@Keroronsk with WiFIManager it’s quite normal to see token size of “33” characters because I believe the way the library is written if you use 32 characters it will be 1 character short. But that is if you are actually entering the token via WiFi Manager which I don’t think you are.
Don’t paste code on external sites.
I have added 3 lines of code to your sketch before Blynk.config(). Look closely what Serial Monitor shows you for these 3 lines. Should be like >fhfjftssdwdwdwdfjjdfdjfjd< with no spaces.
#include <FS.h>
#include <Arduino.h>
#include <ESP8266WiFi.h> //https://github.com/esp8266/Arduino
// Wifi Manager
#include <DNSServer.h>
#include <ESP8266WebServer.h>
#include <WiFiManager.h> //https://github.com/tzapu/WiFiManager
// HTTP requests
#include <ESP8266HTTPClient.h>
// OTA updates
#include <ESP8266httpUpdate.h>
// Blynk
// JSON
#include <ArduinoJson.h> //https://github.com/bblanchon/ArduinoJson
// GPIO Defines
#define I2C_SDA 5 // D1 Orange
#define I2C_SCL 4 // D2 Yellow
// Humidity/Temperature SI7021
//#include <SI7021.h>
//SI7021 si7021;
#include <Wire.h>
// Pressure and Temperature
#include <Adafruit_BMP085.h>
// Use U8g2 for i2c OLED Lib
#include <U8g2lib.h>
U8G2_SSD1306_128X64_NONAME_F_SW_I2C u8g2(U8G2_R0, I2C_SCL, I2C_SDA, U8X8_PIN_NONE);
byte x {0};
byte y {0};
// Handy timers
// CO2 SERIAL
#define DEBUG_SERIAL Serial1
#define SENSOR_SERIAL Serial
#define BLYNK_PRINT Serial1 // Defines the object that is used for printing
#define BLYNK_DEBUG // Optional, this enables more detailed prints
byte cmd[9] = {0xFF,0x01,0x86,0x00,0x00,0x00,0x00,0x00,0x79};
unsigned char response[7];
// Pressure and temperature
Adafruit_BMP085 bme;
// Blynk token
char blynk_token[33] {"******************************c6e204"};
//char blynk_server[64] {"blynk-cloud.com"};
char blynk_server[64] {"192.168.1.243"};
const uint16_t blynk_port {8442};
// Device Id
char device_id[17] = "Keroro CO2";
const char fw_ver[17] = "0.1.1";
// Handy timer
// Setup Wifi connection
WiFiManager wifiManager;
// Network credentials
String ssid { "ku_" + String(ESP.getChipId())};
String pass {"ku_" + String(ESP.getFlashChipId()) };
//flag for saving data
bool shouldSaveConfig = false;
// Sensors data
int t {-100};
int p {-1};
int h {-1};
int co2 {-1};
char loader[4] {'.'};
//callback notifying the need to save config
void saveConfigCallback() {
DEBUG_SERIAL.println("Should save config");
shouldSaveConfig = true;
void factoryReset() {
wifiManager.resetSettings();
SPIFFS.format();
ESP.reset();
void printString(String str) {
DEBUG_SERIAL.println(str);
void readCO2() {
// CO2
bool header_found {false};
char tries {0};
SENSOR_SERIAL.write(cmd, 9);
memset(response, 0, 7);
// Looking for packet start
while(SENSOR_SERIAL.available() && (!header_found)) {
if(SENSOR_SERIAL.read() == 0xff ) {
if(SENSOR_SERIAL.read() == 0x86 ) header_found = true;
if (header_found) {
SENSOR_SERIAL.readBytes(response, 7);
byte crc = 0x86;
for (char i = 0; i < 6; i++) {
crc+=response[i];
crc = 0xff - crc;
crc++;
if ( !(response[6] == crc) ) {
DEBUG_SERIAL.println("CO2: CRC error: " + String(crc) + " / "+ String(response[6]));
unsigned int responseHigh = (unsigned int) response[0];
unsigned int responseLow = (unsigned int) response[1];
unsigned int ppm = (256*responseHigh) + responseLow;
co2 = ppm;
DEBUG_SERIAL.println("CO2:" + String(co2));
DEBUG_SERIAL.println("CO2: Header not found");
void sendMeasurements() {
//Serial.println("Hello World!");
// Read data
// Temperature
//float tf = si7021.getCelsiusHundredths() / 100.0;
float t2f =bme.readTemperature();
t = static_cast<int>((t2f));
//t = static_cast<int>((tf + t2f) / 2);
// Humidity
//h = si7021.getHumidityPercent();
// Pressure (in mmHg)
p = static_cast<int>(bme.readPressure() * 760.0 / 101325);
// CO2
readCO2();
// Send to server
Blynk.virtualWrite(V1, t);
//Blynk.virtualWrite(V2, h);
Blynk.virtualWrite(V4, p);
Blynk.virtualWrite(V5, co2);
// Write to debug console
//printString("H: " + String(h) + "%");
printString("T: " + String(t) + "C");
printString("P: " + String(p) + "mmHg");
printString("CO2: " + String(co2) + "ppm");
void loading() {
long unsigned int count {(millis() / 500) % 4};
memset(loader, '.', count);
memset(&loader[count], 0, 1);
void draw() {
u8g2.clearBuffer();
// CO2
if (co2 > -1) {
char co2a [5];
sprintf (co2a, "%i", co2);
u8g2.setFont(u8g2_font_inb19_mf);
x = (128 - u8g2.getStrWidth(co2a))/2;
y = u8g2.getAscent() - u8g2.getDescent();
u8g2.drawStr(x, y, co2a);
const char ppm[] {"ppm CO2"};
u8g2.setFont(u8g2_font_6x12_mf);
x = (128 - u8g2.getStrWidth(ppm)) / 2;
y = y + 2 + u8g2.getAscent() - u8g2.getDescent();
u8g2.drawStr(x, y, ppm);
loading();
x = (128 - u8g2.getStrWidth(loader)) / 2;
u8g2.drawStr(x, y, loader);
// Cycle other meauserments
String measurement {"..."};
const char degree {176};
// Switch every 3 seconds
switch((millis() / 3000) % 3) {
case 0:
if (t > -100) { measurement = "T: " + String(t) + degree + "C"; }
break;
case 1:
if (h > -1) { measurement = "H: " + String(h) + "%"; }
break;
default:
if (p > -1) { measurement = "P: " + String(p) + " mmHg"; }
char measurementa [12];
measurement.toCharArray(measurementa, 12);
u8g2.setFont(u8g2_font_9x18_mf);
x = (128 - u8g2.getStrWidth(measurementa))/2;
y = 64 + u8g2.getDescent();
u8g2.drawStr(x, y, measurementa);
u8g2.sendBuffer();
void drawBoot(String msg = "Loading...") {
u8g2.clearBuffer();
x = (128 - u8g2.getStrWidth(msg.c_str())) / 2;
y = 32 + u8g2.getAscent() / 2;
u8g2.drawStr(x, y, msg.c_str());
u8g2.sendBuffer();
void drawConnectionDetails(String ssid, String pass, String url) {
String msg {""};
u8g2.clearBuffer();
msg = "Connect to WiFi:";
u8g2.setFont(u8g2_font_7x13_mf);
msg = "net: " + ssid;
y = y + 1 + u8g2.getAscent() - u8g2.getDescent();
msg = "pw: "+ pass;
msg = "Open browser:";
// URL
// u8g2.setFont(u8g2_font_6x12_mf);
x = (128 - u8g2.getStrWidth(url.c_str())) / 2;
u8g2.drawStr(x, y, url.c_str());
u8g2.sendBuffer();
bool loadConfig() {
File configFile = SPIFFS.open("/config.json", "r");
if (!configFile) {
DEBUG_SERIAL.println("Failed to open config file");
return false;
size_t size = configFile.size();
if (size > 1024) {
DEBUG_SERIAL.println("Config file size is too large");
return false;
// Allocate a buffer to store contents of the file.
std::unique_ptr<char[]> buf(new char[size]);
// We don't use String here because ArduinoJson library requires the input
// buffer to be mutable. If you don't use ArduinoJson, you may as well
// use configFile.readString instead.
configFile.readBytes(buf.get(), size);
StaticJsonBuffer<200> jsonBuffer;
JsonObject &json = jsonBuffer.parseObject(buf.get());
if (!json.success()) {
DEBUG_SERIAL.println("Failed to parse config file");
return false;
// Save parameters
strcpy(device_id, json["device_id"]);
strcpy(blynk_token, json["blynk_token"]);
void configModeCallback (WiFiManager *wifiManager) {
String url {"http://192.168.4.1"};
printString("Connect to WiFi:");
printString("net: " + ssid);
printString("pw: "+ pass);
printString("Open browser:");
printString(url);
printString("to setup device");
drawConnectionDetails(ssid, pass, url);
void setupWiFi() {
//set config save notify callback
wifiManager.setSaveConfigCallback(saveConfigCallback);
// Custom parameters
WiFiManagerParameter custom_device_id("device_id", "Device name", device_id, 16);
WiFiManagerParameter custom_blynk_server("blynk_server", "Blynk server", blynk_server, 64);
WiFiManagerParameter custom_blynk_token("blynk_token", "Blynk token", blynk_token, 34);
wifiManager.addParameter(&custom_blynk_server);
wifiManager.addParameter(&custom_blynk_token);
wifiManager.addParameter(&custom_device_id);
// wifiManager.setTimeout(180);
wifiManager.setAPCallback(configModeCallback);
if (!wifiManager.autoConnect(ssid.c_str(), pass.c_str())) {
DEBUG_SERIAL.println("failed to connect and hit timeout");
//save the custom parameters to FS
if (shouldSaveConfig) {
DEBUG_SERIAL.println("saving config");
DynamicJsonBuffer jsonBuffer;
JsonObject &json = jsonBuffer.createObject();
json["device_id"] = custom_device_id.getValue();
json["blynk_server"] = custom_blynk_server.getValue();
json["blynk_token"] = custom_blynk_token.getValue();
File configFile = SPIFFS.open("/config.json", "w");
if (!configFile) {
DEBUG_SERIAL.println("failed to open config file for writing");
json.printTo(DEBUG_SERIAL);
json.printTo(configFile);
configFile.close();
//end save
DEBUG_SERIAL.println("WiFi connected");
DEBUG_SERIAL.print("IP address: ");
DEBUG_SERIAL.println(WiFi.localIP());
//DEBUG_SERIAL.print("GATEWAY: ");
//DEBUG_SERIAL.println(WiFi.gateway());
// Virtual pin update FW
BLYNK_WRITE(V22) {
if (param.asInt() == 1) {
DEBUG_SERIAL.println("Got a FW update request");
char full_version[34] {""};
strcat(full_version, device_id);
strcat(full_version, "::");
strcat(full_version, fw_ver);
t_httpUpdate_return ret = ESPhttpUpdate.update("http://keroronsk.name/get", full_version);
switch (ret) {
case HTTP_UPDATE_FAILED:
DEBUG_SERIAL.println("[update] Update failed.");
break;
case HTTP_UPDATE_NO_UPDATES:
DEBUG_SERIAL.println("[update] Update no Update.");
break;
case HTTP_UPDATE_OK:
DEBUG_SERIAL.println("[update] Update ok.");
break;
// Virtual pin reset settings
BLYNK_WRITE(V23) {
factoryReset();
// Init serial ports
//Serial.begin(9600);
DEBUG_SERIAL.begin(115200);
SENSOR_SERIAL.begin(9600);
SENSOR_SERIAL.swap(); // GPIO15 (TX) and GPIO13 (RX)
// Init I2C interface
Wire.begin(I2C_SDA, I2C_SCL);
// Init display
u8g2.begin();
drawBoot();
// Init Humidity/Temperature sensor
//si7021.begin(I2C_SDA, I2C_SCL);
// Init Pressure/Temperature sensor
if (!bme.begin()) {
DEBUG_SERIAL.println("Could not find a valid BMP085 sensor, check wiring!");
// Init filesystem
if (!SPIFFS.begin()) {
DEBUG_SERIAL.println("Failed to mount file system");
ESP.reset();
// Setup WiFi
setupWiFi();
// Load config
drawBoot();
if (!loadConfig()) {
DEBUG_SERIAL.println("Failed to load config");
factoryReset();
DEBUG_SERIAL.println("Config loaded");
// Start blynk
DEBUG_SERIAL.print(">");
DEBUG_SERIAL.print(blynk_token);
DEBUG_SERIAL.println("<");
Blynk.config(blynk_token, blynk_server, blynk_port);
// Setup a function to be called every 10 second
timer.setInterval(10000L, sendMeasurements);
sendMeasurements();
draw();
