Hello Pet! me again! As you will realize, I am very new to this, you have already helped me on other occasions! I want to make the internal led of my wemos blink and I can’t make it work with the code you published … what could I be wrong about … ??
#include <FS.h>
//#define BLYNK_PRINT Serial
#include <DNSServer.h>
#include <ESP8266WebServer.h>
#include <WiFiManager.h>
#include <ArduinoJson.h>
//for LED status
#include <Ticker.h>
#define blue_led 2 // NodeMCU onboard LED attached to GPIO2 (D4)
Ticker blueticker; // Initialise the Ticker object called blueticker
Ticker ticker;
bool alarm_mode = false ;
bool verificador = false;
//int led_placa = 2;
int sensor = 5;
int buzzer = 15;
int alarm_led = 4;
//int alarm_led_off = 0;
int indicador = 13;
int ledPin = 14;
int contconexion = 0;
int conteoReactivacion = 0;
int ledState = LOW; // ledState used to set the LED
int VirtualPinA = 3;
//define your default values here, if there are different values in config.json, they are overwritten.
char mqtt_server[40];
char mqtt_port[6] = "8080";
char blynk_token[34] = "ymzp8hEq9d4UmNguWdvF7PhDj8nVUTlc";
//flag for saving data
bool shouldSaveConfig = false;
//callback notifying us of the need to save config
void flashblue() // Non-blocking ticker for Blue LED
int state = digitalRead(blue_led); // get the current state of the blue_led pin
digitalWrite(blue_led, !state); // set pin to the opposite state
blueticker.attach(0.2, flashblue); // start blueticker with 0.1 second flash rate
blueticker.detach(); // stop the blueticker
digitalWrite(blue_led, LOW); // LED is active LOW, so force it to be off
void tick()
//toggle state
int state = digitalRead(indicador); // get the current state of GPIO1 pin
digitalWrite(indicador, !state); // set pin to the opposite state
void ledState1()
if (ledState == LOW) {
ledState = HIGH;
Blynk.virtualWrite(VirtualPinA, 0);
ledState = LOW;
Blynk.virtualWrite(VirtualPinA, 1023);
//gets called when WiFiManager enters configuration mode
void configModeCallback (WiFiManager *myWiFiManager) {
Serial.println("Entered config mode");
Serial.println(WiFi.softAPIP());
//if you used auto generated SSID, print it
Serial.println(myWiFiManager->getConfigPortalSSID());
//entered config mode, make led toggle faster
ticker.attach(0.2, tick);
void saveConfigCallback () {
Serial.println("Should save config");
shouldSaveConfig = true;
// Keep this flag not to re-sync on every reconnection
bool isFirstConnect = true;
// This function will run every time Blynk connection is established
BLYNK_CONNECTED()
if (isFirstConnect)
// Request Blynk server to re-send latest values for all pins
Blynk.syncAll();
isFirstConnect = false;
void myTimerEvent() {
//Serial.println("Tiempo des en seg: " + String(conteoReactivacion));
if (alarm_mode == false) {
conteoReactivacion++;
if (conteoReactivacion >= 1800) {
Blynk.virtualWrite(V1, 1);
digitalWrite(alarm_led, HIGH);
//digitalWrite(alarm_led_off, LOW);
alarm_mode = true;
if (digitalRead(sensor) == 0) {
Blynk.virtualWrite(V0, "NORMAL");
delay(3000); // Tiempo de demora al recibir señal de disparo
if (digitalRead(sensor) == 1)
Blynk.virtualWrite(V0, "ALERTA");
if (alarm_mode == true)
//AUTOR ALEXIS MORA
Blynk.email("clianaloss01@gmail.com", "Historial de Alarmas", "Alarma Disparo");
Blynk.notify("Alarma Disparo");
digitalWrite(buzzer, HIGH);
delay(500);
digitalWrite(buzzer, LOW);
BLYNK_WRITE(V1) {
Serial.println(param.asInt());
switch (param.asInt()) {
case 1: {
alarm_mode = true;
break;
case 2: {
alarm_mode = false;
digitalWrite(alarm_led, LOW);
//digitalWrite(alarm_led_off, HIGH);
break;
pinMode(sensor, INPUT_PULLUP);
pinMode(buzzer, OUTPUT);
pinMode(alarm_led, OUTPUT);
pinMode(blue_led, OUTPUT);
//pinMode(alarm_led_off, OUTPUT);
pinMode(indicador, OUTPUT);
//pinMode(led_placa, OUTPUT);
//pinMode(BUILTIN_LED, OUTPUT);
//start ticker with 0.5 because we start in AP mode and try to connect
ticker.attach(0.6, tick);
Serial.println();
//clean FS, for testing
//SPIFFS.format();
// Blynk.begin(auth, ssid, pass);
timer.setInterval(1000L, ledState1); //timer will run every sec
//SPIFFS.format();
//read configuration from FS json
Serial.println("mounting FS...");
if (SPIFFS.begin()) {
Serial.println("mounted file system");
if (SPIFFS.exists("/config.json")) {
//file exists, reading and loading
Serial.println("reading config file");
File configFile = SPIFFS.open("/config.json", "r");
if (configFile) {
Serial.println("opened config file");
size_t size = configFile.size();
// Allocate a buffer to store contents of the file.
std::unique_ptr<char[]> buf(new char[size]);
configFile.readBytes(buf.get(), size);
DynamicJsonBuffer jsonBuffer;
JsonObject& json = jsonBuffer.parseObject(buf.get());
json.printTo(Serial);
if (json.success()) {
Serial.println("\nparsed json");
//strcpy(mqtt_server, json["mqtt_server"]);
//strcpy(mqtt_port, json["mqtt_port"]);
strcpy(blynk_token, json["blynk_token"]);
Serial.println("failed to load json config");
configFile.close();
Serial.println("failed to mount FS");
//end read
// The extra parameters to be configured (can be either global or just in the setup)
// After connecting, parameter.getValue() will get you the configured value
// id/name placeholder/prompt default length
//WiFiManagerParameter custom_mqtt_server("server", "mqtt server", mqtt_server, 40);
//WiFiManagerParameter custom_mqtt_port("port", "mqtt port", mqtt_port, 6);
WiFiManagerParameter custom_blynk_token("blynk", "blynk token", blynk_token, 34);
//WiFiManager
//Local intialization. Once its business is done, there is no need to keep it around
WiFiManager wifiManager;
//set config save notify callback
wifiManager.setSaveConfigCallback(saveConfigCallback);
//set static ip
//wifiManager.setSTAStaticIPConfig(IPAddress(10,0,1,99), IPAddress(10,0,1,1), IPAddress(255,255,255,0));
//add all your parameters here
//wifiManager.addParameter(&custom_mqtt_server);
//wifiManager.addParameter(&custom_mqtt_port);
wifiManager.addParameter(&custom_blynk_token);
//reset settings - for testing
//wifiManager.resetSettings(); //borra usuario y contraseña cuando esta linea esta sin comentar al grabar.
//set callback that gets called when connecting to previous WiFi fails, and enters Access Point mode
wifiManager.setAPCallback(configModeCallback);
//set minimu quality of signal so it ignores AP's under that quality
// defaults to 8%
wifiManager.setMinimumSignalQuality( 20 );
//sets timeout until configuration portal gets turned off
//useful to make it all retry or go to sleep
//in seconds
wifiManager.setTimeout(120);
//fetches ssid and pass and tries to connect
//if it does not connect it starts an access point with the specified name
//here "AutoConnectAP"
//and goes into a blocking loop awaiting configuration
if (!wifiManager.autoConnect("NanoWifi", "12345678")) {
Serial.println("failed to connect and hit timeout");
delay(3000);
//reset and try again, or maybe put it to deep sleep
ESP.reset();
delay(5000);
Serial.println("connected...yeey :)");
//read updated parameters
//strcpy(mqtt_server, custom_mqtt_server.getValue());
//strcpy(mqtt_port, custom_mqtt_port.getValue());
strcpy(blynk_token, custom_blynk_token.getValue());
//save the custom parameters to FS
if (shouldSaveConfig) {
Serial.println("saving config");
JsonObject& json = jsonBuffer.createObject();
//json["mqtt_server"] = mqtt_server;
// json["mqtt_port"] = mqtt_port;
json["blynk_token"] = blynk_token;
File configFile = SPIFFS.open("/config.json", "w");
if (!configFile) {
Serial.println("failed to open config file for writing");
json.printTo(configFile);
configFile.close();
//end save
int mytimeout = 5;
delay(500);
Serial.print(".");
if((millis() / 1000) > mytimeout ){ // try for less than 6 seconds to connect to WiFi router
Serial.println(" ");
break;
if(WiFi.status() == WL_CONNECTED){
Serial.println("connected to WiFi!! yay :)");
Serial.println("IP address: ");
ticker.detach();
//keep LED on
digitalWrite(indicador, HIGH);
Blynk.config(blynk_token);
bool result = Blynk.connect();
if (result != true)
Serial.println("BLYNK Connection Fail");
Serial.println(blynk_token);
ESP.reset();
delay (1000);
