sorry for the incomplete info.
Yes i have attached a Push Button to Pin D1 and the relay out to pin D2 , And am using node mcu and also defined them in the code
const int TacSwitch1 = D1;
const int TestLED11 = D2;
void checkPhysicalButton();
int ledState = LOW;
int btnState = HIGH;
pinMode(TestLED1, OUTPUT); // Pin D2 P5 on board
pinMode(TacSwitch1, INPUT_PULLUP); // Pin D1 P1 on board
digitalWrite(TestLED1, LOW); // set LED OFF
digitalWrite(TacSwitch1, ledState);
this is just a few lines of the code so state that push button is defined.
later what i have done is in the setup part,
if (digitalRead(TestLED1) == LOW) {
if (btnState != LOW) {
// Toggle LED state
ledState = !ledState;
// Update Button Widget
Blynk.virtualWrite(V2, ledState);
btnState = LOW;
btnState = HIGH;
BLYNK_WRITE(V2) // ON-OFF Manual
if (ledState = param.asInt()) { //// here am missing out
//(param.asInt()==1) // boton encendido //////// this was how it was previously done
terminal.println();
terminal.println();
terminal.println();
terminal.println("Manual MODE is ON");
terminal.println("Press ON/OFF button if required");
terminal.println("Device is ON");
terminal.println();
terminal.println();
terminal.flush();
if (manual==0){ //estĂĄ en modo automĂĄtico
checklastbuttonpressed ();
manual=1;
mondayfriday=0;
saturdaysunday=0;
alldays=0;
uptoyou=0;
Blynk.virtualWrite(V1, 1);
Blynk.virtualWrite(V5, 0);
Blynk.virtualWrite(V7, 0);
Blynk.virtualWrite(V9, 0);
Blynk.virtualWrite(V11, 0);
digitalWrite(TestLED1, HIGH); // set LED ON
Blynk.virtualWrite(V2, 1); //Turn ON Button Widget
} else { //estĂĄ en modo manual
mondayfriday=0;
saturdaysunday=0;
alldays=0;
uptoyou=0;
}else {
terminal.println();
terminal.println();
terminal.println();
terminal.println("Device is OFF");
terminal.println();
terminal.println();
terminal.flush();
if (manual==0){ //modo automĂĄtico
manual=1;
mondayfriday=0;
saturdaysunday=0;
alldays=0;
uptoyou=0;
Blynk.virtualWrite(V2, 0); //Turn OFF Button Widget
mondayfriday=0;
saturdaysunday=0;
alldays=0;
uptoyou=0;
hardware part is completely working fine. The only problem is the code part.
and posting the complete edited code is not a problem. but it goes way too long. above i have mentioned the bits of code that i have injected to the @psoro code.
And below i will post the whole code .
* timeinput.ino Demonstrate interaction of Time library with
* Blynk's TimeInput widget.
* App project setup:
* RTC widget (no pin required!!!)
* V1 : Manual/Auto button
* V2: On-off button
* Terminal on V3 // Label will be the clock + wifi signal!!!!
* Time Input widget on V4 (Monday-Friday)
* Button selection for Time Input (Monday-Friday) on V5
* Time Input widget on V6 (Saturday-Sunday)
* Button selection for Time Input (Saturday-Sunday on V7
* Time Input widget on V8 (All days)
* Button selection for Time Input (All days) on V9
* Time Input widget on V10 (Up to you)
* Button selection for Time Input (Up to you) on V11
#include <TimeLib.h>
#include <WidgetRTC.h>
WidgetRTC rtc;
WidgetTerminal terminal(V3);
#define server "192.168.1.xxx" // or "blynk.cloud-com" for Blynk's cloud server
#define TestLED1 4 // pin assignment D2
char Date[16];
char Time[16];
char auth[] = "xxxxxxxxxxxxxx";
char ssid[] = "xxx";
char pass[] = "xxx";
long startsecondswd; // weekday start time in seconds
long stopsecondswd; // weekday stop time in seconds
long nowseconds; // time now in seconds
bool isFirstConnect = true;
String displaycurrenttimepluswifi;
int wifisignal;
int manual=0;
int oldstatus;
int mondayfriday;
int saturdaysunday;
int alldays;
int uptoyou;
const int TacSwitch1 = D1; //////////
const int TestLED11 = D2; ////////
int ledState = LOW;
Serial.println("\Starting");
// Blynk.begin(auth, ssid, pass, server);
Blynk.begin(auth, ssid, pass, IPAddress(192,168,1,xxx), 8080);
timer.setInterval(100L, checkPhysicalButton);
int mytimeout = millis() / 1000;
while (Blynk.connect() == false) { // try to connect to server for 10 seconds
if((millis() / 1000) > mytimeout + 8){ // try local server if not connected within 9 seconds
break;
rtc.begin();
timer.setInterval(10000L, activetoday); // check every 10 SECONDS if schedule should run today
timer.setInterval(30000L, reconnectBlynk); // check every 30s if still connected to server
timer.setInterval(5000L, clockvalue); // check value for time
timer.setInterval(5000L, sendWifi); // Wi-Fi singal
BLYNK_CONNECTED() {
if (isFirstConnect) {
Blynk.syncAll();
Blynk.notify("TIMER STARTING!!!!");
isFirstConnect = false;
void sendWifi() {
wifisignal = map(WiFi.RSSI(), -105, -40, 0, 100);
void clockvalue() // Digital clock display of the time
int gmthour = hour();
if (gmthour == 24){
gmthour = 0;
String displayhour = String(gmthour, DEC);
int hourdigits = displayhour.length();
if(hourdigits == 1){
displayhour = "0" + displayhour;
String displayminute = String(minute(), DEC);
int minutedigits = displayminute.length();
if(minutedigits == 1){
displayminute = "0" + displayminute;
displaycurrenttimepluswifi = " Clock: " + displayhour + ":" + displayminute + " Signal: " + wifisignal +" %";
Blynk.setProperty(V3, "label", displaycurrenttimepluswifi);
void activetoday(){ // check if schedule should run today
if(year() != 1970){
if (mondayfriday==1) {
Blynk.syncVirtual(V4); // sync timeinput widget
if (saturdaysunday==1) {
Blynk.syncVirtual(V6); // sync timeinput widget
if (alldays==1) {
Blynk.syncVirtual(V8); // sync timeinput widget
if (uptoyou==1) {
Blynk.syncVirtual(V10); // sync timeinput widget
void checklastbuttonpressed (){
if((mondayfriday==1)&&(saturdaysunday==0)){ oldstatus=1; }
if((mondayfriday==0)&&(saturdaysunday==1)){ oldstatus=2; }
if((mondayfriday==1)&&(saturdaysunday==1)){ oldstatus=3; }
if(alldays==1){ oldstatus=4; }
if(uptoyou==1){ oldstatus=5; }
if((mondayfriday==0)&&(saturdaysunday==0)&&(alldays==0)&&(uptoyou==0)){ oldstatus=6; }
void restorelastbuttonpressed (){
if(oldstatus==1){ mondayfriday=1; Blynk.virtualWrite(V5, 1); }
if(oldstatus==2){ saturdaysunday=1 ; Blynk.virtualWrite(V7, 1); }
if(oldstatus==3){ saturdaysunday=1; mondayfriday=1;Blynk.virtualWrite(V5, 1);Blynk.virtualWrite(V7, 1); }
if(oldstatus==4){ alldays=1; Blynk.virtualWrite(V9, 1);}
if(oldstatus==5){ uptoyou=1; Blynk.virtualWrite(V11, 1);}
if(oldstatus==6){
mondayfriday=0;
saturdaysunday=0;
alldays=0;
uptoyou=0;
BLYNK_WRITE(V1) // Manual/Auto selection
if (param.asInt()==1) {
manual=1;
terminal.println();
terminal.println();
terminal.println();
terminal.println();
terminal.println();
terminal.println();
terminal.flush();
alldays=0;
uptoyou=0;
mondayfriday=0;
saturdaysunday=0;
restorelastbuttonpressed ();
manual=0;
terminal.println();
terminal.println();
terminal.println();
terminal.println("Manual MODE is OFF");
terminal.println("Auto MODE restored from last status");
terminal.println("Wait for update (10 seconds as maximum)");
terminal.println();
terminal.println();
terminal.flush();
void resetTerminal()
terminal.println();
terminal.println();
terminal.println();
terminal.println("New MODE has been selected");
terminal.println();
terminal.println();
terminal.println();
terminal.flush();
void resetManual()
Blynk.virtualWrite(V1, 0); //Turn OFF Manual Mode Widget
Blynk.virtualWrite(V2, 0); //Turn OFF Button Widget Device
// Toggle LED state
btnState = LOW;
btnState = HIGH;
terminal.println();
terminal.println();
terminal.println();
terminal.println();
terminal.println();
terminal.flush();
manual=1;
mondayfriday=0;
saturdaysunday=0;
alldays=0;
uptoyou=0;
mondayfriday=0;
saturdaysunday=0;
alldays=0;
uptoyou=0;
}else {
terminal.println();
terminal.println();
terminal.println();
terminal.println();
terminal.println();
terminal.flush();
manual=1;
mondayfriday=0;
saturdaysunday=0;
alldays=0;
uptoyou=0;
mondayfriday=0;
saturdaysunday=0;
alldays=0;
uptoyou=0;
BLYNK_WRITE(V5) // Monday-Friday selected
if (param.asInt()==1 && (V1==1)) {
timer.setTimeout(50, resetTerminal);
timer.setTimeout(50, resetManual);
timer.setTimeout(50, checklastbuttonpressed);
mondayfriday=1;
alldays=0;
uptoyou=0;
mondayfriday=0;
BLYNK_WRITE(V7) // Saturday-Sunday selected
saturdaysunday=1;
alldays=0;
uptoyou=0;
saturdaysunday=0;
BLYNK_WRITE(V9) // All days selected
alldays=1;
mondayfriday=0;
saturdaysunday=0;
uptoyou=0;
alldays=0;
BLYNK_WRITE(V11) // Up to you selected
uptoyou=1;
mondayfriday=0;
saturdaysunday=0;
alldays=0;
uptoyou=0;
BLYNK_WRITE(V4)//Monday-Friday
sprintf(Date, "%02d/%02d/%04d", day(), month(), year());
TimeInputParam t(param);
terminal.print("M-F Checked schedule at: ");
terminal.println(Time);
terminal.flush();
int dayadjustment = -1;
if(weekday() == 1){
dayadjustment = 6; // needed for Sunday, Time library is day 1 and Blynk is day 7
if(t.isWeekdaySelected(weekday() + dayadjustment)){ //Time library starts week on Sunday, Blynk on Monday
terminal.println("Monday-Friday ACTIVE today");
terminal.flush();
if (t.hasStartTime()) // Process start time
terminal.println(String("Start: ") + t.getStartHour() + ":" + t.getStartMinute());
terminal.flush();
if (t.hasStopTime()) // Process stop time
terminal.println(String("Stop : ") + t.getStopHour() + ":" + t.getStopMinute());
terminal.flush();
// Display timezone details, for information purposes only
terminal.println(String("Time zone: ") + t.getTZ()); // Timezone is already added to start/stop time
// terminal.println(String("Time zone offset: ") + t.getTZ_Offset()); // Get timezone offset (in seconds)
terminal.flush();
for (int i = 1; i <= 7; i++) { // Process weekdays (1. Mon, 2. Tue, 3. Wed, ...)
if (t.isWeekdaySelected(i)) {
terminal.println(String("Day ") + i + " is selected");
terminal.flush();
nowseconds = ((hour() * 3600) + (minute() * 60) + second());
startsecondswd = (t.getStartHour() * 3600) + (t.getStartMinute() * 60);
//Serial.println(startsecondswd); // used for debugging
if(nowseconds >= startsecondswd){
terminal.print("Monday-Friday STARTED at");
terminal.println(String(" ") + t.getStartHour() + ":" + t.getStartMinute());
terminal.flush();
if(nowseconds <= startsecondswd + 90){ // 90s on 60s timer ensures 1 trigger command is sent
// code here to switch the relay ON
else{
terminal.println("Monday-Friday Device NOT STARTED today");
terminal.flush();
stopsecondswd = (t.getStopHour() * 3600) + (t.getStopMinute() * 60);
//Serial.println(stopsecondswd); // used for debugging
if(nowseconds >= stopsecondswd){
terminal.print("Monday-Friday STOPPED at");
terminal.println(String(" ") + t.getStopHour() + ":" + t.getStopMinute());
terminal.flush();
if(nowseconds <= stopsecondswd + 90){ // 90s on 60s timer ensures 1 trigger command is sent
// code here to switch the relay OFF
else{
digitalWrite(TestLED1, HIGH); // set LED ON test
terminal.println("Monday-Friday is ON");
terminal.flush();
else{
terminal.println("Monday-Friday INACTIVE today");
terminal.flush();
// nothing to do today, check again in 30 SECONDS time
terminal.println();
BLYNK_WRITE(V6) //Saturday-Sunday
terminal.print("S-S Checked schedule at: ");
terminal.flush();
if(weekday() == 1){
terminal.println("Saturday-Sunday ACTIVE today");
terminal.flush();
terminal.flush();
terminal.flush();
terminal.flush();
terminal.flush();
terminal.print("Saturday-Sunday STARTED at");
terminal.flush();
else{
terminal.println("Saturday-Sunday NOT STARTED today");
terminal.flush();
terminal.print("Saturday-Sunday STOPPED at");
terminal.flush();
else{
digitalWrite(TestLED1, HIGH); // set LED ON TEST
terminal.println("Saturday-Sunday is ON");
terminal.flush();
else{
terminal.println("Saturday-Sunday INACTIVE today");
terminal.flush();
terminal.println();
BLYNK_WRITE(V8)//All days
if (alldays==1) {
terminal.print("All Days Checked schedule at: ");
terminal.flush();
if(weekday() == 1){
terminal.println("ALL DAYS ACTIVE today");
terminal.flush();
terminal.flush();
terminal.flush();
terminal.flush();
terminal.flush();
terminal.print("ALL DAYS STARTED at");
terminal.flush();
else{
terminal.println("All Day Device NOT STARTED today");
terminal.flush();
terminal.print("All day STOPPED at");
terminal.flush();
else{
digitalWrite(TestLED1, HIGH); // set LED ON TEST!!!!!
terminal.println("All day is ON");
terminal.flush();
else{
terminal.println("All day INACTIVE today");
terminal.flush();
terminal.println();
BLYNK_WRITE(V10)//Up to you
if (uptoyou==1) {
terminal.print("Up to you Checked schedule at: ");
terminal.flush();
if(weekday() == 1){
terminal.println("Up to you ACTIVE today");
terminal.flush();
terminal.flush();
terminal.flush();
terminal.println("At least ONE day MUST be selected");
terminal.flush();
terminal.flush();
terminal.print("Up to you STARTED at");
terminal.flush();
else{
terminal.println("UP to you Device NOT STARTED today");
terminal.flush();
terminal.print("Up to you STOPPED at");
terminal.flush();
else{
terminal.println("Up to you is ON");
terminal.flush();
else{
terminal.println("Up to you INACTIVE today");
terminal.flush();
terminal.println();
void reconnectBlynk() {
if (!Blynk.connected()) {
if(Blynk.connect()) {
BLYNK_LOG("Reconnected");
BLYNK_LOG("Not reconnected");
if (Blynk.connected()) {
triggering the V2 that is the on/off button widget will bring the program into manual mode and work untill we choose auto in the Blynk app. Thats the end game. Because physical button comes in handy.
