Hello. I’m using Arduino Nano, with HC-06. I don’t have any shields. On my phone i have the latest version of app. Anroid, btw. Also in my project I have latest Blynk library. I’m not using any local servers or something else. So HC-06 works properly, i tried it in other project without Blynk. But when I’m using any code from example, i don’t receive anything from arduino. For example, i have code like this:
http://twitter.com/blynk_app
Note: This only works on Android!
iOS does not support Bluetooth 2.0 Serial Port Profile
You may need to pair the module with your smartphone
via Bluetooth settings. Default pairing password is 1234
NOTE: Bluetooth support is in beta!
You can send/receive any data using WidgetTerminal object.
App project setup:
Terminal widget attached to Virtual Pin V1
char auth[] = "MyToken here, yes, i didn't forget to change it";
SoftwareSerial SerialBLE(10, 11); // RX, TX
// Attach virtual serial terminal to Virtual Pin V1
WidgetTerminal terminal(V1);
// You can send commands from Terminal to your hardware. Just use
// the same Virtual Pin as your Terminal Widget
BLYNK_WRITE(V1)
// if you type "Marco" into Terminal Widget - it will respond: "Polo:"
if (String("Marco") == param.asStr()) {
terminal.println("You said: 'Marco'") ;
terminal.println("I said: 'Polo'") ;
// Send it back
terminal.print("You said:");
terminal.write(param.getBuffer(), param.getLength());
terminal.println();
// Ensure everything is sent
terminal.flush();
SerialBLE.begin(9600);
Blynk.begin(SerialBLE, auth);
// This will print Blynk Software version to the Terminal Widget when
// your hardware gets connected to Blynk Server
terminal.println(F("Blynk v" BLYNK_VERSION ": Device started"));
terminal.println(F("-------------"));
terminal.println(F("Type 'Marco' and get a reply, or type"));
terminal.println(F("anything else and get it printed back."));
terminal.flush();
Thx for help, I didn’t noticed that. I just copied that from example. But why is that in examples? Looks strange. So i deleted other things, but it still doesn’t work:
App project setup:
char auth[] = "authkey";
BLYNK_WRITE(V1)
// Send it back
terminal.println();
terminal.flush();
terminal.flush();
Okey, I noticed that code from example is for BLE, but HC-06 doesn’t support it. I took code from that example:
And now it’s looks like that:
App project setup:
char auth[] = "931cf63a5d0a4af1b4c5405f51e1caa3";
BLYNK_WRITE(V1)
// Send it back
terminal.println();
terminal.flush();
Blynk.begin(Serial, auth);
terminal.flush();
But it still doesn’t work. Thats what it’s saying in terminal:
