Hello blynk team, in my project, the writing is done on the terminal. When the application is open, I see the writing on the teminal, but when the application is closed, I open it. I do not find the events recorded in the terminal, what is the reason
It’s a feature of the new terminal. They said, it can be fixed somewhere in the fiture, but who knows, when…
Thank you, dear @PeteKnight This also applies to notifications. A notification tone is not sent to the mobile, but the notification is sent to the notification center and when you exit and return, the notification center becomes empty.
In that case I’d suggest that you search the issues list to see if there is one about notification sounds and if there isn’t one then you should create one.
