SENSOR, pulseCounter, FALLING);
and the terminal output of a test using Blynk_WM library library
217] Calc Cksum = 0x2ea9, Read Cksum = 0x2ea9
[219] Header = ESP8266, Board Name = RFID-Gas
[223] SSID = ****, PW =****
[226] SSID1 = ****, PW1 = ****
[230] Server = ****.duckdns.org, Token = ****
[236] Server1 = 192.168.2.110, Token1 = ****
[243] Port = 8080
[244] Connecting MultiWifi...
[4602] WiFi connected after time: 1
[4602] SSID: ****, RSSI = -36
[4602] Channel: 10, IP address: 192.168.2.46
[4602] bg: WiFi connected. Try Blynk
[4604]
    ___  __          __
   / _ )/ /_ _____  / /__
  / _  / / // / _ \/  '_/
 /____/_/\_, /_//_/_/\_\
        /___/ v0.6.1 on NodeMCU
[4617] BlynkArduinoClient.connect: Connecting to ****.duckdns.org:8080
[4646] Ready (ping: 5ms).
[4914] Connected to Blynk Server = ****.duckdns.org, Token  = ****
[4914] bg: WiFi+Blynk connected
Purchase Confirmed
Stop pumping gas
Purchase Confirmed
Stop pumping gas
Purchase Confirmed
Stop pumping gas
We’re here as volunteers, and are not interested in compensation. If we have to live by that, it might be very high to pay.
