Our mobile home is during the winter in his/her wintersleep.
To controll temp and hum inside the car I placed a NodeMCU and a SHT1x sensor. With the help of the great Blynk libraries and the witgets I now can monitor temp and hum at any time and place!
This is my first attemp, later I will clean the code and put some better commands in it!
For now enjoy!
* Downloads, docs, tutorials: http://www.blynk.cc
* Blynk community: http://community.blynk.cc
* Social networks: http://www.fb.com/blynkapp
* http://twitter.com/blynk_app
* This example runs directly on ESP8266 chip.
* You need to install this for ESP8266 development:
* https://github.com/esp8266/Arduino
* Please be sure to select hte right ESP8266 module
* in the Tools -> Board menu!
* Change WiFi ssid, pass, and Blynk auth token to run :)
#include <SHT1x.h>
// Specify data and clock connections and instantiate SHT1x object
#define dataPin D1
#define clockPin D2
float temp_c;
float temp_f;
float humidity;
SHT1x sht1x(dataPin, clockPin);
char auth[] = "xxxxxxxxx";
SimpleTimer tijd;
void schrijven()
// This function sends Arduino up time every 1 minute
// In the app, Widget's reading frequency should be set to PUSH
// You can send anything with any interval using this construction
// Don't send more that 10 values per second
Blynk.virtualWrite(V5, temp_c);
Blynk.virtualWrite(V6,humidity);
if (temp_c >15)
Blynk.virtualWrite(V2,255);
Blynk.virtualWrite(V3,0);
Blynk.virtualWrite(V2,0);
Blynk.virtualWrite(V3,255);
if (humidity >75)
Blynk.virtualWrite(V0,255);
Blynk.virtualWrite(V1,0);
Blynk.virtualWrite(V0,0);
Blynk.virtualWrite(V1,255);
Blynk.begin(auth, "xxxx", "xxxxxxxx");
Serial.println("Starting up");
tijd.setInterval(60000, schrijven); // Here you set interval (1 min) and which function to call
// Read values from the sensor
temp_c = sht1x.readTemperatureC();
temp_f = sht1x.readTemperatureF();
humidity = sht1x.readHumidity();
// Print the values to the serial port
Serial.print(temp_c, DEC);
Serial.print("C / ");
Serial.print(temp_f, DEC);
Serial.print("F. Humidity: ");
Serial.print(humidity);
Serial.println("%");
tijd.run();
André
