TimeInput Widget interaction with none days selected cant seems to work
Hi all,
I am a new blynk user here trying to use the time input function to set like a certain time duration/range to turn on a LED. I have succeeded in doing this with the LED turning on in a certain day and time and close when it is supposed to, but now I noticed that when no days are selected in blynk app it will turn all of the days into selected days. Is this the normal behavior of the time input widget ? and if so how do I change it so that if no days are selected then it wont turn on the LED?
Here is the attached code where I test for no days selected:
#define BLYNK_TEMPLATE_ID "*"
#define BLYNK_TEMPLATE_NAME "*"
#define BLYNK_AUTH_TOKEN "*"
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
#include <TimeLib.h>          // For time functions
char ssid[] = "*";   // Wifi SSID
char pass[] = "*";  // Wifi password
bool isTimeSynced = false; // Flag to check time synchronization
// Request time sync from Blynk server
BLYNK_CONNECTED() {
  Serial.println("Device connected to Blynk server, requesting time sync...");
  Blynk.sendInternal("rtc", "sync");
  isTimeSynced = false; // Reset the flag to check for new sync
BLYNK_WRITE(InternalPinRTC) {   //check the value of InternalPinRTC
  long t = param.asLong();      //store time in t variable
  Serial.print("Unix time: ");
  Serial.print(t);              //prints time in UNIX format to Serial Monitor
  Serial.println();
// Callback for Time Input widget
BLYNK_WRITE(V14) {
  TimeInputParam t(param);
  // Check for start and stop times
  if (t.hasStartTime()) {
    Serial.println(String("Start: ") + t.getStartHour() + ":" +
                   t.getStartMinute() + ":" + t.getStartSecond());
  if (t.hasStopTime()) {
    Serial.println(String("Stop: ") + t.getStopHour() + ":" +
                   t.getStopMinute() + ":" + t.getStopSecond());
  // Timezone information
  Serial.println(String("Time zone: ") + t.getTZ());
  Serial.println(String("Time zone offset: ") + t.getTZ_Offset());
  // Weekday selection
  for (int i = 1; i <= 7; i++) {
    if (t.isWeekdaySelected(i)) {
      Serial.println(String("Day ") + i + " is selected");
  Serial.println();
// Check if the RTC time has been synchronized
and this is the serial monitor display when no days are selected:
Start: 2:8:0
Stop: 21:1:0
Time zone: Asia/Kuala_Lumpur
Time zone offset: 28800
Day 1 is selected
Day 2 is selected
Day 3 is selected
Day 4 is selected
Day 5 is selected
Day 6 is selected
Day 7 is selected
Cheers and Thanks!
You need to modify the WidgetTimeInput.h file inside the scr folder of the Blynk library.
Line number 33 - mWeekdays = -1; // All set
To
mWeekdays = 0;
Alright will try it out right away. Thanks!
