The LoRa Ra-02 is doesn't work with blynk
Before creating the topic
  1. Search forum for similar topics
  2. Check http://docs.blynk.cc and http://help.blynk.cc/
  3. Add details :
    • Blynk Library version
    • Add your sketch code. :point_up:Code should be formatted as example below.
  Developed by Dhanish Vijayan - Elementz Engineers Guild Pvt. Ltd.
  Instructions
  Tested with the Elementz Lora board with Arduino Pro mini 8 MHz bootloader
  Led blinks at every packet reception
  ToDo:
  // Receive from multiple EspSerials
  // Parameter tuning to achive more range
#include <ESP8266_Lib.h>
#include "LoRa.h"
String phrase;
String s;
char copy[50];
int temp, hum, tre;
int LED_BUILTIN1 = 3;
int SyncWord = 0x22;
char auth[] = "0Mgw_IRUnX9H****************6ygloG";
char ssid[] = "home WIFI";
char pass[] = "shiv*****************3.";
#define ESP8266_BAUD 9600
ESP8266 wifi(&EspSerial);
long writingTimer = 17;
long startTime = 0;
long waitTime = 0;
   LoRa.setSpreadingFactor(12);           // ranges from 6-12,default 7 see API docs
  LoRa.setSignalBandwidth(62.5E3);           // for -139dB (page - 112)
  LoRa.setCodingRate4(8);                   // for -139dB (page - 112)
  LoRa.setSyncWord(SyncWord);           // ranges from 0-0xFF, default 0x12, see API docs
  Serial.print("current spreading factor : ");
  Serial.println(LoRa.getSpreadingFactor());
  Serial.print("current bandwidth : ");
  Serial.println(LoRa.getSignalBandwidth());
  Serial.println("LoRa init succeeded.");
  while (!Serial);
  pinMode(LED_BUILTIN1, OUTPUT);
  Serial.println("LoRa Receiver");
  if (!LoRa.begin(433E6)) {
    Serial.println("Starting LoRa failed!");
    while (1);
 Serial.print("hello");
  int packetSize = LoRa.parsePacket();
  if (packetSize) {
    // received a packet
    Serial.print("Received packet '");
    // read packet
    while (LoRa.available()) {
      char c;
      c = (char)LoRa.read();
      phrase = String(phrase + c);
    phrase.toCharArray(copy,  phrase.length());
    //Serial.println(s);
    // delay(000);
    int v[5], i;
    char *string = copy, *ptr = string;  i = 0;
    while (*ptr) {
      if (isdigit(*ptr)) {
        long val = strtol(ptr, &ptr, 10);
        // Serial.println( val);
        v[i] = val; i++;
        //Serial.println("neew lin e prointh\n");
        ptr++;
      temp = v[0];
      hum = v[1];
      tre = v[2];
  //   EspSerial.println("-------------------- new data --------------------")   ;
    Serial.print("temp:");
    Serial.println(temp);
    Serial.print("hum:");
    Serial.println(hum);
    Serial.print("tre:");
    Serial.println(tre);
    Blynk.virtualWrite(V1, temp);
    Blynk.virtualWrite(V2, hum);
    Blynk.virtualWrite(V3, tre);
    phrase = "";
    // print RSSI of packet
    digitalWrite(LED_BUILTIN1, HIGH);   // turn the LED on (HIGH is the voltage level)
    delay(200);                       // wait for a second
    digitalWrite(LED_BUILTIN1, LOW);    // turn the LED off by making the voltage LOW
    delay(200);
this is code i have written according to it . It should connect to Blynk and start receiving the data from another Lora device but when i connect separately it will work but when i combine both esp and Lora with blynk it does not work . Please help me this is my final year project
Try search. “Keep your void loop clean”
You have put a while syntax in your loop this is blocking code
