[49978] Connected to WiFi
[49978] IP: 192.168.3.231
[49979] Blynk v0.3.8 on ESP8266
[49979] Connecting to blynk-cloud.com:8442
[50211] Ready (ping: 100ms).
3251666944 led is low = 3251666944
Exception (0):
epc1=0x40205428 epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
ctx: sys
sp: 3ffffc90 end: 3fffffb0 offset: 01a0
>>>stack>>>
3ffffe30: 401043aa 00000030 00000000 ffffffff
3ffffe40: 4000438f 00000030 00000019 ffffffff
3ffffe50: 60000200 00000001 00022d00 80000000
3ffffe60: 20000000 3fff1120 80000000 2007c2a0
3ffffe70: 00000000 3feffe00 fc70ffff 3fff1124
3ffffe80: 00000054 0007c2a0 3ffe91b0 00000030
3ffffe90: 3fffc278 40102af0 3fffc200 00000022
3ffffea0: 3ffffeb0 40205428 3fffc258 4000050c
3ffffeb0: 40000f68 00000030 0000001e ffffffff
3ffffec0: 40000f58 00000000 00000020 00000000
3ffffed0: 3ffe9880 c162cf54 3ff20a00 c0000000
3ffffee0: 00003000 00000000 0000001c 3fffdab0
3ffffef0: 00000000 3fffdcc0 3ffe92b8 00000030
3fffff00: ffffffff 00000000 3ffe92c1 00000008
3fffff10: 40207592 3ffeca48 00000000 3fffdc00
3fffff20: 3ffed510 0000003c 40101bbf 3ffeca48
3fffff30: 00000000 400042db 00000000 3ffe91b0
3fffff40: 40004b31 3fff0e84 000002f4 0007c000
3fffff50: 40105aca 00001311 3ffed410 4010757c
3fffff60: 4020967d 3ffed410 00001311 3fffdcc0
3fffff70: 3fff0e84 00001000 40209aef 000000b2
3fffff80: 4020a367 4020a43e 60000600 3ffed410
3fffff90: 3fffdcc0 00000000 40000f65 3fffdab0
3fffffa0: 00000000 00002121 3fffdab0 40000f49
<<<stack<<<
J9Cю7!aSК
мой скетч через arduino ide (esp-07)
my sketch with arduino ide (esp-07)
* IRremoteESP8266: IRrecvDemo - demonstrates receiving IR codes with IRrecv
* An IR detector/demodulator must be connected to the input RECV_PIN.
* Version 0.1 Sept, 2015
* Based on Ken Shirriff's IrsendDemo Version 0.1 July, 2009, Copyright 2009 Ken Shirriff, http://arcfn.com
#include <IRremoteESP8266.h>
int RECV_PIN = 12; //an IR detector/demodulatord is connected to GPIO pin 2
IRrecv irrecv(RECV_PIN);
decode_results results;
char auth[] = "cf6cc84140ee415097daecbf5efb2387";
WidgetLED led1(V1);
WidgetLCD lcd(V10);
Serial.print(" *begin* ");
Blynk.begin(auth, "niblernet2G", "hackwork");
irrecv.enableIRIn(); // Start the receiver
if (irrecv.decode(&results)) {
Serial.print(results.value);
lcd.print(0, 0, results.value);
if (results.value==3251666952) /*or (results.value==C1D08008))*/
led1.on(); Serial.print(" led is high");
} else
led1.off(); Serial.print(" led is low");
Serial.print(" = ");
Serial.println(results.value, DEC);
irrecv.resume(); // Receive the next value
delay(100);
- Use English, please
- Code snippet should be formatted. Edit your post
Wrap the code by adding 3 Backtick: ``` symbols:
Example:
``` cpp <--put 3 backticks BEFORE your code starts (cpp means C++ language)
//Put your code here
``` <--insert 3 backticks AFTER your code
**This makes your code readable and with highlighted syntax, like this:**
//comment goes here
void helloWorld() {
String message = "hello" + "world";
