Before creating the topic
- Search forum for similar topics
- Check http://docs.blynk.cc and http://help.blynk.cc/
- Add details :
• Blynk Library version
• Add your sketch code.
Code should be formatted as example below.
Does the app work from your phone?
Can you login, create a blank project?
yes, i have account in the app
and create my project with arduino uno & ethernet shield but it always offline
Blynk-cloud is probably working just fine than.
I’d repost this question as “Trouble connecting with Arduino w/ Eth sheild”
Post the sketch you are using. Maybe add the comment you are in syria.
‘‘Sorry, new users can only put 2 links in a post’’
I don`t know how to post the sketch and i tried.
anyway we are connecting to the internet by ‘‘ADSL’’
and my speed is 2mbit … is this enough
my code is just like that from examples
i’ve added my auth token; it was send to mail
I am not a programming expert but I have instructions from YouTube
There are dozens and dozens of threads on the forum about getting your hardware combination to work. Problems are mostly around using too high a baud rate with SoftwareSerial, not having your ESP-01 set to use the correct (same) baud rate, not crossing the Rx and Tx connections between the Arduino and ESP-01 or not having a suitable separate power supply for the ESP-01.
Do some searching and some experimentation and you’ll come up with an answer.
