I have a problem with the time input widget and I don’t know where to start., I’m sure it’s my problem because I didn’t quite understand how it works.
I have 7 time input widgets and 7 numeric inputs to control the time interval on Mondays to Fridays 4 widgets and 3 widgets to control on weekends, as in the attached images
My problem is that if I have a time interval from Monday to Friday and I have the same interval in the weekend, it returns the data from the last widget, don’t take into account that it is a weekend.
I certainly didn’t quite understand how this widget works and that’s why I need help.
#include <DHT.h>
#define DHTPIN 12 // What digital pin we're connected to
//#define DHTTYPE DHT11 // DHT 11
#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21 // DHT 21, AM2301
DHT dht(DHTPIN, DHTTYPE);
char auth[] = "xxxxxxxxxx";
char ssid[] = "xxxxxxxxxxxx";
char pass[] = "xxxxxxxxx";
float t_101=0.00;
float t_103=0.00;
float t_105=0.00;
float t_107=0.00;
float t_109=0.00;
float t_111=0.00;
float t_127=0.00;
int ora_start;
const int rel_centr = 2;
BLYNK_WRITE(V101){
t_101=param.asInt();
BLYNK_WRITE(V103){
t_103=param.asInt();
BLYNK_WRITE(V105){
t_105=param.asInt();
BLYNK_WRITE(V107){
t_107=param.asInt();
BLYNK_WRITE(V109){
t_109=param.asInt();
BLYNK_WRITE(V111){
t_111=param.asInt();
BLYNK_WRITE(V113){
t_113=param.asInt();
BLYNK_WRITE(V100) {
TimeInputParam t(param);
for (int i = 1; i <= 5; i++) {
if (t.isWeekdaySelected(i)) {
if (t.hasStartTime())
t_127=t_101;
// Process stop time
if (t.hasStopTime())
BLYNK_WRITE(V102) {
t_127=t_103;
BLYNK_WRITE(V104) {
t_127=t_105;
BLYNK_WRITE(V106) {
t_127=t_107;
BLYNK_WRITE(V108) {
for (int i = 6; i <= 7; i++) {
t_127=t_109;
BLYNK_WRITE(V110) {
t_127=t_111;
void sendSensor()
float h = dht.readHumidity();
float temp = dht.readTemperature(); // or dht.readTemperature(true) for Fahrenheit
Blynk.syncAll();
if (isnan(h) || isnan(temp)) {
return;
Blynk.virtualWrite(V5, h);
Blynk.virtualWrite(V6, temp);
Blynk.virtualWrite(V127,t_127);
Blynk.virtualWrite(V99,"Setare periaode lucru WEKEWND");
if (temp<=t_127-0.5)
digitalWrite(rel_centr,LOW);
else {
digitalWrite(rel_centr,HIGH);
BLYNK_WRITE(V112) {
t_127=t_113;
Blynk.connected();
Blynk.syncAll();
dht.begin();
pinMode(rel_centr, OUTPUT);
timer.setInterval(2000L, sendSensor);
