Hi I tested this code, and for my design is perfect but i would like to replace the DHT11 sensor with 2 or 3 DS18B20 stuff, how can i do ??? Thank you
* This example shows how value can be pushed from Arduino to
* the Blynk App.
* WARNING :
* For this example you'll need SimpleTimer library:
* https://github.com/jfturcot/SimpleTimer
* and Adafruit DHT sensor library:
* https://github.com/adafruit/DHT-sensor-library
* App project setup:
* Value Display widget attached to V5
* Value Display widget attached to V6
#include <DHT.h>
char auth[] = "xxxxxxxxxxxxxxxxxxxxxx";
char ssid[] = "xxxx";
char pass[] = "xxxxxxxx";
#define DHTPIN 2 // D4 PIN NodeMCU What digital pin we're connected to
//#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21 // DHT 21, AM2301
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
return;
Blynk.virtualWrite(V5, h);
Blynk.virtualWrite(V6, t);
dht.begin();
You are in luck. I was messing around with a DS18B20 just yesterday. This is for two probes, you can add more as needed. Although, I am not sure on the total amount allowed. Make sure you have the proper libraries installed as well.
// request to all devices on the bus
Serial.print("Requesting temperatures...");
sensors.requestTemperatures(); // Send the command to get temperatures
Serial.println("DONE");
// After we got the temperatures, we can print them here.
// We use the function ByIndex, and as an example get the temperature from the first sensor only.
float temp1 = sensors.getTempCByIndex(0);
float temp2 = sensors.getTempCByIndex(1);
float temp1F = DallasTemperature::toFahrenheit(temp1); //convert to F
float temp2F = DallasTemperature::toFahrenheit(temp2); //convert to F
Serial.print("Temperature for the device 1 (index 0) is: ");
Serial.println(temp1F);
Serial.print("Temperature for the device 1 (index 1) is: ");
Serial.println(temp2F);
Blynk.virtualWrite(V21, temp1F); //write to virtual pin for app
Blynk.virtualWrite(V22, temp2F); //write to virtual pin for app
Hope this helps. Don’t forget to remove all the DHT11 stuff.
You can make it work with BLYNK by reading the DOCS and seeing what the difference is between a typical sketch and one that is formatted for BLYNK. You can also work through some of the examples to get a better understanding.
If you are looking for someone to turn that code into one that will work with BLYNK, you are going to need to find someone else. Cause it aint gonna be me.
I provided you with the “meat” of code that I know for sure works (because I am using it to get temps as we speak), all you need to do if put it in a properly formatted sketch.
@structure7, has provided what looks to be a complete code that should work as well.
Thank you for the answer, I’m not very experienced. I’m trying to find the solution alone but I can not help it so I asked for help, I do not want the job already ready
This should work to get you your temperatures. Wire the DS18B20 with red to +3.3V black to GND and Yellow to GPIO14 (D5 on NodeMcu). You will need to add your AUTH token and WIFi stuff. In the Blynk App, use a value display attached to Virtual pin 10.
I do not have any experience with thingspeak, but I would assume it would be handled in a similar fashion as the temp sensor. Basically put it in a timed loop that: connects to thingspeak, then passes the required values, then disconnect from thingspeak.
#include <OneWire.h>
#define ONE_WIRE_BUS 14 //pin connected to DS18B20 Sensor(s) D5 on NodeMCU
char auth[] = "AUTH";
char ssid[] = "WIFI";
char pass[] = "Password";
void sendSensor(){
Blynk.virtualWrite(V10, temp1F); //BLYNK Value Display set to Virtual Pin 10
sensors.begin();
timer.setInterval(5000L, sendSensor); // Temp Sensor Function every 5 seconds
From what I have read the 4.7K resistor is needed, and should go from +3.3V to the same pin as the signal wire is hooked up to (GPIO4, D2).
If this does not work (code provided, plus wiring as stated), then maybe you have a bad probe.
I am running this set-up as we speak to get two temperatures from two sensors (inside and outside of my garage), They are wired as I have stated, and use the same code as I have provided (I am using GPIO13, D7).
I’m already using the GPIO4 (D2) pin. I do not have a 4.7k resistance I put a 10k. The probe works well. With thingspeak works well. It is now mounted on the Puffer.
