I observed the Timer Widget shows 1 hour ahead after switching to European Summer Time.
If I select in Widget ex. 20:00, Time add 1 hour and show 21:00.
Widget Timezone do not calculate Summer/Winter time or Blynk Server need adjustment.for time.
Same problem here in Finland after time switch last night. Using local server in a Docker container and host OS is in UTC time.
edit: Everything works just fine. It’s just the widget showing incorrect time (+1h) after selecting a time.
Thanks for reporting. We will take a look. This is Android, right?
I have the same problem. Android 8.1.0
Android 7 / Samsung S7
Yes, I’m using Android 8.0.0. I give you a clue. I set Timer Widget to 21:00 (choose 20:00, but Widget shows 21:00 after OK).
Then the Timer activates at 19:00. 2 hours different. Maybe the Timezone is involved.
For Denmark Timezone is UTC +2 at winter but UTC +1 in summer. Hope it helps.
Hi.
Is this solved? I got an issue, timer is not setting virtual pin but shows time correctly.
