BLYNK
The physical button without wifi does not work
• NodeMcu ESP8266 V3 Lua CH340 Wifi Dev. Board
• android p
• Blynk server
• Blynk Library version 0.6.1
#include "FastLED.h"
#define LED_PIN 3
#define NUM_LEDS 3 // Number of LEDs connected.
#define BRIGHTNESS 64 // Default LED brightness.
#define LED_TYPE WS2812B
#define COLOR_ORDER RGB
CRGB leds[NUM_LEDS];
char auth[] = "";
char ssid[] = "";
char pass[] = "";
void checkPhysicalButton();
//---variables for our RGB values (0-1023) ---
int r = 0;
int g = 0;
int b = 0;
//---variables for On/Off, and Auto/Manual toggle
int autoMode = 0;
//--- int/byte for automatic hue incrementation---
uint8_t gHue = 0; // rotating "base color" used by many of the patterns
bool rele;
BLYNK_CONNECTED() {
  Blynk.syncVirtual(V0);
  Blynk.syncVirtual(V1);
  Blynk.syncVirtual(V2);
  Blynk.syncVirtual(V3);
  Blynk.syncVirtual(V4);
  Blynk.syncVirtual(V5);
  Blynk.syncVirtual(V6);
  Blynk.syncVirtual(V7);
  Blynk.syncVirtual(V8);
// Button 1
BLYNK_WRITE(V0) {
  rele = param.asInt();
  digitalWrite(D1, rele);
// Button 2
BLYNK_WRITE(V1) {
  digitalWrite(D4, rele);
// Button 3
BLYNK_WRITE(V2){
  digitalWrite(D5, rele);
// Button 4
BLYNK_WRITE(V3)
  digitalWrite(D8, rele);
//--- Toggle Auto/Manual Mode ---
BLYNK_WRITE(V4) {
  autoMode = param.asInt();
//--- Red slider value---
BLYNK_WRITE(V6)
  r = param.asInt();
BLYNK_WRITE(V7) {
  g = param.asInt();
//--- Blue slider value---
BLYNK_WRITE(V8) {
  b = param.asInt();
 if (digitalRead(D7))
    rele = !rele;
    Blynk.virtualWrite(V3, rele);
    delay (450);
 if (digitalRead(D0))
    rele = !rele;
    Blynk.virtualWrite(V1, rele);
    delay (450);
  if (digitalRead(D6))
    rele = !rele;
    Blynk.virtualWrite(V2, rele);
    delay (450);
  if (digitalRead(D2))
    rele = !rele;
    Blynk.virtualWrite(V0, rele);
    delay (450);
  FastLED.addLeds<LED_TYPE, LED_PIN, COLOR_ORDER>(leds, NUM_LEDS).setCorrection(TypicalSMD5050);
  FastLED.setBrightness(BRIGHTNESS);
  #define FRAMES_PER_SECOND 120
  pinMode(D1, OUTPUT);
  pinMode(D4, OUTPUT);
  pinMode(D5, OUTPUT);
  pinMode(D8, OUTPUT);
  pinMode(D2, INPUT);
  pinMode(D0, INPUT);
  pinMode(D6, INPUT);
  pinMode(D7, INPUT);
  // Setup a function to be called every 100 ms
  timer.setInterval(100L, checkPhysicalButton);
if(autoMode == 0) {
    for (int i = 0; i < NUM_LEDS; i++){
      leds[i] = CRGB(r, g, b);
      FastLED.show();
      delay(30);
if(autoMode == 1 ) {
    fill_rainbow( leds, NUM_LEDS, gHue, 7);
    // send the 'leds' array out to the actual LED strip
    FastLED.show();
    // insert a delay to keep the framerate modest
    FastLED.delay(1000/FRAMES_PER_SECOND);
    EVERY_N_MILLISECONDS(20) {
      gHue++; // slowly cycle the "base color" through the rainbow
Take a look at this:
sir i don’t know how to add this code in my code, please help me,
@Toro_Blanco help me please
WiFi.begin(ssid, pass);  // Non-blocking if no WiFi available
  Blynk.config(auth, server, port);
  Blynk.connect();
//your code
  if (Blynk.connected()) {  // If connected run as normal
  } else if (ReCnctFlag == 0) {  // If NOT connected and not already trying to reconnect, set timer to try to reconnect in 30 seconds
    ReCnctFlag = 1;  // Set reconnection Flag
    Serial.println("Starting reconnection timer in 30 seconds...");
    timer.setTimeout(30000L, []() {  // Lambda Reconnection Timer Function
      ReCnctFlag = 0;  // Reset reconnection Flag
      ReCnctCount++;  // Increment reconnection Counter
      Serial.print("Attempting reconnection #");
      Serial.println(ReCnctCount);
      Blynk.connect();  // Try to reconnect to the server
    });  // END Timer Function
As @harymk is using Blynk.begin in his original void setup then that will need to be changed as well :slightly_frowning_face:
I just add it in setup :stuck_out_tongue_winking_eye:
thanks dear now its working fine.
sir can we change wifi ssid and password with blynk auth
You are welcome.
Why don’t you use interrupt to control physical buttons ?
Yes you can but with HTML
You can find a way to change it on this forum
give me detail
The search function is very handy, as are saying Please and Thank You.
Try searching for “WiFiManager”.
sir now all function going slowly
What do you mean “now all function going slowly” ?
Pls provide us your new code and serial printed
Don’t forget to format it.
