Time Input widget will be back!
Good news everybody, due to many complaints about the missing Time Input widget, we decided to return it back. At least for now. In order to simplify your migration to Blynk 2.0. The widget will be available until we introduce offline automation that should fully replace Time Input.
Thank you :+1::pray:. Eta?
Will offline automation allow us to access the trigger variable in device side code?
@chinswain yes.
Great news :partying_face::partying_face::partying_face: !!!
But offline automation is only for plus n pro subs right ??
This is good news. Thank you for this :smiling_face_with_three_hearts:
Great! Really excited for the new time input and offline automations!
~ few days. The next app update should include it.
\We’ll see.
Fantastic news! Thanks for listening.
The android app with Time Input is released already. Enjoy!
Hi @Dmytro,
I am trying time input. Looks like something went wrong. I try to set the time but after pressing “OK” it doesn’t save the setting value. what I see is “–:-- - —:–” nothing changes ( I choose HH:mm format).
@nttu53 hello, ios/android?
i’m using android
Best news ever! :smiley::smiley: Thank you everybody!
The bug is confirmed (Android specific). Will be fixed with the next release.
Hello, How do I set up the datastream for the Time Input widget. I have “no supported datastreams” there. I need to adjust the time in the RTC module. And set up timers. Thank you
Hello. For the TimeInput data stream should be of the type String.
please use triple backtickS
@nttu53 please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
I have the same question. There are no github examples or documentation on this widget.
