Hello everyone,
i need advice on how to increase the buffer for a terminal.
My program is written to print things in setup (when initializing WiFi and Blynk) using terminal.print ().
After connecting to the server (BLYNK_CONNECTED ()), I update all the text to the terminal in the application using terminal.flush ().
The terminal shows only a few characters from the bottom up.
It would be best for me if it could be changed directly in my .ino file. But if that doesn’t work, I can then change WidgetTerminal.h.
PS: I use my own server and I have set: terminal.strings.pool.size = 10
Personally, I think it’s limited by the kind of variable in WidgetTerminal.h
private:
uint8_t mOutBuf [64];
uint8_t mOutQty;
I changed the value from 64 to 5000. This gave me a better result, but I still didn’t get nearly 5000 characters. From this I conclude that this is a limitation of the variable uint8_t, which has, if I’m not mistaken only 255 characters.
Will overwriting something in WidgetTerminal.h solve my problem, or is there a problem on the server as well?
