Huge help and inspiration from Costas and psoro’s Scheduler.
My goal was to have my garden fauntain and garden light with comfortable electronic switch.
But after seeing psoro’s scheduler, I could see it I might “need” to have a timer too.
It has two buttons to turn on fauntain and gardenlight individually.
It also have two timers.
And a automatic/manual switch.
One thing thats not visible is the rtc widget which you also have to add, mine is used on another tab.
It uses the Eventor widget to turn on the relay by looking at the virtualpin V51 and V52.
The wiring is fairly simple, I have used a powerboard that has two outputs, both 3.3v for the nodemcu and 5v for the relay.
The code
A huge part is borrowed from psoro’s Scheduler, but boilded down to only whats needed in my version.
So alot of credit goes to him and Costa.
// #define BLYNK_DEBUG
#include <TimeLib.h>
#include <WidgetRTC.h>
char auth[] = "xxxxxx"; // Put your Auth Token here. (see Step 3 above)
WidgetRTC rtc;
char Date[16];
char Time[16];
int manual=0;
long startsecondswd; // weekday start time in seconds
long stopsecondswd; // weekday stop time in seconds
long nowseconds; // time now in seconds
WiFi.mode(WIFI_STA);
Serial.begin(115200); // See the connection status in Serial Monitor
Blynk.begin(auth, "xxxx", "xxxxx"); //insert here your SSID and password
rtc.begin();
Blynk.virtualWrite(V49, 1);
timer.setInterval(100000L, sendWifi);
timer.setInterval(60000L, syncRelay);
timer.setInterval(1000,showCurrentTime);
BLYNK_WRITE(V49)
if (param.asInt()==1)
manual=1;
manual=0;
BLYNK_WRITE(V50)//Fauntain
if (manual==1)
sprintf(Date, "%02d/%02d/%04d", day(), month(), year());
TimeInputParam t(param);
Serial.println(Time);
Serial.println(Date);
int dayadjustment = -1;
if(weekday() == 1){
dayadjustment = 6; // needed for Sunday, Time library is day 1 and Blynk is day 7
if(t.isWeekdaySelected(weekday() + dayadjustment)){ //Time library starts week on Sunday, Blynk on Monday
nowseconds = ((hour() * 3600) + (minute() * 60) + second());
startsecondswd = (t.getStartHour() * 3600) + (t.getStartMinute() * 60);
Serial.println(startsecondswd); // used for debugging
if(nowseconds >= startsecondswd){
if(nowseconds <= startsecondswd + 90){ // 90s on 60s timer ensures 1 trigger command is sent
Blynk.virtualWrite(V51, 1);
// code here to switch the relay ON
stopsecondswd = (t.getStopHour() * 3600) + (t.getStopMinute() * 60);
Serial.println(stopsecondswd); // used for debugging
if(nowseconds >= stopsecondswd){
Blynk.virtualWrite(V51, 0);
if(nowseconds <= stopsecondswd + 90){ // 90s on 60s timer ensures 1 trigger command is sent
// code here to switch the relay OFF
else{
// nothing to do today, check again in 30 SECONDS time
BLYNK_WRITE(V53)//Gardenlight
if (manual==1)
if(weekday() == 1){
Blynk.virtualWrite(V52, 1);
Blynk.virtualWrite(V52, 0);
else{
void syncRelay()
Blynk.syncAll();
Serial.println("sync relay");
void showCurrentTime()
String CurrentDate = String(day()) + '-' + monthShortStr(month()) + '-' + year();
String CurrentTime = String(hour()) + ':' + minute() + ':' + second();
String formattedDate = CurrentDate + String(" | ") + CurrentTime;
Blynk.virtualWrite(V11,formattedDate);
void sendWifi()
Blynk.virtualWrite(1, map(WiFi.RSSI(), -105, -40, 0, 100) );
