There are very few Tiva-C posts, and I have been unable to read a button push on the board.
- Tiva-C EK-TM4C129XL
- Blynk library V0.4.8
- Running local server (awesome idea). server-0.28.0-java8
- Energia version 1.6.10E18
- Energia is configured for “Board: “LaunchPad (Tiva-C) w/tm4c129 (120 MHz)””
- Android tablet (version 4.4.2)
- My shoe size is: 10.
I have four button widgets that control the four LEDs on the board. No problem controlling those, so I feel comfortable the tablet, server, and board are talking. I have a LED widget on V3, and have tried several of the example projects on reading a GPIO pin and pushing it via a virtual connection (including using interrupts, which interestingly caused the server to disconnect from the board - another problem for another day).
I settled on polling the button, using the example project modified for my use of a local server. Energia did not like compiling using the symbolic designation of the button (PJ0), so I used the pin number called out on the schematic (116).
My expectation is that a button push will change the state of the LED widget on the tablet. That does not happen.
My code below (I hope I am pasting it correctly, and may fail on that part of posting instructions).
Thank you for any insights.
Social networks: http://www.fb.com/blynkapp
http://twitter.com/blynk_app
This example shows how to use Energia with Ethernet
to connect your project to Blynk. Tested with:
TI LaunchPad (Tiva C) w/ tm4c129
Requires Energia IDE: http://energia.nu/download/
#include <Blynk.h>
#include <Ethernet.h>
#include <BlynkSimpleEnergiaEthernet.h>
char auth[] = "f89a81b91a0c4dc2958dd31d0a0361e2";
// Select your pin with physical button
const int btnPin1 = 116;
const int btnPin2 = 117;
int prevState = -1;
int currState = -1;
long lastChangeTime = 0;
void checkPin()
// Invert state, since button is "Active LOW"
int state = !digitalRead(btnPin1);
// Debounce mechanism
long t = millis();
if (state != prevState) {
lastChangeTime = t;
if (t - lastChangeTime > 50) {
if (state != currState) {
currState = state;
Blynk.virtualWrite(V3, state);
prevState = state;
//Running Blynke server locally on Raspberry Pi2
Blynk.begin(auth, IPAddress(192,168,1,105), 8442);
// Make push button switch pins default HIGH
pinMode(btnPin1, INPUT_PULLUP);
pinMode(btnPin2, INPUT_PULLUP);
checkPin();
