bug on terminal widget !! display 2  line when i use gps stream widget at
v10-terminal
v11-gps stream
but if i change gps stream to v20 the terminal work nice…
i check on local blynk server and online blynk server same think!!!..
v10-terminal
v11-gps stream
Thanks for the report.
Do you have some additional logic for v11 pin in sketch, eventor widget, smth else?
