All documented in the Welcome Topic… and just about every 3rd post in this forum
No, you made a few more changes
Two compile errors in your code… first is at the very top just a single forward slash /**** is needed, not a //****
Second compile error is because you added this line in your void setup()
Serial.println(String("Start: ") + t.getStartHour();
Because the TimeInputParam t(param)
gets provided only within the BLYNK_WRITE(V12)
function, when sent by the widget.
As I suggested check out that whole topic about using this widget. One way (probably not the only way) I utilised the time parameters throughout my code was to declare separate global variables and assign them from the param call.
int SThour;
int STmin;
int STsec;
int SPhour;
int SPmin;
int SPsec;
BLYNK_WRITE(V1) { // Called whenver setting Time Input Widget
TimeInputParam t(param);
SThour = t.getStartHour();
STmin = t.getStartMinute();
STsec = t.getStartSecond();
SPhour = t.getStopHour();
SPmin = t.getStopMinute();
SPsec = t.getStopSecond();
