Terminal Widget losing connection
I’m trying to understand why my code seems to continuously disconnect and reconnect to my network. If I run the terminal widget example using the same network settings I get more stability (although I still get Heartbeat timeout).
[51435] Heartbeat timeout
[56327] Connecting to blynk-cloud.com:8442
[56631] Ready (ping: 119ms).
on
[101517] Connecting to blynk-cloud.com:8442
[101826] Ready (ping: 119ms).
All LEDs switched ON
[127951] Heartbeat timeout
[132832] Connecting to blynk-cloud.com:8442
[133153] Ready (ping: 120ms).
off
[138155] Connecting to blynk-cloud.com:8442
[138465] Ready (ping: 118ms).
All LEDs switched OFF
[154465] Heartbeat timeout
[157468] Connecting to blynk-cloud.com:8442
[157778] Ready (ping: 118ms).
Although the code is kind of working I am frustrated at how many times I need to send the terminal commands for them to work.
Is my code structured correctly to achieve the proper result?
#include <Ethernet.h>
#include <Adafruit_NeoPixel.h>
#define PIN 3
#define NUMPIXELS 30
int R;
int G;
int B;
int SPEED = 50;
boolean aOn = false;
boolean bOn = false;
boolean cOn = false;
boolean dOn = false;
boolean eOn = false;
boolean fOn = false;
boolean gOn = false;
boolean allOn = false;
String inString = "";
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
WidgetTerminal terminal(V1);
// Mac address should be different for each device in your LAN
byte arduino_mac[] = { 0xDE, 0xEF, 0xCA, 0xEE, 0xEE, 0xED };
IPAddress arduino_ip ( 192,   168,   0,  21);
IPAddress dns_ip     (  192,   168,   0,   1);
IPAddress gateway_ip ( 192,   168,   0,   1);
IPAddress subnet_mask(255, 255, 255,   0);
  Blynk.begin(auth, "blynk-cloud.com", 8442, arduino_ip, dns_ip, gateway_ip, subnet_mask, arduino_mac);
  strip.begin();
  strip.show(); // Initialize all pixels to 'off'
    // Wait until connected
  Serial.println("Welcome to your computer lights");
  Serial.println("For preset colors select 1-8");
  Serial.println("Switch ON or OFF using 'on' or 'off' commands");
  Serial.println("'rainbow' 'theater' 'theaterrainbow' also available");
  terminal.println("Welcome to your computer lights");
  terminal.println("For preset colors select 1-8");
  terminal.println("Switch ON or OFF using 'on' or 'off' commands");
  terminal.println("'rainbow' 'theater' 'theaterrainbow' also available");
  terminal.flush();
BLYNK_WRITE(V1)
  String inString = param.asStr();
  Serial.println(inString);
  if (Blynk.connect() == false)
    terminal.println("Connection Lost");
  if (inString == "1")
    R = 255;
    G = 0;
    B = 0;
    Serial.println("Color set to Red");
    terminal.println("Color set to Red");
    terminal.flush();
  if (inString == "2")
    R = 255;
    G = 0;
    B = 132;
    Serial.println("Color set to Pink");
    terminal.println("Color set to Pink");
    terminal.flush();
  if (inString == "3")
    R = 0;
    G = 0;
    B = 255;
    Serial.println("Color set to Blue");
    terminal.println("Color set to Blue");
    terminal.flush();
  if (inString == "4")
    R = 0;
    G = 255;
    B = 255;
    Serial.println("Color set to Turquoise");
    terminal.println("Color set to Turquoise");
    terminal.flush();
  if (inString == "5")
    R = 0;
    G = 255;
    B = 0;
    Serial.println("Color set to Green");
    terminal.println("Color set to Green");
    terminal.flush();
  if (inString == "6")
    R = 255;
    G = 150;
    B = 0;
    Serial.println("Color set to Yellow");
    terminal.println("Color set to Yellow");
    terminal.flush();
  if (inString == "7")
    R = 255;
    G = 70;
    B = 0;
    Serial.println("Color set to Orange");
    terminal.println("Color set to Orange");
    terminal.flush();
  if (inString == "8")
    R = 255;
    G = 255;
    B = 255;
    Serial.println("Color set to White");
    terminal.println("Color set to White");
    terminal.flush();
  if (inString == "off")
    R = 0;
    G = 0;
    B = 0;
    backwardsColorWipe(strip.Color(R, G, B), SPEED);
    Serial.println("All LEDs switched OFF");
    terminal.println("All LEDs switched OFF");
    terminal.flush();
  if (inString == "on")
    if (R == 0 && G == 0 && B == 0)
      R = 255;
      G = 255;
      B = 255;
    colorWipe(strip.Color(R, G, B), SPEED);
    Serial.println("All LEDs switched ON");
    terminal.println("All LEDs switched ON");
    terminal.flush();
  if (inString == "rainbow")
    Serial.println("Rainbow selected");
    terminal.println("Rainbow selected");
    terminal.flush();
    rainbow(SPEED);
  if (inString == "theater")
    Serial.println("Theater Chase selected");
    terminal.println("Theater Chase selected");
    terminal.flush();
    theaterChase(strip.Color(R, G, B), SPEED);
  if (inString == "theaterrainbow")
    Serial.println("Theater Chase Rainbow Selected");
    terminal.println("Theater Chase Rainbow Selected");
    terminal.flush();
    theaterChaseRainbow(SPEED);
  if (inString == "refresh")
    refreshMenu();
  if (inString == "sega")
    if (aOn)
      Serial.println("Segment A switched OFF");
      terminal.println("Segment A switched OFF");
      terminal.flush();
    else {
      Serial.println("Segment A switched ON");
      terminal.println("Segment A switched ON");
      terminal.flush();
    segmentAOn(R, G, B);
  if (inString == "segb")
    if (bOn)
      Serial.println("Segment B switched OFF");
      terminal.println("Segment B switched OFF");
      terminal.flush();
    else {
      Serial.println("Segment B switched ON");
      terminal.println("Segment B switched ON");
      terminal.flush();
    segmentBOn(R, G, B);
  if (inString == "segc")
    if (cOn)
      Serial.println("Segment C switched OFF");
      terminal.println("Segment C switched OFF");
      terminal.flush();
    else {
      Serial.println("Segment C switched ON");
      terminal.println("Segment C switched ON");
      terminal.flush();
    segmentCOn(R, G, B);
  if (inString == "segd")
    if (dOn)
      Serial.println("Segment D switched OFF");
      terminal.println("Segment D switched OFF");
      terminal.flush();
    else {
      Serial.println("Segment D switched ON");
      terminal.println("Segment D switched ON");
      terminal.flush();
    segmentDOn(R, G, B);
  if (inString == "sege")
    if (eOn)
      Serial.println("Segment E switched OFF");
      terminal.println("Segment E switched OFF");
      terminal.flush();
    else {
      Serial.println("Segment E switched ON");
      terminal.println("Segment E switched ON");
      terminal.flush();
    segmentEOn(R, G, B);
  if (inString == "segf")
    if (aOn)
      Serial.println("Segment F switched OFF");
      terminal.println("Segment F switched OFF");
      terminal.flush();
    else {
      Serial.println("Segment F switched ON");
      terminal.println("Segment F switched ON");
      terminal.flush();
    segmentFOn(R, G, B);
  if (inString == "segg")
    if (gOn)
      Serial.println("Segment G switched OFF");
      terminal.println("Segment G switched OFF");
      terminal.flush();
    else {
      Serial.println("Segment G switched ON");
      terminal.println("Segment G switched ON");
      terminal.flush();
    segmentGOn(R, G, B);
  if (inString == "toggle")
    if (allOn)
      terminal.flush();
    else {
      terminal.flush();
    switchAll(R, G, B);
  if (aOn == true && bOn == true && cOn == true && dOn == true && eOn == true && fOn == true && gOn == true) {
    allOn = true;
  terminal.flush();
  inString = "";
void segmentAOn(int r, int g, int b) {
  if (aOn == false) {
    for(int i=0; i<4; i++) {
      strip.setPixelColor(i, strip.Color(r, g, b));
      strip.show();
      aOn = true;
      allOn = false;
  }else{
      strip.setPixelColor(i, strip.Color(0, 0, 0));
      strip.show();
      aOn = false;
      allOn = false;
void segmentBOn(int r, int g, int b) {
  if (bOn == false) {
    for(int i=4; i<8; i++) {
      strip.show();
      bOn = true;
      allOn = false;
  }else{
      strip.show();
      bOn = false;
      allOn = false;
void segmentCOn(int r, int g, int b) {
  if (cOn == false) {
    for(int i=8; i<12; i++) {
      strip.show();
      cOn = true;
      allOn = false;
  }else{
      strip.show();
      cOn = false;
      allOn = false;
void segmentDOn(int r, int g, int b) {
  if (dOn == false) {
    for(int i=12; i<18; i++) {
      strip.show();
      dOn = true;
      allOn = false;
  }else{
      strip.show();
      dOn = false;
      allOn = false;
void segmentEOn(int r, int g, int b) {
  if (eOn == false) {
    for(int i=18; i<22; i++) {
      strip.show();
      eOn = true;
      allOn = false;
  }else{
      strip.show();
      eOn = false;
      allOn = false;
void segmentFOn(int r, int g, int b) {
  if (fOn == false) {
    for(int i=22; i<26; i++) {
      strip.show();
      fOn = true;
      allOn = false;
  }else{
      strip.show();
      fOn = false;
      allOn = false;
void segmentGOn(int r, int g, int b) {
  if (gOn == false) {
    for(int i=26; i<30; i++) {
      strip.show();
      gOn = true;
      allOn = false;
  }else{
      strip.show();
      gOn = false;
      allOn = false;
void switchAll(int r, int g, int b) {
  if (allOn == false) {
    for(int i=0; i<30; i++) {
      strip.show();
      allOn = true;
      aOn = true;
      bOn = true;
      cOn = true;
      dOn = true;
      eOn = true;
      fOn = true;
      gOn = true;
  }else{
      strip.show();
      allOn = false;
      aOn = false;
      bOn = false;
      cOn = false;
      dOn = false;
      eOn = false;
      fOn = false;
      gOn = false;
void colorWipe(uint32_t c, uint16_t wait) {
  for(uint16_t i=0; i<strip.numPixels(); i++) {
    if (Serial.available() == 0) {
      strip.setPixelColor(i, c);
      strip.show();
      delay(wait);
  allOn = true;
void backwardsColorWipe(uint32_t c, uint16_t wait) {
  for(uint16_t i=1 + (strip.numPixels()); i>0; i--) {
      strip.setPixelColor(i-1, c);
      strip.show();
      delay(wait);
  allOn = true;
void rainbow(uint8_t wait) {
  uint16_t i, j;
  for(j=0; j<256; j++) {
    for(i=0; i<strip.numPixels(); i++) {
      strip.setPixelColor(i, Wheel((i+j) & 255));
    strip.show();
    delay(wait);
  allOn = true;
void theaterChase(uint32_t c, uint8_t wait) {
  for (int j=0; j<10; j++) {  //do 10 cycles of chasing
    for (int q=0; q < 3; q++) {
      for (int i=0; i < strip.numPixels(); i=i+3) {
        strip.setPixelColor(i+q, c);    //turn every third pixel on
      strip.show();
      delay(wait);
        strip.setPixelColor(i+q, 0);        //turn every third pixel off
  allOn = true;
void theaterChaseRainbow(uint8_t wait) {
  for (int j=0; j < 256; j++) {     // cycle all 256 colors in the wheel
          strip.setPixelColor(i+q, Wheel( (i+j) % 255));    //turn every third pixel on
        strip.show();
        delay(wait);
  allOn = true;
void refreshMenu()
  terminal.flush();
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
  WheelPos = 255 - WheelPos;
  if(WheelPos < 85) {
   return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
  } else if(WheelPos < 170) {
    WheelPos -= 85;
   return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
   WheelPos -= 170;
   return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
Hello. Does this timeout happen when you working with Blynk or when you do nothing?
This is related to effects used on WS2812 you need to have Blynk.run() inside for loops otherwise it takes a lot of time to cycle through the function and Arduino looses connectivity. You can have a look at my code that I posted a while ago. It’s not super pretty solution to put Blynk.run() inside all those loops but it is bulletproof in terms of connectivity and stable for over 30 days.
works 100% with two ESPs on the same token
Thank you,
This looks like the solution, I will have a go at modifying my code (first by simplifying it down to one function and adding the Blynk.run() function inside it as you have).
this looks very wrong. Probably you mean connected()…
