Continuing the discussion from [SOLVED] (TimeInput Widget with 0 days selected) modified library not working:
Dear @Gunner @Dmitriy
is there any plan to have this behavior selectable at the sketching time ( or even at the run time )?
What I asking is to have a kind of parameterization that can selected one of the possible behaviors and not to deal with this making “hacking” that need to be redone each time the library get updated.
Thanks and Best Regards,
Mike Kranidis
@mikekgr suggest you submit a push request on GitHub for the 2 characters to be changed in the library, seems bizarre the way it’s currently coded.
hello @Costas, I will try to find the time to write the proper explanation text with the required details and to file a request on GitHub. I hopped that, because @Dmitriy is monitoring the forum, this can be shorter and more direct…
Thanks anyway .
Well, it’s shorter all right, but it has to be stated or added to a worklist, that is why we have GitHub Otherwise the developers don’t know what to develop
