Timezone / Location. How do I set my time zone correctly?
A permanent time difference of 3 or more hours. I tried different options. Setup is one of these options.
local.setPosix(F("Europe/Moscow"));
  local.setLocation(F("Europe/Moscow"));
  local.setTime(10800);
char *t_zone[4] = {"tz_name", "iso",  "tz", "tz_rule"};
   Blynk.sendInternal("utc", "time");      // Unix timestamp (with msecs)
   Blynk.sendInternal("utc", t_zone[mass]);
I change these values. There is always a difference of 3 hours. How and where to choose a time zone?
BLYNK_WRITE(InternalPinUTC) {
    String cmd = param[0].asStr();
    if (cmd == "time") {
        uint64_t utc_time = param[1].asLongLong();
         UTC.setTime(utc_time / 1000, utc_time % 1000);
 //   else if (cmd == "iso") {
  //      String iso_time = param[1].asStr();
  else if (cmd == "tz") {
        String tz_offset = param[1].asStr();
        long dst_offset = param[2].asInt();
    else if (cmd == "tz_name") {
        String tz_name = param[1].asStr();
   else if (cmd == "tz_rule") {
        String tz_rule = param[1].asStr();
@hugiboss317 Please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
