I’ve got a 30 min timer to rest a pump for 1/2 hr after 1 hr running. Timer is reset when pump starts and is in the routine labeled “RestPump” about 2/3 down. Every 30min it loops and advances a counter. Counter is zeroed after 3 loops of if pump is off and not flagged as resting.
Except it doesn’t. It’s stuck on 3. (For debugging I send status to app.) I found one error but still something’s wrong. It’s probably something silly.
Any thots?
//V0 soldCnt, V1 ROState (LED), V2 ROOverride (sw), V3 XferState (LED), V4 XferOverride (sw)
//V5 DelayRORestart (LED), V6 LoopCntDelay V7 loopCntRO, V8 PumpResting (LED)
// ADDebug
#define BLYNK_TEMPLATE_ID "TMPL2***3635"
#define BLYNK_TEMPLATE_NAME "Acqu***eDebug"
#define BLYNK_AUTH_TOKEN "1F2v0ebHsMUNq***MJT9uFuCiu21fy"
#define BLYNK_FIRMWARE_VERSION "0.1.3"
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
#include "MinBlynkOTAESP32.h" // My own Blynk OTA setup. Add these 2 to sketch
int UpdateOnStatusTimerID, RestPumpTimerID;
bool ROState, XferState, CoinState;
bool ReConnected = false, DelayRORestart = false;
const byte ROPin = 16, XferPin = 17, CoinPin=23;
const byte LEDPin = 2, ROPwrPin=18, XferPwrPin=19;
double SoldCnt, ComPauseTime;
char ssid[] = "Infornet_***staurante";
char pass[] = "***";
pinMode(ROPin, INPUT_PULLUP);
pinMode (XferPwrPin, OUTPUT) ;
timer.setInterval(1000L, PinCk);
UpdateOnStatusTimerID = timer.setInterval(180000L, UpdateOnStatus); //120k=2m, 300k=5
RestPumpTimerID = timer.setInterval(1800000L,RestPump); //30 min
Blynk.syncVirtual(V0,V2,V4); //sync relay w/ V switches & sold count
void loop(){
void PinCk(){ //1 sec timer
static bool OldROState, OldXferState, OldCoinState;
ROState = !digitalRead(ROPin); //invert for pullup
if (ROState != OldROState){ //immediate state change, + timer 3m repeats
Blynk.virtualWrite(V1, ROState);
OldROState = ROState;
if (ROState==true) { //if just turned on, re-start Blynk timer
timer.restartTimer(UpdateOnStatusTimerID); //timer to send Blynk info
timer.restartTimer(RestPumpTimerID); //timer 60m on 30 off
if (ROState==false) { //if just turned off, start re-start prog timer
DelayRORestart = true; // flag to delay re-start of RO pump to allow raw water tank time to refill and avoid cycling
Blynk.virtualWrite(V5, DelayRORestart);
digitalWrite(ROPwrPin,LOW); //relay on,pwr off
Blynk.virtualWrite(V2, LOW); //may be redund, try wo dWrite
void UpdateOnStatus (){ // confirm ON status w app every X min (3)
static int LoopCntDelay;
if (ROState) Blynk.virtualWrite(V1, ROState);
if (XferState) Blynk.virtualWrite(V3, XferState);
if (DelayRORestart) { //mostly so if xfer empty gives time to fill some before restart
LoopCntDelay++;
Blynk.virtualWrite(V6, LoopCntDelay);
if (LoopCntDelay >= 3) {
digitalWrite(ROPwrPin,HIGH); //relay off,pwr on
Blynk.virtualWrite(V2, HIGH); //may be redund, try wo dWrite
LoopCntDelay=0;
DelayRORestart=false;
void RestPump(){ //30 min
static int LoopCntRO;
static bool PumpResting;
if (ROState||PumpResting){ //if pump on OR resting...
LoopCntRO++;
Blynk.virtualWrite(V7, LoopCntRO);
if (LoopCntRO == 2) { //1st loop do nothing (stays on), 2nd stop pump & set flag
digitalWrite(ROPwrPin,LOW); //relay on, pwr off
PumpResting=true;
Blynk.virtualWrite(V8, PumpResting);
if (LoopCntRO >= 3) { //3rd loop turn on and reset counter & flag
digitalWrite(ROPwrPin,HIGH); //relay off, pwr on
LoopCntRO = 0;
PumpResting=false;
else LoopCntRO = 0; // if pump off and not resting, reset counter
BLYNK_CONNECTED() {
// This function will run every time Blynk connection is established
// Request Blynk server to re-send latest values for pins
ReConnected = true;
Blynk.syncAll();
BLYNK_WRITE(V0){ //seems redundant, but allows console to change value here
if(ReConnected == true) { //only update count if reconnected and APP > device (i.e. no sales while offline)
double SoldCntTmp = param.asDouble();
if (SoldCntTmp > SoldCnt) SoldCnt = SoldCntTmp;//if sale while offline
else if (SoldCnt > SoldCntTmp) Blynk.virtualWrite(V0, SoldCnt);
ReConnected = false;
if (!CoinState){ //if CoinState, device initiated write, if !CoinState, app init and must update SoldCnt w/ new value even if less
SoldCnt = param.asDouble(); // assigning incoming value from pin V0 to a variable
/* BLYNK_WRITE(V5){
int SwState = param.asInt();
if (SwState) {
Blynk.syncVirtual(V6);
Blynk.disconnect();
timer.setTimeout(ComPauseTime , []() //so this is suppposed to pause and hold place to start @ next line when time up
Blynk.connect();
BLYNK_WRITE(V6){
ComPauseTime = param.asDouble();
ComPauseTime = ComPauseTime * 60000; // chg min to millis
