hi guys. i have a problem.
i want to connect blynk to my localblynk but i have a problem:
my nodemcu code:
char auth[] = "******";
char ssid[] = "******";
char pass[] = "******";
Blynk.begin(auth, ssid, pass, IPAddress(192,168,41,2));
// to avoid delay() function!
and the problem is nodemcu monitor:
[492107] Connecting to blynk-cloud.com:80
[495144] Login timeout
why it cannot connect?!
You have two Blynk.begin commands. The first tries to connect to Blynk cloud. When it doesn’t succeed the code does not progress to the second one, because Blynk.begin is a blocking command.
tnq for answering mr pete.
i delete “Blynk.begin(auth, ssid, pass);”
but my code cannot connect to blynk locla server (“192.168.41.2:9443”)
my nodemcu cdoe:
char auth[] = "*******";
char ssid[] = "*****";
Blynk.begin(auth, ssid, pass, IPAddress(192,168,41,2),9443);
the monitor output is:
[4480] Connecting to 192.168.41.2
[9480] Connecting to 192.168.41.2
[14481] Connecting to 192.168.41.2
also i did this without port number but the result is same:
char ssid[] = "*******";
char pass[] = "*****";
I would have thought port 80 or 8080 would have been required, but it depends how you’ve configured your local server.
i also try it on 80 and 8080 port after ip address but i cannot connect to blynk localserver
i can creat acoount in blynk in local server and also i can that account in my user in local server but nodemcu cannot connect to localserver
Is your local server running?
Have you connected to it using the app and customer server setting.
Have you created a new project and added a device through the app?
Have you use the Auth code for that device in your sketch?
Are you server and device connected to the same network?
yes.
yes blynk app can connect to local server cuz i created an account in blynk with local ip and it is registered in user of blynk local server.
yes.
yes.
yes local server is created in document folder in laptop and laptop connected to the same WIFI the nodemcu connect.
the problem is just nodemcu cannot connect to localserver.
What happens if you turn on debugging in your sketch, and what do the server logs show?
