Hello! I am building a sign language to speech convertor using an Arduino Nano board. I need help converting some sensor value inputs corresponding to certain signs into speech. I need a text to speech library that can output the audio through my android device.
Blynk doesn’t have a text-to-speech library. You’ll need to find a 3rd party library.
Thank you. Is it possible to direct the data to Google TTS API from the Blynk app? To perform this function? Or using the Android device’s own text-to-speech engine?
As far as I’m aware, the Blynk app doesn’t have the hooks in place to allow this to happen.
You could use a device running Blynk to generate speech from text inputted via the app, but I guess this isn’t what you’re looking for?
I see. And true, that is not what I am looking for. Will it work if I get my code to send in text/strings to the app? That is, if I direct my Arduino program to send in information to the Blynk App as words?
Also, thank you so much for responding so patiently!
