Time input widget only shows on other devices
I got a weird bug with the time input widget.
When I input a start and end time with my iPhone I got the values on my esp but the widget only shows —:—:—. When looking on a android phone I can see the time. Otherwise versa, inputting a time on android only shows the time on the esp and iphone.
Both apps run the latest versions.
On the android I got a „OK“ button on the top right, on the iPhone there is only a cancel button on the top left.
I don’t know if there is a problem with my sketch, I can upload it later. But it seems to be a bug since I am able to see the time on the other device.
Some info about app versions, screenshots, datastream settings and your sketch would help.
For now I can only apply screenshots. I hope I can post code and datastreams tomorrow.
I set the time on the iPhone and nothing happens:
Picture 1+2
On the android it look like this:
Picture 3
If I set the time on the android phone like this:
Picture 4+5
I can’t see the time on the phone.
The iPhone looks like this:
I use Version 1.30 on the iPhone and 1.10.4 on the Android phone.
Hope you can follow my thoughts.
Also the charts looks totally different but I think that’s another problem I didn’t try to fix yet.
I can’t upload more then 1 picture. Is there a preferred way to share the pictures?
I’ve increased your privileges, so you should be able to upload more images now.
What version does it show in the About screen of the app?
Thank you Pete!
Picture 1
Picture 2
Picture 3
Picture 4
Picture 5
Picture 6
On iPhone it’s Version 3.5.6
The android version I will add later when I get access to the phone again
This is the Datastream of the virtual pin
And last but not least my Code refering to the Timer:
#define BLYNK_TEMPLATE_ID           "####"
#define BLYNK_DEVICE_NAME           "####"
#define BLYNK_AUTH_TOKEN            "####"
#include <DHT.h>
#include <TimeLib.h>
#include <WidgetRTC.h>
char ssid[] = "####";
char pass[] = "####";
int startHour;
int startMinute;
int stopHour;
int stopMinute;
BLYNK_WRITE(V5) {
  TimeInputParam t(param);
  if (t.hasStartTime()) {
    startHour = t.getStartHour();
    startMinute = t.getStartMinute();
  if (t.hasStopTime()) {
    stopHour = t.getStopHour();
    stopMinute = t.getStopMinute();
    Serial.print("Startzeit: ");
  Serial.print(startHour);
  Serial.print(":");
  Serial.println(startMinute);
  Serial.print("Endzeit: ");
  Serial.print(stopHour);
  Serial.print(":");
  Serial.println(stopMinute);
BLYNK_CONNECTED() {
  // Synchronize time on connection
  rtc.begin();
Serial.begin(57600);
    dht.begin();
      setSyncInterval(10 * 60); // Sync interval in seconds (10 minutes)
  Blynk.syncVirtual(V5);
I don’t understand your screenshots.
Im sorry its a bit confusing. It ist hard for me to describe my problem in English.
In the first Picture you can see the IPhone setting a start and stop time.
As soon I press the cross in the top left the timer resets itself and shows —:—:— on the iPhone as you can see in picture two. On the Android phone it shows the set time as seen in picture three.
If i try it the other way around, setting the timer on the android phone as seen in picture four the timer reset itself on the android (picture 5) and shows the correct time at the iPhone (picture 6).
The arduino meanwhile gets the set time it doesn’t matter if i set it on the iPhone or android phone.
Maybe i misunderstand the input widget but i want to see what time i set it to.
What happens if you log the android device off?
I have an iPhone and iPad running the same app version as you, and the time input widget works as expected across both devices.
When i log off the android phone i can’t see the time on my iPhone.
I receive the time on the arguing but can’t see anything on my iPhone.
Same thing when i only use arguing.
@nico2211 the code you posted is partial and copied in parts. Can you post the whole file?
Sorry for the delay.
Here you got the full code:
#define BLYNK_TEMPLATE_ID           "#####"
#define BLYNK_DEVICE_NAME           "#####"
#define BLYNK_AUTH_TOKEN            "#####"
#include <DHT.h>
char ssid[] = "#####";
char pass[] = "#####";
#define DHTPIN 2          // What digital pin we're connected to
#define DHTTYPE DHT22   // DHT 22, AM2302, AM2321
int startHour;
int startMinute;
int stopHour;
int stopMinute;
int Helligkeit;
String mystring;
DHT dht(DHTPIN, DHTTYPE);
WidgetRTC rtc;
void sendSensor()
  float h = dht.readHumidity();
  if (isnan(h) || isnan(t)) {
    return;
  Blynk.virtualWrite(V0, h);
  Blynk.virtualWrite(V1, t);
BLYNK_WRITE(V2) //Helligkeit
  Serial.print("Got a value: ");
  Serial.println(param.asStr());
  Helligkeit= (param.asInt());
BLYNK_WRITE(V3) //Lüfter
BLYNK_WRITE(V5) {
  Serial.print(":");
  Serial.print(":");
BLYNK_CONNECTED() {
  rtc.begin();
  //Blynk.begin(auth, ssid, pass, "blynk.cloud", 80);
    dht.begin();
