Thermistor, Photoresistor and Blynk not working
Hello. I’m trying to use a Thermistor to read the temperature and send it to the Blynk app. Also, I’m trying to use a Photoresistor to turn on some lights. Below is the code So far. The bord that I’m using is a ESP32. If I comment out the BlynkEdgent.begin(); and the BlynkEdgent.run(); the code works fine and I can see the 2 values in the serial monitor but if I uncomment them I get in the serial monitor a 0 value for the Photoresistor and a -268.1 for the Thermistor.
Can anybody tell me what I’m doing wrong?
#define BLYNK_TEMPLATE_ID "TMPLy1vivXtZ"
#define BLYNK_DEVICE_NAME "Curte"
#define APP_DEBUG
#include "BlynkEdgent.h"
#define Sensor_Lumina 15
#define Reflectoare 2
const double VCC = 3.3;
const double R1 = 9850; // 10k ohm series resistor
const double adc_resolution = 4096;
const double A = 0.001129148;
const double B = 0.000234125;
const double C = 0.0000000876741;
BLYNK_WRITE(V0)
int ReflectoareV = param.asInt();
// digitalWrite(Reflectoare,ReflectoareV);
pinMode(Sensor_Lumina,OUTPUT);
pinMode(Reflectoare,OUTPUT);
digitalWrite(Reflectoare,LOW);
delay(100);
BlynkEdgent.run();
int Nivel_Lumina = analogRead(Sensor_Lumina);
Serial.println(Nivel_Lumina);
if (Nivel_Lumina < 1) {
digitalWrite(Reflectoare,HIGH);
} else{
double Vout1, Rth1, TempOut1, TempIn1;
TempIn1 = analogRead(4);
Vout1 = (TempIn1 * VCC) / adc_resolution;
Rth1 = (VCC * R1 / Vout1)- R1;
TempOut1 = (1 / (A + (B * log(Rth1)) + (C * pow((log(Rth1)),3)))); // Temperature in kelvin
TempOut1 = TempOut1 - 273.15; // Temperature in degree celsius
Serial.print("Temperature = ");
Serial.print(TempOut1+5,1);
Serial.println("°C");
delay(500);
