The soil moisture sensor does not read on blynk
before I connected this coding with blynk, the sensor worked fine on the serial monitor but when connected using blynk coding the percent value remained at 0 and did not change on the serial monitor
@jolio Please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
