Hi! I am using the ds18b20 temperature sensor and it is displaying data on the app. However, the issue I have is that it is constantly displaying -196.6 as the temperature on the app. I have tried a vanilla code with the serial monitor, and the sensor displays the data perfectly to the serial monitor, so I don’t think it’s an issue with the wiring or the sensor itself. I am using an Arduino Nano if that helps.
//fall detection
#include <Wire.h>
const int MPU_addr=0x68; // I2C address of the MPU-6050
int16_t AcX,AcY,AcZ,Tmp,GyX,GyY,GyZ;
float ax=0, ay=0, az=0, gx=0, gy=0, gz=0;
//int data[STORE_SIZE][5]; //array for saving past data
//byte currentIndex=0; //stores current data array index (0-255)
boolean fall = false; //stores if a fall has occurred
boolean trigger1=false; //stores if first trigger (lower threshold) has occurred
boolean trigger2=false; //stores if second trigger (upper threshold) has occurred
boolean trigger3=false; //stores if third trigger (orientation change) has occurred
byte trigger1count=0; //stores the counts past since trigger 1 was set true
byte trigger2count=0; //stores the counts past since trigger 2 was set true
byte trigger3count=0; //stores the counts past since trigger 3 was set true
int angleChange=0;
//temperature
#include <OneWire.h>
#define ONE_WIRE_BUS 4
//blynk
SoftwareSerial DebugSerial (2,3); // RX, TX
char auth[] = "XGTJ9FJkD8tr0f9KFG7WoxFC6oksNOTR";
timer.setInterval(2000L,soundSensor);
timer.setInterval(1000L,tempSensor);
timer.setInterval(3000L,sendSensor);
Blynk.begin(auth,Serial);
DebugSerial.begin(9600);
pinMode(13,OUTPUT);
pinMode(A0,INPUT);
Wire.begin();
Wire.beginTransmission(MPU_addr);
Wire.write(0x6B); // PWR_MGMT_1 register
Wire.write(0); // set to zero (wakes up the MPU-6050)
Wire.endTransmission(true);
sensors.begin();
pinMode(11, OUTPUT);
digitalWrite (11,HIGH);
void sendSensor()
//for fall detection
//2050, 77, 1947 are values for calibration of accelerometer
// values may be different for you
ax = (AcX-2050)/16384.00;
ay = (AcY-77)/16384.00;
az = (AcZ-1947)/16384.00;
//270, 351, 136 for gyroscope
gx = (GyX+270)/131.07;
gy = (GyY-351)/131.07;
gz = (GyZ+136)/131.07;
// calculating Amplitute vactor for 3 axis
float Raw_AM = pow(pow(ax,2)+pow(ay,2)+pow(az,2),0.5);
int AM = Raw_AM * 10; // as values are within 0 to 1, I multiplied
// it by for using if else conditions
if (trigger3==true){
trigger3count++;
if (trigger3count>=10){
angleChange = pow(pow(gx,2)+pow(gy,2)+pow(gz,2),0.5);
if ((angleChange>=0) && (angleChange<=10)){ //if orientation changes remains between 0-10 degrees
fall=true; trigger3=false; trigger3count=0;
else{ //user regained normal orientation
if (fall==true){ //in event of a fall detection
Blynk.notify("the patient has fallen down!");
fall=false;
// exit(1);
if (trigger2count>=6){ //allow 0.5s for orientation change
trigger2=false; trigger2count=0;
if (trigger1count>=6){ //allow 0.5s for AM to break upper threshold
trigger1=false; trigger1count=0;
if (trigger2==true){
trigger2count++;
//angleChange=acos(((double)x*(double)bx+(double)y*(double)by+(double)z*(double)bz)/(double)AM/(double)BM);
if (angleChange>=30 && angleChange<=400){ //if orientation changes by between 80-100 degrees
trigger3=true; trigger2=false; trigger2count=0;
if (trigger1==true){
trigger1count++;
if (AM>=12){ //if AM breaks upper threshold (3g)
trigger2=true;
if (AM<=2 && trigger2==false){ //if AM breaks lower threshold (0.4g)
trigger1=true;
//It appears that delay is needed in order not to clog the port
Wire.write(0x3B); // starting with register 0x3B (ACCEL_XOUT_H)
Wire.endTransmission(false);
Wire.requestFrom(MPU_addr,14,true); // request a total of 14 registers
AcX=Wire.read()<<8|Wire.read(); // 0x3B (ACCEL_XOUT_H) & 0x3C (ACCEL_XOUT_L)
AcY=Wire.read()<<8|Wire.read(); // 0x3D (ACCEL_YOUT_H) & 0x3E (ACCEL_YOUT_L)
AcZ=Wire.read()<<8|Wire.read(); // 0x3F (ACCEL_ZOUT_H) & 0x40 (ACCEL_ZOUT_L)
Tmp=Wire.read()<<8|Wire.read(); // 0x41 (TEMP_OUT_H) & 0x42 (TEMP_OUT_L)
GyX=Wire.read()<<8|Wire.read(); // 0x43 (GYRO_XOUT_H) & 0x44 (GYRO_XOUT_L)
GyY=Wire.read()<<8|Wire.read(); // 0x45 (GYRO_YOUT_H) & 0x46 (GYRO_YOUT_L)
GyZ=Wire.read()<<8|Wire.read(); // 0x47 (GYRO_ZOUT_H) & 0x48 (GYRO_ZOUT_L)
//for sound sensor
void soundSensor()
int sensorVal=analogRead(A0);
Blynk.virtualWrite(V1,sensorVal);
if (sensorVal>=500){
digitalWrite(13,HIGH);
Blynk.notify("a shout or loud noise detected near/from the patient");
else {
digitalWrite(13,LOW);
void tempSensor () {
float temperature = sensors.getTempCByIndex(0) * 9.0 / 5.0 + 32.0;
Blynk.virtualWrite(V5,temperature);
if (temperature>=100){
Blynk.notify("the patient's temperature is over 100");
if (temperature<=95){
Blynk.notify("the patient's temperature is below 95");
void loop ()
