this code from youtube cr. ttps://www.youtube.com/watch?v=NW1fwFZA45U
when i am run app it worrking with out time current
#include <TimeLib.h>
#include <WidgetRTC.h>
#include <EEPROM.h>
#define EEPROM_STATE_ADDRESS_1 128
#define EEPROM_STATE_ADDRESS_2 144
#define relayLed 12
WidgetRTC rtc;
WidgetTerminal terminal(V3);
WidgetLED led1(V4);
WidgetLED led2(V5);
char Date[16];
char Time[16];
char auth[] = "XXXX";
char ssid[] = "ikness";
char pass[] = "12345678";
long startsecondswd;
long stopsecondswd;
long nowseconds;
bool isFirstConnect = true;
String displaycurrenttimepluswifi;
int wifisignal;
int manual = 0;
int oldstatus;
int automode;
char ledstate = 0;
char schestate = 0;
bool check = true;
bool check2 = true;
bool check3 = true;
pinMode(relayLed, OUTPUT);
digitalWrite(relayLed, LOW); // set LED OFF
Serial.println("\Starting");
int mytimeout = millis() / 1000;
while (Blynk.connect() == false) { // try to connect to server for 10 seconds
if ((millis() / 1000) > mytimeout + 8) { // try local server if not connected within 9 seconds
break;
EEPROM.begin(512);
ledstate = EEPROM.read(EEPROM_STATE_ADDRESS_1) == 1 ? 1 : 0;
schestate = EEPROM.read(EEPROM_STATE_ADDRESS_2) == 1 ? 1 : 0;
ledonstart();
rtc.begin();
timer.setInterval(10000L, activetoday); // check every 10 SECONDS if schedule should run today
timer.setInterval(30000L, reconnectBlynk); // check every 30s if still connected to server
timer.setInterval(5000L, clockvalue); // check value for time
timer.setInterval(5000L, sendWifi); // Wi-Fi singal
timer.setInterval(1000L, check_status);
timer.setInterval(1000L, check_sche);
void ledonstart() {
if (ledstate == 1) {
digitalWrite(relayLed, 1);
Blynk.virtualWrite(V2, 1);
else {
digitalWrite(relayLed, 0);
Blynk.virtualWrite(V2, 0);
if (schestate == 1) {
Blynk.virtualWrite(V11, 1);
led1.on();
led2.off();
if ((schestate == 1) && (check3 == true)) {
timer.setTimeout(50, resetTerminal);
timer.setTimeout(50, checklastbuttonpressed);
automode = 1;
schestate = 1;
check3 = false;
else {
Blynk.virtualWrite(V11, 0);
led1.off();
led2.on();
void check_status() {
if (digitalRead(relayLed) == HIGH) {
ledstate = 1;
if (check == true) {
EEPROM.write(EEPROM_STATE_ADDRESS_1, ledstate);
EEPROM.commit();
Serial.println("EEPROM Write ledstate ON 1");
check = false;
else {
ledstate = 0;
if (check == false) {
EEPROM.commit();
Serial.println("EEPROM Write ledstate OFF 1");
check = true;
void check_sche() {
if (automode == 1) {
schestate = 1;
if (check2 == true) {
EEPROM.write(EEPROM_STATE_ADDRESS_2, schestate);
EEPROM.commit();
Serial.println("EEPROM Write schestate ON 1");
led1.on();
led2.off();
check2 = false;
else {
schestate = 0;
if (check2 == false) {
EEPROM.commit();
Serial.println("EEPROM Write schestate OFF 1");
led1.off();
led2.on();
check2 = true;
BLYNK_CONNECTED() {
if (isFirstConnect) {
Blynk.syncAll();
Blynk.notify("TIMER STARTING!!!!");
isFirstConnect = false;
void sendWifi() {
wifisignal = map(WiFi.RSSI(), -105, -40, 0, 100);
void clockvalue() // Digital clock display of the time
int gmthour = hour();
if (gmthour == 24) {
gmthour = 0;
String displayhour = String(gmthour, DEC);
int hourdigits = displayhour.length();
if (hourdigits == 1) {
displayhour = "0" + displayhour;
String displayminute = String(minute(), DEC);
int minutedigits = displayminute.length();
if (minutedigits == 1) {
displayminute = "0" + displayminute;
displaycurrenttimepluswifi = " Clock: " + displayhour + ":" + displayminute + " Signal: " + wifisignal + " %";
Blynk.setProperty(V3, "label", displaycurrenttimepluswifi);
void activetoday() { // check if schedule should run today
if (year() != 1970) {
Blynk.syncVirtual(V10); // sync timeinput widget
void checklastbuttonpressed () {
oldstatus = 1; //5
oldstatus = 2; //6
void restorelastbuttonpressed () {
if (oldstatus == 1) {
automode = 1;
automode = 0;
void resetTerminal()
terminal.println();
terminal.println();
terminal.println();
terminal.println("AUTO Mode has been selected");
terminal.println("Wait for update (10 seconds as maximum)");
terminal.println();
terminal.println();
terminal.println();
terminal.flush();
BLYNK_WRITE(V2) // ON-OFF Manual
if (param.asInt() == 1) { // boton encendido
terminal.println();
terminal.println();
terminal.println();
terminal.println("Manual MODE is ON");
terminal.println("Press ON/OFF button if required");
terminal.println("Device is ON");
terminal.println();
terminal.println();
terminal.flush();
if (manual == 0) { //está en modo automático
checklastbuttonpressed ();
manual = 1;
automode = 0;
digitalWrite(relayLed, HIGH); // set LED ON
Blynk.virtualWrite(V2, 1); //Turn ON Button Widget
} else { //está en modo manual
automode = 0;
terminal.println();
terminal.println();
terminal.println();
terminal.println("Device is OFF");
terminal.println();
terminal.println();
terminal.flush();
if (manual == 0) { //modo automático
manual = 1;
automode = 0;
Blynk.virtualWrite(V2, 0); //Turn OFF Button Widget
automode = 0;
BLYNK_WRITE(V11) // Up to you selected
automode = 1;
schestate = 1;
automode = 0;
schestate = 0;
BLYNK_WRITE(V10)//Up to you
sprintf(Date, "%02d/%02d/%04d", day(), month(), year());
TimeInputParam t(param);
terminal.print("Auto Mode Checked schedule at: ");
terminal.println(Time);
terminal.flush();
int dayadjustment = -1;
if (weekday() == 1) {
dayadjustment = 6; // needed for Sunday, Time library is day 1 and Blynk is day 7
if (t.isWeekdaySelected(weekday() + dayadjustment)) { //Time library starts week on Sunday, Blynk on Monday
terminal.println("Auto Mode ACTIVE today");
terminal.flush();
if (t.hasStartTime()) // Process start time
terminal.println(String("Start: ") + t.getStartHour() + ":" + t.getStartMinute());
terminal.flush();
if (t.hasStopTime()) // Process stop time
terminal.println(String("Stop : ") + t.getStopHour() + ":" + t.getStopMinute());
terminal.flush();
// Display timezone details, for information purposes only
terminal.println(String("Time zone: ") + t.getTZ()); // Timezone is already added to start/stop time
terminal.println("At least ONE day MUST be selected");
//terminal.println(String("Time zone offset: ") + t.getTZ_Offset()); // Get timezone offset (in seconds)
terminal.flush();
for (int i = 1; i <= 7; i++) { // Process weekdays (1. Mon, 2. Tue, 3. Wed, ...)
if (t.isWeekdaySelected(i)) {
terminal.println(String("Day ") + i + " is selected");
terminal.flush();
nowseconds = ((hour() * 3600) + (minute() * 60) + second());
startsecondswd = (t.getStartHour() * 3600) + (t.getStartMinute() * 60);
//Serial.println(startsecondswd); // used for debugging
if (nowseconds >= startsecondswd) {
terminal.print("Auto Mode STARTED at");
terminal.println(String(" ") + t.getStartHour() + ":" + t.getStartMinute());
terminal.flush();
if (nowseconds <= startsecondswd + 90) { // 90s on 60s timer ensures 1 trigger command is sent
// code here to switch the relay ON
else {
terminal.println("Auto Mode Device NOT STARTED today");
terminal.flush();
stopsecondswd = (t.getStopHour() * 3600) + (t.getStopMinute() * 60);
//Serial.println(stopsecondswd); // used for debugging
if (nowseconds >= stopsecondswd) {
terminal.print("Auto Mode STOPPED at");
terminal.println(String(" ") + t.getStopHour() + ":" + t.getStopMinute());
terminal.flush();
if (nowseconds <= stopsecondswd + 90) { // 90s on 60s timer ensures 1 trigger command is sent
// code here to switch the relay OFF
else {
terminal.println("Auto Mode is ON");
terminal.flush();
else {
terminal.println("Auto Mode INACTIVE today");
terminal.flush();
// nothing to do today, check again in 30 SECONDS time
terminal.println();
void reconnectBlynk() {
if (!Blynk.connected()) {
if (Blynk.connect()) {
BLYNK_LOG("Reconnected");
BLYNK_LOG("Not reconnected");
if (Blynk.connected()) {
````Preformatted text`
