hello. I’m trying to finish part of a project that consists of capturing a time from blynk, using the “time input” widget and turning on an LED at that time that was established by the user. However, I’m having a lot of difficulties, the code runs but the LED doesn’t light up (I’ve already tested it separately). I’m using the Arduino IDE and the ESP8266 board. the code is like this:
#define BLYNK_TEMPLATE_ID " ******* "
#define BLYNK_TEMPLATE_NAME " ****** "
#define BLYNK_AUTH_TOKEN " ****** "
char ssid[] = " ****** ";
char pass[] = " ****** ";
#include <time.h>
#include <NTPClient.h>
#include <WiFiUdp.h>
WiFiUDP ntpUDP;
const long utcOffsetInSeconds = -10800; // Ajuste para UTC-3
NTPClient timeClient(ntpUDP, "br.pool.ntp.org", utcOffsetInSeconds);
int pinLED = 5; //
String targetTime = "00:00";
BLYNK_WRITE(V2)
String newTime = param.asStr();
if (isValidTime(newTime))
targetTime = newTime;
Serial.print("Hora definida pelo Blynk: ");
Serial.println(targetTime);
Serial.println("Hora inválida.");
void checkAndControlLED()
int currentHour = timeClient.getHours();
int currentMinute = timeClient.getMinutes();
if (targetTime == (String(currentHour) + ":" + String(currentMinute)))
digitalWrite(pinLED, LOW); // Liga o LED se a hora e minuto correspondem
digitalWrite(pinLED, HIGH); // Desliga o LED caso contrário
Serial.begin(115200); // Inicia a comunicação serial para depuração
pinMode(pinLED, OUTPUT);
digitalWrite(pinLED, HIGH); // Garanta que o LED esteja desligado no início
timeClient.begin();
timer.setInterval(1000L, checkAndControlLED); // Verifica a hora a cada segundo
timeClient.update();
I generated a code similar to this example, however it still doesn’t work and nothing even appears on the serial monitor
#define BLYNK_TEMPLATE_ID " ***** "
#define BLYNK_TEMPLATE_NAME " ***** "
#define BLYNK_AUTH_TOKEN " ***** "
// Substitua com suas credenciais de rede e token Blynk
char ssid[] = " ***** ";
char pass[] = " ***** ";
#include <TimeLib.h>
int timeInputPin = V7;
int ledPin = 4;
BLYNK_WRITE(timeInputPin) {
TimeInputParam t(param);
// Obter a hora e o minuto definidos no Time Input
int selectedHour = t.getStartHour();
int selectedMinute = t.getStartMinute();
Serial.print("Hora definida pelo usuário: ");
Serial.print(selectedHour);
Serial.print(":");
Serial.println(selectedMinute);
// Obter o tempo atual em horas e minutos
int currentHour = hour();
int currentMinute = minute();
Serial.print("Hora atual do RTC: ");
Serial.print(currentHour);
Serial.print(":");
Serial.println(currentMinute);
// Verificar se a hora e o minuto selecionados correspondem ao tempo atual
if (selectedHour == currentHour && selectedMinute == currentMinute) {
// Acender o LED no GPIO 4 (D4)
digitalWrite(ledPin, HIGH);
delay(10000); // Manter o LED aceso por 10 segundos
digitalWrite(ledPin, LOW);
Serial.println("Iniciando o setup...");
Serial.println("Configuração do Blynk concluída.");
Please do not generate any code. Don’t take that trouble. Blynk team has done a wonderful job by giving us the example builder. Just replace/add your template name and device name. Get this working. Understand how things work line by line.
Your code should be producing some serial output when the board boots and connects to Blynk, and when you change the value of the start time in the V7 widget. If its not (and assuming that you have the serial monitor set to the correct baud rate) your board may be faulty.
Your code is structured incorrectly.
It has no way to obtain the current time, which is needed to compare with the start time set in the Time Input widget.
Also, the code that checks if the current time matches the start time in the widget is only called once, when you change the value of the time input widget.
@night rather than hijacking an existing topic, you’d be far better creating your own “need help…” topic and explaining more about your hardware and the overall aim(s) of your project. That way, you’ll get much more meaningful answers.
