You are in luck. I was messing around with a DS18B20 just yesterday. This is for two probes, you can add more as needed. Although, I am not sure on the total amount allowed. Make sure you have the proper libraries installed as well.
You will need to add this,
#include <OneWire.h>
#define ONE_WIRE_BUS 14 //pin connected to DS18B20 Sensor(s)
along with this in your setup()
sensors.begin();
and this in a timer loop
// request to all devices on the bus
Serial.print("Requesting temperatures...");
sensors.requestTemperatures(); // Send the command to get temperatures
Serial.println("DONE");
// After we got the temperatures, we can print them here.
// We use the function ByIndex, and as an example get the temperature from the first sensor only.
float temp1 = sensors.getTempCByIndex(0);
float temp2 = sensors.getTempCByIndex(1);
float temp1F = DallasTemperature::toFahrenheit(temp1); //convert to F
float temp2F = DallasTemperature::toFahrenheit(temp2); //convert to F
Serial.print("Temperature for the device 1 (index 0) is: ");
Serial.println(temp1F);
Serial.print("Temperature for the device 1 (index 1) is: ");
Serial.println(temp2F);
Blynk.virtualWrite(V21, temp1F); //write to virtual pin for app
Blynk.virtualWrite(V22, temp2F); //write to virtual pin for app
Hope this helps. Don’t forget to remove all the DHT11 stuff.
