Trying To Change The World
@Dmytro I am using an ESP32 Cam and a motion sensor, I used Blynk Air to open up my app but when I changed the code to get the motion sensor to work and allow live streaming suddenly I get the error message “‘BOARD_BUTTON_PIN’ was not declared in this scope” in ResetButton.h. It also gave me a problem with the WebServer. I am new to coding and to Blynk. I chose Blynk because of it’s friendliness to new users who do not have much experience with coding. So, I copy and pasted codes from GitHub that appeared to do what I needed. Here is my code at this point, can anyone help me figure out why my code will not compile and work as desired? I am looking for the code to set off a sensor which turns on my ESP32 Cam then sends an alert to Blynk App and allows me to livestream what is on the camera via the Blynk App. Thank you.
#define BLYNK_TEMPLATE_ID "TMPLPozfIt3F"
#define BLYNK_DEVICE_NAME "PMD V4"
#define BLYNK_FIRMWARE_VERSION        "0.1.1"
//#define BLYNK_DEBUG
#define APP_DEBUG
// Uncomment your board, or configure a custom board in Settings.h
//#define USE_WROVER_BOARD
//#define USE_TTGO_T7
#define CAMERA_MODEL_AI_THINKER
#include "BlynkEdgent.h"
#include "src/OV2640.h"
#include "esp_camera.h"
#include <WiFi.h>
#include <WebServer.h>
#include <WiFiClient.h>
#include "camera_pins.h"
OV2640 cam;
WebServer server(80);
const char HEADER[] = "HTTP/1.1 200 OK\r\n" \
                      "Access-Control-Allow-Origin: *\r\n" \
                      "Content-Type: multipart/x-mixed-replace; boundary=123456789000000000000987654321\r\n";
const char BOUNDARY[] = "\r\n--123456789000000000000987654321\r\n";
const char CTNTTYPE[] = "Content-Type: image/jpeg\r\nContent-Length: ";
const int hdrLen = strlen(HEADER);
const int bdrLen = strlen(BOUNDARY);
const int cntLen = strlen(CTNTTYPE);
void handle_jpg_stream(void)
  char buf[32];
  int s;
  WiFiClient client = server.client();
  client.write(HEADER, hdrLen);
  client.write(BOUNDARY, bdrLen);
  while (true)
    if (!client.connected()) break;
    cam.run();
    s = cam.getSize();
    client.write(CTNTTYPE, cntLen);
    sprintf( buf, "%d\r\n\r\n", s );
    client.write(buf, strlen(buf));
    client.write((char *)cam.getfb(), s);
const char JHEADER[] = "HTTP/1.1 200 OK\r\n" \
                       "Content-disposition: inline; filename=capture.jpg\r\n" \
                       "Content-type: image/jpeg\r\n\r\n";
const int jhdLen = strlen(JHEADER);
void handle_jpg(void)
  cam.run();
  if (!client.connected()) return;
  client.write(JHEADER, jhdLen);
  client.write((char *)cam.getfb(), cam.getSize());
void handleNotFound()
  String message = "Server is running!\n\n";
  message += "URI: ";
  message += server.uri();
  message += "\nMethod: ";
  message += (server.method() == HTTP_GET) ? "GET" : "POST";
  message += "\nArguments: ";
  message += server.args();
  message += "\n";
  server.send(200, "text / plain", message);
   camera_config_t config;
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer = LEDC_TIMER_0;
  config.pin_d0 = Y2_GPIO_NUM;
  config.pin_d1 = Y3_GPIO_NUM;
  config.pin_d2 = Y4_GPIO_NUM;
  config.pin_d3 = Y5_GPIO_NUM;
  config.pin_d4 = Y6_GPIO_NUM;
  config.pin_d5 = Y7_GPIO_NUM;
  config.pin_d6 = Y8_GPIO_NUM;
  config.pin_d7 = Y9_GPIO_NUM;
  config.pin_xclk = XCLK_GPIO_NUM;
  config.pin_pclk = PCLK_GPIO_NUM;
  config.pin_vsync = VSYNC_GPIO_NUM;
  config.pin_href = HREF_GPIO_NUM;
  config.pin_sscb_sda = SIOD_GPIO_NUM;
  config.pin_sscb_scl = SIOC_GPIO_NUM;
  config.pin_pwdn = PWDN_GPIO_NUM;
  config.pin_reset = RESET_GPIO_NUM;
  config.xclk_freq_hz = 20000000;
  config.pixel_format = PIXFORMAT_JPEG;
  // Frame parameters
  //  config.frame_size = FRAMESIZE_UXGA;
  config.frame_size = FRAMESIZE_QVGA;
  config.jpeg_quality = 12;
  config.fb_count = 2;
#if defined(CAMERA_MODEL_ESP_EYE)
  pinMode(13, INPUT_PULLUP);
  pinMode(14, INPUT_PULLUP);
#endif
  cam.init(config);
 // camera init
  esp_err_t err = esp_camera_init(&config);
  if (err != ESP_OK) {
    Serial.printf("Camera init failed with error 0x%x", err);
    return;
  sensor_t * s = esp_camera_sensor_get();
  // initial sensors are flipped vertically and colors are a bit saturated
  if (s->id.PID == OV3660_PID) {
    s->set_vflip(s, 1); // flip it back
    s->set_brightness(s, 1); // up the brightness just a bit
    s->set_saturation(s, -2); // lower the saturation
  // drop down frame size for higher initial frame rate
  s->set_framesize(s, FRAMESIZE_QVGA);
  IPAddress ip;
  delay(100);
 ip = WiFi.localIP();
  Serial.println(F("WiFi connected"));
  Serial.println("");
  Serial.println(ip);
  Serial.print("Stream Link: http://");
  Serial.print(ip);
  Serial.println("/mjpeg/1");
  server.on("/mjpeg/1", HTTP_GET, handle_jpg_stream);
  server.on("/jpg", HTTP_GET, handle_jpg);
  server.onNotFound(handleNotFound);
  BlynkEdgent.begin();
  BlynkEdgent.run();
  server.handleClient();
  delay(10000);
ResetButton.h
volatile bool     g_buttonPressed = false;
volatile uint32_t g_buttonPressTime = -1;
void button_action(void)
  BlynkState::set(MODE_RESET_CONFIG);
void button_change(void)
#if BOARD_BUTTON_ACTIVE_LOW
  bool buttonState = !digitalRead(BOARD_BUTTON_PIN);
#else
  bool buttonState = digitalRead(BOARD_BUTTON_PIN);
#endif
  if (buttonState && !g_buttonPressed) {
    g_buttonPressTime = millis();
    g_buttonPressed = true;
 //   DEBUG_PRINT("Hold the button for 10 seconds to reset configuration...");
  } else if (!buttonState && g_buttonPressed) {
    uint32_t buttonHoldTime = millis() - g_buttonPressTime;
    if (buttonHoldTime >= BUTTON_HOLD_TIME_ACTION) {
      button_action();
      // User action
void button_init()
  pinMode(BOARD_BUTTON_PIN, INPUT_PULLUP);
#else
   pinMode(BOARD_BUTTON_PIN, INPUT_PULLDOWN);
#endif
  //attachInterrupt(BOARD_BUTTON_PIN, button_change, CHANGE);
ConfigMode.h
#include <DNSServer.h>
#include <Update.h>
#include <nvs.h>
#include <nvs_flash.h>
DNSServer dnsServer;
const byte DNS_PORT = 53;
#ifdef BLYNK_USE_SPIFFS
  #include "SPIFFS.h"
#else
  const char* config_form = R"html(
<!DOCTYPE HTML>
<html>
<head>
  <title>WiFi setup</title>
  <style>
  body {
    background-color: #fcfcfc;
    box-sizing: border-box;
  body, input {
    font-family: Roboto, sans-serif;
    font-weight: 400;
    font-size: 16px;
  .centered {
    position: fixed;
    top: 50%;
    left: 50%;
    transform: translate(-50%, -50%);
    padding: 20px;
    background-color: #ccc;
    border-radius: 4px;
  td { padding:0 0 0 5px; }
  label { white-space:nowrap; }
  input { width: 20em; }
  input[name="port"] { width: 5em; }
  input[type="submit"], img { margin: auto; display: block; width: 30%; }
  </style>
</head>
<body>
<div class="centered">
  <form method="get" action="config">
    <table>
    <tr><td><label for="ssid">WiFi SSID:</label></td>  <td><input type="text" name="ssid" length=64 required="required"></td></tr>
    <tr><td><label for="pass">Password:</label></td>   <td><input type="text" name="pass" length=64></td></tr>
    <tr><td><label for="blynk">Auth token:</label></td><td><input type="text" name="blynk" placeholder="a0b1c2d..." pattern="[-_a-zA-Z0-9]{32}" maxlength="32" required="required"></td></tr>
    <tr><td><label for="host">Host:</label></td>       <td><input type="text" name="host" value="blynk.cloud" length=64></td></tr>
    <tr><td><label for="port_ssl">Port:</label></td>   <td><input type="number" name="port_ssl" value="443" min="1" max="65535"></td></tr>
    </table><br/>
    <input type="submit" value="Apply">
  </form>
</div>
</body>
</html>
)html";
#endif
static const char serverUpdateForm[] PROGMEM =
  R"(<html><body>
      <form method='POST' action='' enctype='multipart/form-data'>
        <input type='file' name='update'>
        <input type='submit' value='Update'>
      </form>
    </body></html>)";
void restartMCU() {
  ESP.restart();
  while(1) {};
void eraseMcuConfig() {
  // Erase ESP32 NVS
  int err;
  //err=nvs_flash_init();
  //BLYNK_LOG2("nvs_flash_init: ", err ? String(err) : "Success");
  err=nvs_flash_erase();
  BLYNK_LOG2("nvs_flash_erase: ", err ? String(err) : "Success");
void getWiFiName(char* buff, size_t len, bool withPrefix = true) {
  const uint64_t chipId = ESP.getEfuseMac();
  uint32_t unique = 0;
  for (int i=0; i<4; i++) {
    unique = BlynkCRC32(&chipId, sizeof(chipId), unique);
  unique &= 0xFFFFF;
  if (withPrefix) {
    snprintf(buff, len, "Blynk %s-%05X", BLYNK_DEVICE_NAME, unique);
    snprintf(buff, len, "%s-%05X", BLYNK_DEVICE_NAME, unique);
void enterConfigMode()
  char ssidBuff[64];
  getWiFiName(ssidBuff, sizeof(ssidBuff));
  WiFi.mode(WIFI_OFF);
  delay(100);
  WiFi.mode(WIFI_AP);
  delay(2000);
  WiFi.softAPConfig(WIFI_AP_IP, WIFI_AP_IP, WIFI_AP_Subnet);
  WiFi.softAP(ssidBuff);
  delay(500);
  IPAddress myIP = WiFi.softAPIP();
  DEBUG_PRINT(String("AP SSID: ") + ssidBuff);
  DEBUG_PRINT(String("AP IP:   ") + myIP[0] + "." + myIP[1] + "." + myIP[2] + "." + myIP[3]);
  // Set up DNS Server
  dnsServer.setTTL(300); // Time-to-live 300s
  dnsServer.setErrorReplyCode(DNSReplyCode::ServerFailure); // Return code for non-accessible domains
#ifdef WIFI_CAPTIVE_PORTAL_ENABLE
  dnsServer.start(DNS_PORT, "*", WiFi.softAPIP()); // Point all to our IP
  server.onNotFound(handleRoot);
#else
  dnsServer.start(DNS_PORT, CONFIG_AP_URL, WiFi.softAPIP());
  DEBUG_PRINT(String("AP URL:  ") + CONFIG_AP_URL);
#endif
  server.on("/update", HTTP_GET, []() {
    server.sendHeader("Connection", "close");
    server.send(200, "text/html", serverUpdateForm);
  server.on("/update", HTTP_POST, []() {
    if (!Update.hasError()) {
      server.send(200, "text/plain", "OK");
      server.send(500, "text/plain", "FAIL");
    restartMCU();
    HTTPUpload& upload = server.upload();
    if (upload.status == UPLOAD_FILE_START) {
      DEBUG_PRINT(String("Update: ") + upload.filename);
      //WiFiUDP::stop();
      if (!Update.begin(UPDATE_SIZE_UNKNOWN)) { //start with max available size
        Update.printError(BLYNK_PRINT);
    } else if (upload.status == UPLOAD_FILE_WRITE) {
      /* flashing firmware to ESP*/
      if (Update.write(upload.buf, upload.currentSize) != upload.currentSize) {
      BLYNK_PRINT.print(".");
    } else if (upload.status == UPLOAD_FILE_END) {
      BLYNK_PRINT.println();
      DEBUG_PRINT("Finishing...");
      if (Update.end(true)) { //true to set the size to the current progress
        DEBUG_PRINT("Update Success. Rebooting");
  server.on("/config", []() {
    DEBUG_PRINT("Applying configuration...");
    String ssid = server.arg("ssid");
    String ssidManual = server.arg("ssidManual");
    String pass = server.arg("pass");
    if (ssidManual != "") {
      ssid = ssidManual;
    String token = server.arg("blynk");
    String host  = server.arg("host");
    String port  = server.arg("port_ssl");
    String ip   = server.arg("ip");
    String mask = server.arg("mask");
    String gw   = server.arg("gw");
    String dns  = server.arg("dns");
    String dns2 = server.arg("dns2");
    bool save  = server.arg("save").toInt();
    String content;
    DEBUG_PRINT(String("WiFi SSID: ") + ssid + " Pass: " + pass);
    DEBUG_PRINT(String("Blynk cloud: ") + token + " @ " + host + ":" + port);
    if (token.length() == 32 && ssid.length() > 0) {
      configStore.setFlag(CONFIG_FLAG_VALID, false);
      CopyString(ssid, configStore.wifiSSID);
      CopyString(pass, configStore.wifiPass);
      CopyString(token, configStore.cloudToken);
      if (host.length()) {
        CopyString(host,  configStore.cloudHost);
      if (port.length()) {
        configStore.cloudPort = port.toInt();
      IPAddress addr;
      if (ip.length() && addr.fromString(ip)) {
        configStore.staticIP = addr;
        configStore.setFlag(CONFIG_FLAG_STATIC_IP, true);
        configStore.setFlag(CONFIG_FLAG_STATIC_IP, false);
      if (mask.length() && addr.fromString(mask)) {
        configStore.staticMask = addr;
      if (gw.length() && addr.fromString(gw)) {
        configStore.staticGW = addr;
      if (dns.length() && addr.fromString(dns)) {
        configStore.staticDNS = addr;
      if (dns2.length() && addr.fromString(dns2)) {
        configStore.staticDNS2 = addr;
      if (save) {
        configStore.setFlag(CONFIG_FLAG_VALID, true);
        config_save();
        content = R"json({"status":"ok","msg":"Configuration saved"})json";
        content = R"json({"status":"ok","msg":"Trying to connect..."})json";
      server.send(200, "application/json", content);
      BlynkState::set(MODE_SWITCH_TO_STA);
      DEBUG_PRINT("Configuration invalid");
      content = R"json({"status":"error","msg":"Configuration invalid"})json";
      server.send(500, "application/json", content);
  server.on("/board_info.json", []() {
    DEBUG_PRINT("Sending board info...");
    const char* tmpl = BLYNK_TEMPLATE_ID;
    char ssidBuff[64];
    char buff[512];
    snprintf(buff, sizeof(buff),
      R"json({"board":"%s","tmpl_id":"%s","fw_type":"%s","fw_ver":"%s","ssid":"%s","bssid":"%s","last_error":%d,"wifi_scan":true,"static_ip":true})json",
      BLYNK_DEVICE_NAME,
      tmpl ? tmpl : "Unknown",
      BLYNK_FIRMWARE_TYPE,
      BLYNK_FIRMWARE_VERSION,
      ssidBuff,
      WiFi.softAPmacAddress().c_str(),
      configStore.last_error
    server.send(200, "application/json", buff);
  server.on("/wifi_scan.json", []() {
    DEBUG_PRINT("Scanning networks...");
    int wifi_nets = WiFi.scanNetworks(true, true);
    const uint32_t t = millis();
    while (wifi_nets < 0 &&
           millis() - t < 20000)
      delay(20);
      wifi_nets = WiFi.scanComplete();
    DEBUG_PRINT(String("Found networks: ") + wifi_nets);
    if (wifi_nets > 0) {
      // Sort networks
      int indices[wifi_nets];
      for (int i = 0; i < wifi_nets; i++) {
        indices[i] = i;
        for (int j = i + 1; j < wifi_nets; j++) {
          if (WiFi.RSSI(indices[j]) > WiFi.RSSI(indices[i])) {
            std::swap(indices[i], indices[j]);
      wifi_nets = BlynkMin(15, wifi_nets); // Show top 15 networks
      // TODO: skip empty names
      String result = "[\n";
      char buff[256];
      for (int i = 0; i < wifi_nets; i++){
        int id = indices[i];
        const char* sec;
        switch (WiFi.encryptionType(id)) {
        case WIFI_AUTH_WEP:          sec = "WEP"; break;
        case WIFI_AUTH_WPA_PSK:      sec = "WPA/PSK"; break;
        case WIFI_AUTH_WPA2_PSK:     sec = "WPA2/PSK"; break;
        case WIFI_AUTH_WPA_WPA2_PSK: sec = "WPA/WPA2/PSK"; break;
        case WIFI_AUTH_OPEN:         sec = "OPEN"; break;
        default:                     sec = "unknown"; break;
          R"json(  {"ssid":"%s","bssid":"%s","rssi":%i,"sec":"%s","ch":%i})json",
          WiFi.SSID(id).c_str(),
          WiFi.BSSIDstr(id).c_str(),
          WiFi.RSSI(id),
          sec,
          WiFi.channel(id)
        result += buff;
        if (i != wifi_nets-1) result += ",\n";
      server.send(200, "application/json", result + "\n]");
      server.send(200, "application/json", "[]");
  server.on("/reset", []() {
    server.send(200, "application/json", R"json({"status":"ok","msg":"Configuration reset"})json");
  server.on("/reboot", []() {
    restartMCU();
  if (SPIFFS.begin()) {
    server.serveStatic("/img/favicon.png", SPIFFS, "/img/favicon.png");
    server.serveStatic("/img/logo.png", SPIFFS, "/img/logo.png");
    server.serveStatic("/", SPIFFS, "/index.html");
    DEBUG_PRINT("Webpage: No SPIFFS");
#endif
  server.begin();
  while (BlynkState::is(MODE_WAIT_CONFIG) || BlynkState::is(MODE_CONFIGURING)) {
    dnsServer.processNextRequest();
    app_loop();
    if (BlynkState::is(MODE_WAIT_CONFIG) && WiFi.softAPgetStationNum() > 0) {
      BlynkState::set(MODE_CONFIGURING);
    } else if (BlynkState::is(MODE_CONFIGURING) && WiFi.softAPgetStationNum() == 0) {
      BlynkState::set(MODE_WAIT_CONFIG);
  server.stop();
  SPIFFS.end();
#endif
void enterConnectNet() {
  BlynkState::set(MODE_CONNECTING_NET);
  DEBUG_PRINT(String("Connecting to WiFi: ") + configStore.wifiSSID);
  char ssidBuff[64];
  String hostname(ssidBuff);
  hostname.replace(" ", "-");
  WiFi.setHostname(hostname.c_str());
  if (configStore.getFlag(CONFIG_FLAG_STATIC_IP)) {
    if (!WiFi.config(configStore.staticIP,
                    configStore.staticGW,
                    configStore.staticMask,
                    configStore.staticDNS,
                    configStore.staticDNS2)
      DEBUG_PRINT("Failed to configure Static IP");
      config_set_last_error(BLYNK_PROV_ERR_CONFIG);
      BlynkState::set(MODE_ERROR);
      return;
  WiFi.begin(configStore.wifiSSID, configStore.wifiPass);
  unsigned long timeoutMs = millis() + WIFI_NET_CONNECT_TIMEOUT;
  while ((timeoutMs > millis()) && (WiFi.status() != WL_CONNECTED))
    app_loop();
    if (!BlynkState::is(MODE_CONNECTING_NET)) {
      WiFi.disconnect();
      return;
  if (WiFi.status() == WL_CONNECTED) {
    IPAddress localip = WiFi.localIP();
      BLYNK_LOG_IP("Using Static IP: ", localip);
      BLYNK_LOG_IP("Using Dynamic IP: ", localip);
    BlynkState::set(MODE_CONNECTING_CLOUD);
    config_set_last_error(BLYNK_PROV_ERR_NETWORK);
void enterConnectCloud() {
  Blynk.config(configStore.cloudToken, configStore.cloudHost, configStore.cloudPort);
  Blynk.connect(0);
  unsigned long timeoutMs = millis() + WIFI_CLOUD_CONNECT_TIMEOUT;
        (!Blynk.isTokenInvalid()) &&
        (Blynk.connected() == false))
    app_loop();
    if (!BlynkState::is(MODE_CONNECTING_CLOUD)) {
      Blynk.disconnect();
      return;
  if (millis() > timeoutMs) {
    DEBUG_PRINT("Timeout");
  if (Blynk.isTokenInvalid()) {
    config_set_last_error(BLYNK_PROV_ERR_TOKEN);
  } else if (Blynk.connected()) {
    BlynkState::set(MODE_RUNNING);
    if (!configStore.getFlag(CONFIG_FLAG_VALID)) {
      configStore.last_error = BLYNK_PROV_ERR_NONE;
      config_save();
    config_set_last_error(BLYNK_PROV_ERR_CLOUD);
void enterSwitchToSTA() {
  DEBUG_PRINT("Switching to STA...");
  delay(100);
  WiFi.mode(WIFI_STA);
void enterError() {
  unsigned long timeoutMs = millis() + 10000;
//  while (timeoutMs > millis() || g_buttonPressed)
    app_loop();
    if (!BlynkState::is(MODE_ERROR)) {
      return;
  DEBUG_PRINT("Restarting after error.");
  restartMCU();
Settings.h
 * Board configuration (see examples below).
#if defined(USE_WROVER_BOARD)
  //#define BOARD_BUTTON_PIN            15
 // #define BOARD_BUTTON_ACTIVE_LOW     true
  #define BOARD_LED_PIN_R             0
  #define BOARD_LED_PIN_G             2
  #define BOARD_LED_PIN_B             4
  #define BOARD_LED_INVERSE           false
  #define BOARD_LED_BRIGHTNESS        128
#elif defined(CAMERA_MODEL_AI_THINKER)
#define PWDN_GPIO_NUM     32
#define RESET_GPIO_NUM    -1
#define XCLK_GPIO_NUM      0
#define SIOD_GPIO_NUM     26
#define SIOC_GPIO_NUM     27
#define Y9_GPIO_NUM       35
#define Y8_GPIO_NUM       34
#define Y7_GPIO_NUM       39
#define Y6_GPIO_NUM       36
#define Y5_GPIO_NUM       21
#define Y4_GPIO_NUM       19
#define Y3_GPIO_NUM       18
#define Y2_GPIO_NUM        5
#define VSYNC_GPIO_NUM    25
#define HREF_GPIO_NUM     23
#define PCLK_GPIO_NUM     22
#elif defined(USE_TTGO_T7)
  // This board does not have a built-in button
  // Connect a button to gpio0 <> GND
 #define BOARD_BUTTON_PIN            0
  #define BOARD_LED_PIN               19
  #define BOARD_LED_BRIGHTNESS        64
#else
  #warning "Custom board configuration is used"
  #define BOARD_BUTTON_PIN            0                     // Pin where user button is attached
 #define BOARD_BUTTON_ACTIVE_LOW     true                  // true if button is "active-low"
  #define BOARD_LED_PIN               4                     // Set LED pin - if you have a single-color LED attached
  #define BOARD_LED_PIN_R           15                    // Set R,G,B pins - if your LED is PWM RGB
  #define BOARD_LED_PIN_G           12
  #define BOARD_LED_PIN_B           13
  #define BOARD_LED_PIN_WS2812      4                     // Set if your LED is WS2812 RGB
  #define BOARD_LED_INVERSE           false                 // true if LED is common anode, false if common cathode
  #define BOARD_LED_BRIGHTNESS        64                    // 0..255 brightness control
#endif
 * Advanced options
#define BUTTON_HOLD_TIME_INDICATION   3000
#define BUTTON_HOLD_TIME_ACTION       10000
#define BOARD_PWM_MAX                 1023
#define BOARD_LEDC_CHANNEL_1     1
#define BOARD_LEDC_CHANNEL_2     2
#define BOARD_LEDC_CHANNEL_3     3
#define BOARD_LEDC_TIMER_BITS    10
#define BOARD_LEDC_BASE_FREQ     12000
#define CONFIG_AP_URL                 "blynk.setup"
#define CONFIG_DEFAULT_SERVER         "blynk.cloud"
#define CONFIG_DEFAULT_PORT           443
#define WIFI_NET_CONNECT_TIMEOUT      30000
#define WIFI_CLOUD_CONNECT_TIMEOUT    30000
#define WIFI_AP_IP                    IPAddress(192, 168, 4, 1)
#define WIFI_AP_Subnet                IPAddress(255, 255, 255, 0)
#define WIFI_CAPTIVE_PORTAL_ENABLE
//#define USE_TICKER
//#define USE_TIMER_ONE
//#define USE_TIMER_THREE
//#define USE_TIMER_FIVE
#define USE_PTHREAD
#define BLYNK_NO_DEFAULT_BANNER
#if defined(APP_DEBUG)
  #define DEBUG_PRINT(...) BLYNK_LOG1(__VA_ARGS__)
#else
#endif
camera_pins.h
#if defined(CAMERA_MODEL_WROVER_KIT)
#define PWDN_GPIO_NUM    -1
#define XCLK_GPIO_NUM    21
#define Y5_GPIO_NUM      19
#define Y4_GPIO_NUM      18
#define Y3_GPIO_NUM       5
#define Y2_GPIO_NUM       4
#elif defined(CAMERA_MODEL_ESP_EYE)
#define XCLK_GPIO_NUM    4
#define SIOD_GPIO_NUM    18
#define SIOC_GPIO_NUM    23
#define Y9_GPIO_NUM      36
#define Y8_GPIO_NUM      37
#define Y7_GPIO_NUM      38
#define Y6_GPIO_NUM      39
#define Y5_GPIO_NUM      35
#define Y4_GPIO_NUM      14
#define Y3_GPIO_NUM      13
#define Y2_GPIO_NUM      34
#define VSYNC_GPIO_NUM   5
#define HREF_GPIO_NUM    27
#define PCLK_GPIO_NUM    25
#elif defined(CAMERA_MODEL_M5STACK_PSRAM)
#define RESET_GPIO_NUM    15
#define XCLK_GPIO_NUM     27
#define SIOD_GPIO_NUM     25
#define Y9_GPIO_NUM       19
#define Y8_GPIO_NUM       36
#define Y7_GPIO_NUM       18
#define Y5_GPIO_NUM        5
#define Y4_GPIO_NUM       34
#define Y3_GPIO_NUM       35
#define Y2_GPIO_NUM       32
#define VSYNC_GPIO_NUM    22
#define HREF_GPIO_NUM     26
#define PCLK_GPIO_NUM     21
#elif defined(CAMERA_MODEL_M5STACK_WIDE)
#define SIOD_GPIO_NUM     22
#else
#error "Camera model not selected"
#endif
Camera_index.h is not listed here but can be if needed
Before creating the topic
  1. Search forum for similar topics
  2. Check http://docs.blynk.cc and http://help.blynk.cc/
  3. Add details :
    • Blynk Library version
    • Add your sketch code. :point_up:Code should be formatted as example below.
@drehawk please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
Thank you
Is this correctly formatted? I thought the backticks were backslashes. I could not find backticks so I copied them from the page and pasted them in front of and after my code. Please let me know if I still need to make corrections. Thank you.
Yes, correct now.
First of all, you should read this:
Secondly, you have no board type defined…
which means that the default board type, and the corresponding pin allocations will be used in Settings.h
You should check to see if any of these pins, or the variable names used in the Edgent example sketch, clash with anything you are using win your additional code.
I will read the link. Further, I attempted to define the board I am using “#define CAMERA_MODEL_AI_THINKER” That appears to be insufficient.
You clearly don’t understand how the board definitions work in the Edgent sketch.
I’d suggest that you study the standard ESP32 Edgent example and see how the board definitions in the .ino file relate to the Settings.h file, and how the default custom board configuration is used if none of the preceding #define tests are met in Settings.h
You are absolutely right. I clearly don’t understand how the board definitions work in the Edgent sketch. That is why I am here. With every piece of shrapnel, I learn, and wear my scars well. Again, I chose Blynk because my knowledge is negligible. I am forced to learn on the fly as there is a dearth of individuals in my area with this knowledge or with sufficient willingness to be paid to assist me. So, here I am.
Okay, in that case I’d suggest you do a bit of reading-up on how processor directives work in C++, then look at how the Settings.h file is structured. You’ll see that adding a #define CAMERA_MODEL_AI_THINKER line to your .ino file has no impact on the Settings.h file, unless you then add your own #if defined(CAMERA_MODEL_AI_THINKER) section to Settings.h
In the absence of any board definition in the .ino file that matches an entry in the Settings.h file then custom board configuration values will be used instead. These are (after removing the commented-out lines):
As you can see, GPIO 0 and GPIO 4 are used by the Edgent sketch, making them unavailable for use within your code, unless you make some changes.
Thank you, Pete. I am looking into these things right now.
In Settings.h I had
This called on PIN 0 which is already in use by Edgent for BOARD_BUTTON_PIN, which is also where I was having a problem.
A lot depends on where in Settings.h you put this.
Not necessarily. If you put the #elif defined(CAMERA_MODEL_AI_THINKER) code ion the correct place then pin 0 wouldn’t be defined as BOARD_BUTTON_PIN
However, if BOARD_BUTTON_PIN, BOARD_BUTTON_ACTIVE_LOW, BOARD_LED_PIN, BOARD_LED_INVERSE and BOARD_LED_BRIGHTNESS aren’t defined in your board definition then you’re likely to run into compilation issues.
Hi drehawk
You dont need to use BlynkEdgent.h for Blynk 2.0, you can just use BlynkSimpleEsp32.h
/Torben
Thank you. Part of what I am doing will entail going from location to location each with different WiFi setups. It is my understanding that the easiest way to connect to these different WiFi locations is to use Edgent. But, I am open to learning a different way.
Hi Drehawk
I see your issiue, but if you also use the SD card you have more less no pins left.
Check this out “ESP32-CAM AI-Thinker Pinout Guide: GPIOs Usage Explained | Random Nerd Tutorials”
and then folow Pete´s recipe and change pins
/Torben
WiFiManager is a possible alternative.
Thank you. I had already been looking at that and thinking about the extra pins if I don’t use an SD card.
Thanks. I will explore this as well.
