Timer widget - does the app need to be running?
Hiya,
Thanks to the Blynk guys for the new iOS update! The new timer get is cool, but I have a question - it seems that the timer will only switch things on or off while the app is open and the project is running. Is this right? This kind of ruins the point of a timer - it would be nice if, once the timer is set, the Blynk server would send the commands to the arduino even if the app is not open.
Is there some way to do this?
B
@bdawg
Hi, timer is working in offline mode. BUT your dashboard (view with widgets) should be in active state (active means button “PLAY” pressed). So you press run and could go offline
Brilliant! Thanks Dmitriy, keep up the good work.
B
