Hey there,
It’s late and I’m at my whits end, so I’m hoping one of you fine people might know something I don’t.
I have a Blynk local server setup on a Raspberry Pi Zero W. It was setup running server-0.28.3-java8.jar but I just downloaded and tested 0.29.3-java8 and it works as well.
The Blynk app is running on my phone, and I am able to use a button setup on it for my ESP (it opens my garage door).
The two issues I’m having (and solving either one should suffice):
- Setting up a shortcut on my android homescreen for the button doesn’t work. It lets me select the button I want to assign it to, but when I hit it, nothing.
- I can’t get webhooks to work. I would setup IFTTT or something elsewise to get around the above problem. I think it’s a port problem…?
I think I read that the home-screen button doesn’t work for local servers, but then I saw a more recent post showing that it did?
For the other issue:
Here is what I have:
http://mydomain.com:8443/CORRECTKEYHERE/pin/V7
ports 8441, 8442, 8443 are forwarding on my router…
I access /admin on port 9443
So, ignoring the possibility of my router issue happening, should I be able to do this:
open http://192.168.1.19:8443/CORRECTKEYHERE/pin/V7 in a browser, and have it open my garage
any help would be appreciated, Thank you.
