I tried to combined some of the project i made in single board (esp32) and after hours and hours i uploaded the code and it didn’t work it spouses to control 8 channel relay and 4 physical switch to control 4 from the 8 manually and with the blynk app and a dht sensor for the humidity and temperature and 12v dc to cool the system and reed switch for the door and finally a rc522 for the door lock but unfortunately it didn’t work and i don’t know why the relays are work with huge delay and i don’t get any reads from the sensors
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
#include <DHT.h>
#include <MFRC522.h>
#include <EEPROM.h>
#define DEBUG_SW 0
#define S1 36
#define R1 13
#define S2 35
#define R2 14
#define S3 34
#define R3 27
#define FAN 16
#define SS_PIN 21
#define RST_PIN 22
#define BTN_PIN 39
#define SLN_PIN 15
MFRC522 mfrc522(SS_PIN, RST_PIN);
unsigned long uidDec, uidDecTemp;
int ARRAYindexUIDcard;
int EEPROMstartAddr;
long adminID = 1122539531;
bool beginCard = 0;
bool addCard = 1;
bool skipCard = 0;
int LockSwitch;
unsigned long CardUIDeEPROMread[] = {0, 1, 2, 3, 4, 5, 6, 7, 8, 9};
int PiezoPin = 17;
int MODE = 0;
char ssid[] = "......";
char pass[] = ".....";
char auth[] = ".......";
WidgetLCD lcd(V10);
void myTimerEvent()
Blynk.virtualWrite(V0, millis() / 1000);
int reed_s = 17; // Reed sensor
int flag = 0;
#define DHTPIN 4
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
return;
Blynk.virtualWrite(V5, t);
Blynk.virtualWrite(V6, h);
int switch_ON_Flag1_previous_I = 0;
int switch_ON_Flag2_previous_I = 0;
int switch_ON_Flag3_previous_I = 0;
BLYNK_WRITE(V12)
digitalWrite(R1, pinValue);
// process received value
BLYNK_WRITE(V13)
int pinValue = param.asInt(); // assigning incoming value from pin V2 to a variable
digitalWrite(R2, pinValue);
BLYNK_WRITE(V14)
int pinValue = param.asInt(); // assigning incoming value from pin V3 to a variable
digitalWrite(R3, pinValue);
BLYNK_WRITE(V15)
digitalWrite(FAN, pinValue);
void with_internet()
if (digitalRead(S1) == LOW)
if (switch_ON_Flag1_previous_I == 0 )
digitalWrite(R1, LOW);
if (DEBUG_SW) Serial.println("Relay1- ON");
Blynk.virtualWrite(V12, 0);
switch_ON_Flag1_previous_I = 1;
if (DEBUG_SW) Serial.println("Switch1 -ON");
if (digitalRead(S1) == HIGH )
if (switch_ON_Flag1_previous_I == 1)
digitalWrite(R1, HIGH);
if (DEBUG_SW) Serial.println("Relay1 OFF");
Blynk.virtualWrite(V12, 1);
if (DEBUG_SW)Serial.println("Switch1 OFF");
if (digitalRead(S2) == LOW)
if (switch_ON_Flag2_previous_I == 0 )
digitalWrite(R2, LOW);
if (DEBUG_SW) Serial.println("Relay2- ON");
Blynk.virtualWrite(V13, 0);
switch_ON_Flag2_previous_I = 1;
if (DEBUG_SW) Serial.println("Switch2 -ON");
if (digitalRead(S2) == HIGH )
if (switch_ON_Flag2_previous_I == 1)
digitalWrite(R2, HIGH);
if (DEBUG_SW) Serial.println("Relay2 OFF");
Blynk.virtualWrite(V13, 1);
if (DEBUG_SW)Serial.println("Switch2 OFF");
//delay(200);
if (digitalRead(S3) == LOW)
if (switch_ON_Flag3_previous_I == 0 )
digitalWrite(R3, LOW);
if (DEBUG_SW) Serial.println("Relay3- ON");
Blynk.virtualWrite(V14, 0);
switch_ON_Flag3_previous_I = 1;
if (DEBUG_SW) Serial.println("Switch3 -ON");
if (digitalRead(S3) == HIGH )
if (switch_ON_Flag3_previous_I == 1)
digitalWrite(R3, HIGH);
if (DEBUG_SW) Serial.println("Relay3 OFF");
Blynk.virtualWrite(V14, 1);
if (DEBUG_SW)Serial.println("Switch3 OFF");
//delay(200);
void without_internet()
digitalWrite(R1, digitalRead(S1));
digitalWrite(R2, digitalRead(S2));
digitalWrite(R3, digitalRead(S3));
if (DEBUG_SW) Serial.begin(9600);
pinMode(SLN_PIN, OUTPUT); digitalWrite(SLN_PIN, LOW);
pinMode(BTN_PIN, INPUT_PULLUP);
pinMode(PiezoPin, OUTPUT);
SPI.begin();
mfrc522.PCD_Init();
pinMode(S1, INPUT);
pinMode(R1, OUTPUT);
pinMode(S2, INPUT);
pinMode(R2, OUTPUT);
pinMode(S3, INPUT);
pinMode(R3, OUTPUT);
pinMode(FAN, OUTPUT);
dht.begin();
pinMode(reed_s, INPUT_PULLUP);
timer.setInterval(1000L,sensorvalue1);
//pinMode(MODE, INPUT);
WiFi.begin(ssid, pass);
Blynk.config(auth);//, ssid, pass);
lcd.clear(); //Use it to clear the LCD Widget
EEPROM.begin(512);
DisplayWAiT_CARD();
EEPROMreadUIDcard();
digitalWrite(PiezoPin, HIGH), delay(100), digitalWrite(PiezoPin, LOW);
if (digitalRead(BTN_PIN) == LOW) {
digitalWrite(SLN_PIN, HIGH); //unlock
lcd.print(0, 0, " BUTTON UNLOCK ");
lcd.print(0, 1, " DOOR OPEN ");
digitalWrite(PiezoPin, HIGH), delay(200), digitalWrite(PiezoPin, LOW);
delay(3000);
DisplayWAiT_CARD();
if (beginCard == 0) {
if ( ! mfrc522.PICC_IsNewCardPresent()) { //Look for new cards.
return;
if ( ! mfrc522.PICC_ReadCardSerial()) { //Select one of the cards.
return;
//Read "UID".
for (byte i = 0; i < mfrc522.uid.size; i++) {
uidDecTemp = mfrc522.uid.uidByte[i];
uidDec = uidDec * 256 + uidDecTemp;
if (beginCard == 1 || LockSwitch > 0)EEPROMwriteUIDcard(); //uidDec == adminID
if (LockSwitch == 0) {
//CardUIDeEPROMread.
for (ARRAYindexUIDcard = 0; ARRAYindexUIDcard <= 9; ARRAYindexUIDcard++) {
if (CardUIDeEPROMread[ARRAYindexUIDcard] > 0) {
if (CardUIDeEPROMread[ARRAYindexUIDcard] == uidDec) {
lcd.print(0, 0, "CARD ACCESS OPEN");
lcd.print(3, 1, uidDec);
delay(3000);
break;
if (ARRAYindexUIDcard == 10) {
lcd.print(0, 0, " Card not Found ");
lcd.print(0, 1, " ");
lcd.print(0, 1, "ID : ");
lcd.print(5, 1, uidDec);
for (int i = 0; i <= 2; i++)delay(100), digitalWrite(PiezoPin, HIGH), delay(100), digitalWrite(PiezoPin, LOW);
digitalWrite(SLN_PIN, LOW); //lock();
delay(3000);
DisplayWAiT_CARD();
if (WiFi.status() != WL_CONNECTED)
if (DEBUG_SW) Serial.println("Not Connected");
if (DEBUG_SW) Serial.println(" Connected");
if (MODE == 0)
with_internet();
without_internet();
BLYNK_WRITE(V1) {
int a = param.asInt();
if (a == 1) beginCard = 1; else beginCard = 0;
BLYNK_WRITE(V2) {
if (a == 1) {
skipCard = 1;
if (EEPROMstartAddr / 5 < 10) EEPROMwriteUIDcard();
skipCard = 0;
BLYNK_WRITE(V3) {
if (a == 1) {
lcd.print(0, 0, " APP UNLOCK OK ");
delay(3000);
DisplayWAiT_CARD();
void sensorvalue1()
if((digitalRead(reed_s) == LOW) && ( flag == 0 ))
Blynk.virtualWrite(V7,0 ); //turns off the led
Blynk.virtualWrite(V8,255 ); // turns on the led
Blynk.notify("Door Closed!!!");
flag = 1;
if((digitalRead(reed_s) == HIGH) && ( flag == 1) )
Blynk.virtualWrite(V7,255 ); // turns on the led
Blynk.virtualWrite(V8,0 ); // turns off the led
Blynk.notify("Door Opened!!!");
flag = 0;
void EEPROMwriteUIDcard() {
lcd.print(0, 0, " START REC CARD ");
lcd.print(0, 1, "PLEASE TAG CARDS");
delay(500);
if (LockSwitch > 0) {
if (skipCard == 1) { //uidDec == adminID
lcd.print(0, 0, " SKIP RECORD ");
lcd.print(0, 1, " label : ");
lcd.print(11, 1, EEPROMstartAddr / 5);
EEPROMstartAddr += 5;
skipCard = 0;
Serial.println("writeCard");
EEPROM.write(EEPROMstartAddr, uidDec & 0xFF);
EEPROM.write(EEPROMstartAddr + 1, (uidDec & 0xFF00) >> 8);
EEPROM.write(EEPROMstartAddr + 2, (uidDec & 0xFF0000) >> 16);
EEPROM.write(EEPROMstartAddr + 3, (uidDec & 0xFF000000) >> 24);
EEPROM.commit();
lcd.print(0, 0, "RECORD OK! IN ");
lcd.print(0, 1, "MEMORY : ");
lcd.print(9, 1, EEPROMstartAddr / 5);
delay(500);
LockSwitch++;
if (EEPROMstartAddr / 5 == 10) {
lcd.clear();
lcd.print(0, 0, "RECORD FINISH");
delay(2000);
EEPROMstartAddr = 0;
uidDec = 0;
void EEPROMreadUIDcard() {
for (int i = 0; i <= 9; i++) {
byte val = EEPROM.read(EEPROMstartAddr + 3);
CardUIDeEPROMread[ARRAYindexUIDcard] = (CardUIDeEPROMread[ARRAYindexUIDcard] << 8) | val;
val = EEPROM.read(EEPROMstartAddr + 2);
val = EEPROM.read(EEPROMstartAddr + 1);
val = EEPROM.read(EEPROMstartAddr);
ARRAYindexUIDcard++;
uidDec = 0;
LockSwitch = 0;
DisplayWAiT_CARD();
void DisplayWAiT_CARD() {
lcd.print(0, 0, " ATTACH THE ");
lcd.print(0, 1, " CARD ");
