Terminal clear
This terminal thingy is a beauty and a great mechanism for interacting with the device remotely. Thanks @Pavlo @vshymanskyy @Dmytro.
If the app is on and the device reboots, there seems to be no way to clear/initialise the terminal screen/buffer in the app. Any pointers here?
That’s right, you need to do it with code.
Just do blynk.virtualWrite(vPin, “\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n”): ? I read somewhere that the widget has the last 25 lines. So, should we gives 25 new lines to clear it?
Depends why you are clearing it.
I normally just clear visible windows, which varies a little based on phone screen res.
You use the magnifying glass at your top right for a possible solution :stuck_out_tongue:
@mohan_sundaram
Please DO NOT tag Blynk Team. We monitor EVERY topic.
It creates irritation and hurts more than helps.
Thanks. I did search using brother Google but not the magnifying glass here. Thought Big Brother would catch everything under the sun.
