Wemos d1 mini clone with wifi
Andriod
Local server
The joystick works okay. But drops connection making the car stuck on 1 command like “forward” for some time
#define BLYNK_TEMPLATE_ID "TMPLRIRidq5R"
#define BLYNK_DEVICE_NAME "Car"
#define BLYNK_AUTH_TOKEN ""
#define ipconfig ""
#define port 8080
#define leftMotor 5 // D3
#define rightMotor 14 //D4
int x=0;
int y=0;
int Speed;
char auth[] = BLYNK_AUTH_TOKEN; //Enter your Blynk auth token
char ssid[] = "srh-welcome"; //Enter your WIFI name
char pass[] = ""; //Enter your WIFI passowrd
pinMode(leftMotor, OUTPUT);
pinMode(rightMotor, OUTPUT);
digitalWrite(leftMotor, HIGH);
digitalWrite(rightMotor, HIGH);
Blynk.begin(auth, ssid, pass, ipconfig, 8080);
BLYNK_WRITE(V0) {
x = param[0].asInt();
y = param[1].asInt();
//Get the slider values
BLYNK_WRITE(V2) {
Speed = param.asInt();
void car() {
if (x==0 && y==0){
stopda();
}else
if (y > 1) {
forward();
Serial.println("carForward");
} else
if (y < -1) {
stopda();
Serial.println("stop!");
} else
if (x < -1) {
left();
Serial.println("carLeft");
} else
if (x > 1) {
right();
Serial.println("carRight");
} else
if(y<=1 && y >=-1 && x>=-1 && x <=1) {
stopda();
Serial.println("carstop");
} else{}
Blynk.run();// Run the blynk function
delay(100);
car();// Call the main function
void forward(){
digitalWrite(leftMotor,LOW);
digitalWrite(rightMotor,LOW);
void left(){
digitalWrite(leftMotor,HIGH);
void right(){
digitalWrite(rightMotor,HIGH);
void stopda(){
Simply paste your code between ``` If you don't format your code, your topic can be deleted by moderators.
