Terminal input, error when save value input
I am making a tool using the input value of the user, the input is the value of drinking times for example 1, 2,3,4 for each terminal. the value is stored in the SaveArray [] array. with the code as below and successfully stores input values ​​from the user (as shown below). code below I have added the void program () function that I have not previously entered
 * Project: string inpu untuk mengtur jam minum obat
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
#include <TimeLib.h>
#include <WidgetRTC.h>
//Widget yang digunakan
WidgetRTC rtc;
WidgetLED led1(V4);
//milis() pengganti delay
#define interval_message 10000
unsigned long time_1 = 0;
char auth[] = "***********************************";
char ssid[] = "****************************************";
char pass[] = "***************************************";
// Attach virtual serial Pil_1 to Virtual Pin V1
WidgetTerminal terminal(V11);
WidgetTerminal Pil_1(V5);
WidgetTerminal Pil_2(V6);
WidgetTerminal Pil_3(V7);
WidgetTerminal Pil_4(V8);
WidgetTerminal Pil_5(V9);
WidgetTerminal Pil_6(V10);
//count untuk timer
unsigned count = 0;
//Save input on array
int SaveArray[8];
int nilai[5];
int button[2];
// You can send commands from Pil_1 to your hardware. Just use
// the same Virtual Pin as your Pil_1 Widget
BLYNK_WRITE(V5)
  if (String("1") == param.asStr()) {
    Pil_1.println("Minum 1x1");
    SaveArray[1]=1;
    else if (String("2") == param.asStr()) {
    Pil_1.println("Minum 2x1");
    SaveArray[1]=2;
    else if (String("3") == param.asStr()) {
    Pil_1.println("Minum 3x1");
    SaveArray[1]=3;
    else if (String("4") == param.asStr()) {
    Pil_1.println("Minum 4x1");
    SaveArray[1]=4;
    else if (String("5") == param.asStr()) {
    Pil_1.println("Minum 5x1");
    SaveArray[1]=5;
    // Send it back
    Pil_1.print("You said:");
    Pil_1.write(param.getBuffer(), param.getLength());
    Pil_1.println("Fix your Time input") ;
    Pil_1.println();
  // Ensure everything is sent
  Pil_1.flush();
BLYNK_WRITE(V6)
    Pil_2.println("Minum 1x1");
    SaveArray[2]=1;
    Pil_2.println("Minum 2x1");
    SaveArray[2]=2;
    Pil_2.println("Minum 3x1");
    SaveArray[2]=3;
    Pil_2.println("Minum 4x1");
    SaveArray[2]=4;
    Pil_2.println("Minum 5x1");
    SaveArray[2]=5;
    // Send it back
    Pil_2.print("You said:");
    Pil_2.write(param.getBuffer(), param.getLength());
    Pil_2.println("Fix your Time input") ;
    Pil_2.println();
  Pil_2.flush();
BLYNK_WRITE(V7)
    Pil_3.println("Minum 1x1");
    SaveArray[3]=1;
    Pil_3.println("Minum 2x1");
    SaveArray[3]=2;
    Pil_3.println("Minum 3x1");
    SaveArray[3]=3;
    Pil_3.println("Minum 4x1");
    SaveArray[3]=4;
    Pil_3.println("Minum 5x1");
    SaveArray[3]=5;
    // Send it back
    Pil_3.print("You said:");
    Pil_3.write(param.getBuffer(), param.getLength());
    Pil_3.println("Fix your Time input") ;
    Pil_3.println();
  Pil_3.flush();
// You can send commands from Pil_4 to your hardware. Just use
// the same Virtual Pin as your Pil_3 Widget
BLYNK_WRITE(V8)
    Pil_4.println("Minum 1x1");
    SaveArray[4]=1;
    Pil_4.println("Minum 2x1") ;
    SaveArray[4]=2;
    Pil_4.println("Minum 3x1");
    SaveArray[4]=3;
    Pil_4.println("Minum 4x1") ;
    SaveArray[4]=4;
    Pil_4.println("Minum 5x1") ;
    SaveArray[4]=5;
    // Send it back
    Pil_4.print("You said:");
    Pil_4.write(param.getBuffer(), param.getLength());
    Pil_4.println("Fix your Time input") ;
    Pil_4.println();
  Pil_4.flush();
// You can send commands from Pil_5 to your hardware. Just use
// the same Virtual Pin as your Pil_5 Widget
BLYNK_WRITE(V9)
    Pil_5.println("Minum 1x1") ;
    SaveArray[5]=1;
    Pil_5.println("Minum 2x1") ;
    SaveArray[5]=2;
    Pil_5.println("Minum 3x1") ;
    SaveArray[5]=3;
    Pil_5.println("Minum 4x1") ;
    SaveArray[5]=4;
    Pil_5.println("Minum 5x1") ;
    SaveArray[5]=5;
    // Send it back
    Pil_5.print("You said:");
    Pil_5.write(param.getBuffer(), param.getLength());
    Pil_5.println("Fix your Time input") ;
    Pil_5.println();
  Pil_5.flush();
BLYNK_WRITE(V10)
    Pil_6.println("Minum 1x1") ;
    SaveArray[6]=1;
    Pil_6.println("Minum 2x1") ;
    SaveArray[6]=2;
    Pil_6.println("Minum 3x1") ;
    SaveArray[6]=3;
    Pil_6.println("Minum 4x1") ;
    SaveArray[6]=4;
    Pil_6.println("Minum 5x1") ;
    SaveArray[6]=5;
    // Send it back
    Pil_6.print("You said:");
    Pil_6.write(param.getBuffer(), param.getLength());
    Pil_6.println("Fix your Time input") ;
    Pil_6.println();
  Pil_6.flush();
//debug dengan push button virtual port 12
BLYNK_WRITE(V12)
  if(param.asInt()==HIGH)
    Serial.println("button on");
    button[1]=1;
  }else
    Serial.println("button off");
    button[1]=0;
// Digital clock display of the time
void clockDisplay()
  // You can call hour(), minute(), ... at any time
  // Please see Time library examples for details
  Serial.print(currentTime);
  Serial.print(" ");
  Serial.print(currentDate);
  Serial.println();
  // Send time to the App
  Blynk.virtualWrite(V1, currentTime);
  // Send date to the App
  Blynk.virtualWrite(V2, currentDate);
BLYNK_CONNECTED() {
  // Synchronize time on connection
  rtc.begin();
  //Synchronize all widget on connection
  Blynk.syncAll();
void CekOutput()
   for(int i=1;i<=6;i++)
    Serial.print("Nilai di pil ");Serial.print(i);Serial.print(" :");Serial.println(SaveArray[i]);
    Serial.println("");Serial.println("");Serial.println("");
void Program()
 // int i=3;
  {  //cek_box:
    //simpan nilai SaveArray pada Variable nilai
    nilai[i]=SaveArray[i];
    Serial.print("Cek Kotak ke-");Serial.println(i);
    //Serial.println(SaveArray[i]);
    //Program Switch untuk membandingkan nilai waktu
    switch (nilai[i]) {
    case 1:
          cek_box1:
          //minum 1 kali
          Serial.println("Minum obat 1 kali");
          // while(Berat(n+1) == Berat(n))//cek obat sudah diambil atau belum
          if(button[1] == 0)//cek obat sudah diambil atau belum
            satu:
            if(hour()==6)
              if(minute()==1)//ketika jam 6 lebih 2 detik
                if(millis()>time_1+interval_message)
                    time_1=millis();
                    //nyalakan Buzzer
                    Serial.println("Nyalakan Buzzer");
                    //digitalWrite(buzzer, HIGH);delay(10000); //nyalakan Buzzer 10 detik
                    //digitalWrite(buzzer, LOW); //Matikan Buzzer 10 detik
                    //fungsi gerakkan stepper
                    Serial.print("putar Stepper ke kotak ");Serial.println(i);
                    //stepper.setSpeed(4); // gerakkan Stepper dengan kecepatan 4 rpm
                    //stepper.step(255); // buka kotak (Lakukan 255 langkah)--sesuai dengan satu revolusi dalam satu menit
                  }//goto satu;
              if(minute()==5)//menit ke 5
                    time_1=millis();
                    //nyalakan Buzzer
                    Serial.println("Nyalakan Buzzer, peringatan 5 menit");
                  } //goto satu;
              if(minute()==59)//menit ke 59
                    time_1=millis();
                    //nyalakan Buzzer
                    Serial.println("Nyalakan Buzzer, peringatan 59 menit");
                    //kirim email
                    Serial.println("Kirim email notifikasi belum minum obat");
                  }//goto satu;
                    time_1=millis();
                    //Kotak stay membuka di kotak 1
                    Serial.print("sekarang jam :");Serial.print(hour());Serial.print(" ");
                    Serial.println("Jam Sesuai, kotak membuka menunggu notif berikutnya, dan obat belum diminum");
                  }//goto satu;
            else{
                    time_1=millis();
                    //Kotak_Close( kotak obat menutup ke awal(home)
                    Serial.println("kotak close(home) bukan waktu minum obat dan tidak ada alarm apapun");
                 }//goto cek_box1;
         else{
                  time_1=millis();
                  //Cek nilai kotak berikutnya
                  //kirim email
                  Serial.print("obat kotak ke ");Serial.print(i);Serial.print(" sudah diminum ");
                  Serial.print("Cek nilai kotak berikutnya yang ke ");Serial.println(i+1);
                  ////goto sini;
      button[1]=0;
      Serial.println(button[1]);
      break;
    case 2:
          cek_box2:
          //minum 1 kali
          Serial.println("Minum obat 2 kali");
            dua:
            if(hour()==6 || hour()==18)
                    time_1=millis();
                    //nyalakan Buzzer
                  }//goto dua;
                    time_1=millis();
                    //nyalakan Buzzer
                  } //goto dua;
                    time_1=millis();
                    //nyalakan Buzzer
                    //kirim email
                  }//goto dua;
                    time_1=millis();
                  }//goto dua;
            else{
                    time_1=millis();
                 }//goto cek_box2;
         else{
                  time_1=millis();
                  //kirim email
                  ////goto sini;
      button[1]=0;
      break;
  case 3:
          cek_box3:
          //minum 1 kali
            tiga:
            if(hour()==6 || hour()==12 || hour()==18)
                    time_1=millis();
                    //nyalakan Buzzer
                  }//goto tiga;
                    time_1=millis();
                    //nyalakan Buzzer
                  } //goto tiga;
                    time_1=millis();
                    //nyalakan Buzzer
                    //kirim email
                  }//goto tiga;
                    time_1=millis();
                  }//goto tiga;
            else{
                    time_1=millis();
                 }//goto cek_box3;
         else{
                  time_1=millis();
                  //kirim email
                  ////goto sini;
      button[1]=0;
      break;
  case 4:
          cek_box4:
          //minum 1 kali
            empat:
                    time_1=millis();
                    //nyalakan Buzzer
                  }//goto empat;
                    time_1=millis();
                    //nyalakan Buzzer
                  } //goto empat;
                    time_1=millis();
                    //nyalakan Buzzer
                    //kirim email
                  }//goto empat;
                    time_1=millis();
                  }//goto empat;
            else{
                    time_1=millis();
                 }//goto cek_box4;
         else{
                  time_1=millis();
                  //kirim email
                  ////goto sini;
      button[1]=0;
      break;
  default:
        time_1=millis();
        printf("Maaf, format nilai tidak sesuai \n");
        //////goto sini;
      break;
  // Clear the Pil_6 content
  Pil_1.clear();
  Pil_2.clear();
  Pil_3.clear();
  Pil_4.clear();
  Pil_5.clear();
  Pil_6.clear();
  // This will print Blynk Software version to the Terminal Widget when
  // your hardware gets connected to Blynk Server
  terminal.println(F("Blynk v" BLYNK_VERSION ": Device started"));
  terminal.println(F("-------------"));
  terminal.println(F("Type time one until 5 and get a reply, or type"));
  terminal.println(F("anything else and get it printed back."));
  terminal.flush();
  setSyncInterval(10 * 60); // Sync interval in seconds (10 minutes)
  // Display digital clock every 10 seconds
  timer.setInterval(1000L, CekOutput);
  timer.setInterval(1000L, clockDisplay);
  //timer.setInterval(1000L, Program);
but when I want to use the input value (SaveArray []) into the program void function and run the program I experience failure by not being able to save the array value again, then I try to make a comment on
and finally the value of the user input was successfully saved in SaveArray [] and successfully displayed but when I deleted the comment on the code below
    timer.setInterval (1000L, Program);
the program no longer manages to save for input value 1 or SaveArray [1] and surprisingly the input value 1 or SaveArray [1] is filled with the value SaveArray [6] like figure below even though the value in Blynk is correct. even though I want to run the program’s function to see whether the program is what I want or not. thanks you
